atmega16 problem
11 posts / 0 new
i searched for a seven segment digital clock circuit using avr atmega16 on internet.
i also find the program code for it. i then copied it to atmel studio 5 . created a .hex file, it compiled but didn't
work when i used it in proteus 8.
I am a Learner
Ahsan Ali wrote:
atmel studio 5
Why 5 ??
didn't work when i used it in proteus 8.
So get debugging, then!
Step through the code & see where it goes wrong.
It might not be the root of your problem, but awneil is right. Studio 5 is the worst of the worst. It was so bug-ridden that Atmel at that time very quickly came out with Studio 6. They are now at Studio 7. Get one of those, and get rid of Studio 5. No-one here wants to talk about Studio 5. Very few have it installed, and they will get the firm advice you're getting here and now.
i am using windows 7. atmel 7 is not possible to download
I am a Learner
If the size of the down load for AS7 is too big (or too slow to download), then get AS4.19
well i can post program coding here. you could check can creates a .hex file for me.
i am programing for seven segment digital clock.
and (the website from where i picked the program coding) they says that it is program in atmel studio 5.
and also i am not seeing any error.
it builds up perfectly.
any help would be appreciable
as i want to simulate it on proteus before performing
I am a Learner
i am using macbook. and have installed windows 7 besides mac os.
so so atmel 7 is not easily possible
I am a Learner
"Does't work" does not tell us much about the problem your having, also if your using Proteus, you must have a license for its use, you should be asking them for help as your description of the problem is it "doesn't work" in Proteus!
ok . i have a program.
i ran it into atmel 5 and generated .hex file.
the program compiled successfully.
then i uploaded file into proteus 8.
microcontroller does not works.
I am a Learner
An alternative to Atmel Studio 7 on macOS is CrossPack.
CrossPack was recently updated; the update includes Atmel AVR GCC 3.5.4.
That's not the most recent Atmel AVR GCC though it's close as Atmel Studio 7.0.1416 has AVR GCC 5.4.0 and Atmel Studio 7.0.1188 has AVR GCC 4.9.2.
The IDE appears to be Apple Xcode instead of Microsoft Visual Studio Isolated Shell.
AVaRICE is included though don't know how that integrates with Xcode through AVR GDB.
https://github.com/obdev/CrossPack-AVR/blob/master/mkdist.sh
# The following packages are fetched from Atmel:
atmelToolchainVersion=3.5.4
version_binutils=2.26.20160125
version_gcc=4.9.2
version_avrlibc=2.0.0
via
http://www.atmel.com/tools/atmelavrtoolchainforwindows.aspx
http://www.microchip.com/development-tools/atmel-studio-7/avr-and-arm-toolchains-(c-compilers)
http://avarice.sourceforge.net/
If it compiles ok, but does not run in proteus, cantact the help at labcenter!
