omitting unused functions
12 posts / 0 new
I made a timer0_pwm library for atmega16 that has these functions:
void PWM0_init();
void PWM0_start(uint16 freq); // the frequency here because the timer start running by putting the prescaler which is a factor of frequency
void PWM0_setDuty(uint8 duty_perrcent);
void PWM0_stop();
in the main function I only used PWM0_init(); but I looked into the assembly file and I found that all the functions were written in the application code- not only the function I used-, also I found that it put all the functions from another library that I added to the directory of project even that I didn't includ it's .h file in the main file.I also found that it added the division functions that are required for these other functions but not needed for the PWM0_init() function. How can I make the compiler put the only function called and omit the rest of the unused functions from the timer0_pwm library and the other libraries?
What compiler are we discussing here?
What compile and link options are you using?
Usually it is the linker that decides what to throw away, so have you examined the linker output?
Essential information indeed!
Whether this facility is available at all and, if it is, how to control it will both be specific to the particular toolchain.
ISTR, for GCC ARM, it needs both a Compiler and a Linker option to be correctly set for this to work:
  1. The Compiler has to be told to make things "removable";
  2. The Linker has to be told to do the actual "removing".
awneil wrote:
ISTR, for GCC ARM, it needs both a Compiler and a Linker option [...]
Same for avr-gcc.
If you are using avr-gcc in AS7 it already passes -ffunction-sections, - fdata-sections and -gc-sections
the compiler is  AVR-GCC
the compiler is AVR-GCC  .... and the IDE is eclipse .. does we set these options by code or in project settings .. and please how?
yes Iam using avr-gcc but it doesn't remove them I opened the .lss file and all the functions were in the code
Weren't you listening?  I just told you the options. You pass - ffunction-sections and -fdata-sections to the compiler and -Wl,-gc-sections to the linker.
I searched for this problem in some other threads here and I found  another thread were you had put the solution of putting every function in separate library and calling then including them all in one library:
so which one is the better solution ?
What I just told you.
thanks
