SOLVED: XMega1284U USB CDC Receive issue
4 posts / 0 new
Hi, we are trying to add some USB CDC code to a Xmega128A4U circuit. With Imagecraft compiler, there are no examples so we have resorted to using AVR Studio 7 and ASF.
With the ASF code, the example based on the STK600 seems to almost work. There are no problems sending out characters or strings, but when we try to read a character, this does not work. We have managed to read and echo one character only.
Below is the code we are using.
		if (udi_cdc_is_rx_ready()) {
			c = udi_cdc_getc();
		} else {
Any help would be much appreciated.
Electronic System Design
http://www.esdn.com.au
Looks like the proper usage of udi_cdc_is_rx_ready().  The following works with multiple CDC instances:
int main (void)
	sysclk_init();
	board_init();
	pmic_init();
	cpu_irq_enable();
	cons_init();
	sleepmgr_init();
	com_init();
	do {
		int chr;	// character that is input and echoed
		int port;	// current port number
		// sleep until USB wakes me
		sleepmgr_enter_sleep();
		// check all ports to see which one woke me up
		for (port = 1; port < UDI_CDC_PORT_NB; port++) {
			// if rx is ready, echo char
			if (udi_cdc_multi_is_rx_ready(port)) {
				udi_cdc_multi_putc(port, chr = udi_cdc_multi_getc(port));
				if (chr == '\r')	// expand \r to \r\n
					udi_cdc_multi_putc(port, '\n');
	} while (true);
What does your conf_usb.h look like?
Greg Muth
Portland, OR, US
Thanks for the reply, Greg. I tried this code but still the same.
Here is my conf_usb.h file. This is generated straight from ASF. Thanks
 * \file
 * \brief USB configuration file for CDC application
 * Copyright (c) 2009-2016 Atmel Corporation. All rights reserved.
 * \asf_license_start
 * \page License
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 *    this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 *    this list of conditions and the following disclaimer in the documentation
 *    and/or other materials provided with the distribution.
 * 3. The name of Atmel may not be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * 4. This software may only be redistributed and used in connection with an
 *    Atmel microcontroller product.
 * THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR IMPLIED
 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
 * EXPRESSLY AND SPECIFICALLY DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR
 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
 * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
 * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
 * \asf_license_stop
 * Support and FAQ: visit <a href="http://www.atmel.com/design-support/">Atmel Support</a>
#ifndef _CONF_USB_H_
#define _CONF_USB_H_
#include "compiler.h"
#include "board.h"
 * USB Device Configuration
//! Device definition (mandatory)
#define  USB_DEVICE_VENDOR_ID             USB_VID_ATMEL
#if BOARD == UC3B_BOARD_CONTROLLER
# define  USB_DEVICE_PRODUCT_ID            USB_PID_ATMEL_UC3_CDC_DEBUG
#else
# define  USB_DEVICE_PRODUCT_ID            USB_PID_ATMEL_ASF_CDC
#endif
#define  USB_DEVICE_MAJOR_VERSION         1
#define  USB_DEVICE_MINOR_VERSION         0
#define  USB_DEVICE_POWER                 100 // Consumption on Vbus line (mA)
#define  USB_DEVICE_ATTR                  \
	(USB_CONFIG_ATTR_SELF_POWERED)
// (USB_CONFIG_ATTR_BUS_POWERED)
//	(USB_CONFIG_ATTR_REMOTE_WAKEUP|USB_CONFIG_ATTR_SELF_POWERED)
//	(USB_CONFIG_ATTR_REMOTE_WAKEUP|USB_CONFIG_ATTR_BUS_POWERED)
//! USB Device string definitions (Optional)
#define  USB_DEVICE_MANUFACTURE_NAME      "ATMEL ASF"
#define  USB_DEVICE_PRODUCT_NAME          "CDC Virtual Com"
// #define  USB_DEVICE_SERIAL_NAME           "12...EF"
 * Device speeds support
 * Low speed not supported by CDC
//! To authorize the High speed
#if (UC3A3||UC3A4)
#define  USB_DEVICE_HS_SUPPORT
#elif (SAM3XA||SAM3U)
#endif
 * USB Device Callbacks definitions (Optional)
#define  UDC_VBUS_EVENT(b_vbus_high)
#define  UDC_SOF_EVENT()                  main_sof_action()
#define  UDC_SUSPEND_EVENT()              main_suspend_action()
#define  UDC_RESUME_EVENT()               main_resume_action()
//! Mandatory when USB_DEVICE_ATTR authorizes remote wakeup feature
// #define  UDC_REMOTEWAKEUP_ENABLE()        user_callback_remotewakeup_enable()
// extern void user_callback_remotewakeup_enable(void);
// #define  UDC_REMOTEWAKEUP_DISABLE()       user_callback_remotewakeup_disable()
// extern void user_callback_remotewakeup_disable(void);
#ifdef USB_DEVICE_LPM_SUPPORT
#define  UDC_SUSPEND_LPM_EVENT()          main_suspend_lpm_action()
#define  UDC_REMOTEWAKEUP_LPM_ENABLE()    main_remotewakeup_lpm_enable()
#define  UDC_REMOTEWAKEUP_LPM_DISABLE()   main_remotewakeup_lpm_disable()
#endif
//! When a extra string descriptor must be supported
//! other than manufacturer, product and serial string
// #define  UDC_GET_EXTRA_STRING()
 * USB Interface Configuration
 * Configuration of CDC interface
//! Define two USB communication ports
#define  UDI_CDC_PORT_NB 1
//! Interface callback definition
#define  UDI_CDC_ENABLE_EXT(port)         main_cdc_enable(port)
#define  UDI_CDC_DISABLE_EXT(port)        main_cdc_disable(port)
#define  UDI_CDC_RX_NOTIFY(port)          uart_rx_notify(port)
#define  UDI_CDC_TX_EMPTY_NOTIFY(port)
#define  UDI_CDC_SET_CODING_EXT(port,cfg) uart_config(port,cfg)
#define  UDI_CDC_SET_DTR_EXT(port,set)    main_cdc_set_dtr(port,set)
#define  UDI_CDC_SET_RTS_EXT(port,set)
//! Define it when the transfer CDC Device to Host is a low rate (<512000 bauds)
//! to reduce CDC buffers size
#define  UDI_CDC_LOW_RATE
//! Default configuration of communication port
# define  UDI_CDC_DEFAULT_RATE             57600
#else
# define  UDI_CDC_DEFAULT_RATE             115200
#endif
#define  UDI_CDC_DEFAULT_STOPBITS         CDC_STOP_BITS_1
#define  UDI_CDC_DEFAULT_PARITY           CDC_PAR_NONE
#define  UDI_CDC_DEFAULT_DATABITS         8
 * USB Device Driver Configuration
//! The includes of classes and other headers must be done at the end of this file to avoid compile error
#include "udi_cdc_conf.h"
#include "uart.h"
#include "main.h"
#endif // _CONF_USB_H_
OK, I did some reading and stumbled on a fix.
This issue seems to be very common across all Xmega devices where the udi_cdc_putc (usb transmit) always works but the udi_cdc_getc will get none or just one character. I also have a XMega256A3BU kit which seems to work well and the udi_cdc_getc has no issues with getting multiple characters.
So comparing the  XMega256A3BU kit code and with some other reading, the chnages were:
  • the UDI_CDC_LOW_RATE was turned off (commented out)
  • the #define  UDI_CDC_RX_NOTIFY(port) was blank
So doing these two things enabled the udi_cdc_getc to work as desired. Let me know in the comments below if this helps anyone else.
#define  UDI_CDC_RX_NOTIFY(port)          //uart_rx_notify(port)
//#define  UDI_CDC_LOW_RATE
