SD/MMC interface to my xmega256 a3bu xplained board
8 posts / 0 new
Hello all,
I need help to interface the SD/MMC (fatFS) card into my xmega256 a3bu board.
And need to read & write some files into it, card should be FAT formatted.
Do you have any example or reference code that I can try ?
Also I have got the below code from github and its not working.
https://github.com/qbazd/xmega-s...
And got the issue in SD card initialization.
For using MMC in SPI mode in J4 connector of the board then the below configurations are correct ?
//! \name SPI microSD
#define SD_MMC_SPI_MEM_CNT              1
#define SD_MMC_0_CD_GPIO                IOPORT_CREATE_PIN(PORTC, 6)
#define SD_MMC_0_CD_DETECT_VALUE        0
#define SD_MMC_SPI_USES_USART_SPI_SERVICE // To signal that is a USART in SPI mode
#define SD_MMC_SPI                      &USARTD0
#define SD_MMC_SPI_SCK                  IOPORT_CREATE_PIN(PORTD, 1)
#define SD_MMC_SPI_MISO                 IOPORT_CREATE_PIN(PORTD, 2)
#define SD_MMC_SPI_MOSI                 IOPORT_CREATE_PIN(PORTD, 3)
#define SD_MMC_SPI_0_CS                 IOPORT_CREATE_PIN(PORTD, 0)
Can you anyone help to me come out of this issue ?
Thanks for your help.
Titus S.
Titus S.
The FatFs user manual itself has some examples. The code given to illustrate how to use f_open() for example is pretty much a standalone test of FatFs...
http://elm-chan.org/fsw/ff/doc/o...
The code there is:
/* Read a text file and display it */
FATFS FatFs;   /* Work area (file system object) for logical drive */
int main (void)
    FIL fil;       /* File object */
    char line[82]; /* Line buffer */
    FRESULT fr;    /* FatFs return code */
    /* Register work area to the default drive */
    f_mount(&FatFs, "", 0);
    /* Open a text file */
    fr = f_open(&fil, "message.txt", FA_READ);
    if (fr) return (int)fr;
    /* Read all lines and display it */
    while (f_gets(line, sizeof line, &fil))
        printf(line);
    /* Close the file */
    f_close(&fil);
    return 0;
Obviously there's a bit more to it - for AVR the printf() may not work immediately. But this shows the general technique of f_mount() then f_open().
Now above you simply said:
"not working" says almost nothing about the problems you may be encountering??
Thanks for your reply.
Can you please refer to the below link where I have mentiond the issues ?
I've not connected any serial port and using debugger and found that MMC/SD is failed in initialization.
I can't do this FatFS example since MMC/SD card is itself failed in initialization right.
Can you please help me on this ?
Thanks again.
Titus S.
Since you are using ASF, why don't you try looking at the FATFS Access Example project for the XMEGA-A3BU Xplained?
Greg Muth
Portland, OR, US
Xplained Boards mostly
Did you solve this issue with that library?
The Acces Example code from ASF did not work for me
Hi Greg,
Its just test example for fatfs, and its using SDRAM to test the FatFS, but I need example for MMC/SD.
Titus S.
Hi fabianpi,
Unfortunately, no.
Please update here if you able to make it work.
Thanks !
Titus S.
I've found this thread http://www.avrfreaks.net/forum/solved-micro-sd-card-interface-spi-elm-chans-fatfs?skey=xmega%20fatfs
I'm planning to use the github files but I don't know how to start to use it with the xMEGA256A3BU Xplained
