Online update to 7.0.1417 craves Windows update KB2978092.
6 posts / 0 new
EDIT: I could have sworn the problem described below made selecting Next in the wizard impossible. Somewhere during my trials it went enabled though the KB is still craved. Meanwhile I downloaded the offline installer (as I always have done in the past) and am currently running that. Will report on progress.
Still puzzled about the unavailability of the KB and that MS serves me something marked Windows6.1 when I claim Windows7...
Original post:
Today I attempted an online update of Atmel Studio for the first time. Telling Atmels Studio to look for updates eventually led to downloading as-installer-7.0.1417-web.exe . Upon running that it protests that I need Windows Update KB2978092:
This update is not listed in my Windows Update.
So I download according to the URL given in the sceenshot above. I carefully choose the update fitting my machine:
I end up with a file named Windows6.1-KB2978092-x64.msu . Notice the "6.1".
When I try to apply that file I am informed that it "does not apply" to my system.
Here's my system properties:
Could someone cast a second eye eon this and see if I missed something?
I tried searching for others with this problem, but came out empty. Anyone recognize this from any previous thread here?
Are you there Morten? Help!?   ;-)
The warning is benign... Some of the cumulative updates from Microsoft fails to register the actual hotfix that we require/suggest (KB2978092 in this case, which fixes issues with the WARP acceleration for fallback rendering).
We have seen this a couple of times before and we try correct them retroactively (i.e too late... frown)
:: Morten
My copy of Windows 7 SP1 Pro has KB2978092 but its baseline was from HP approx 2015-March (after KB2978092)
Windows 7 can have patchwork updates that are consistent, patchwork updates that are not consistent, or cumulative updates (2016-Oct and subsequent)
An inconsistency is indicated by a System File Check (sfc.exe) error; if an error then attempt a fix by sfc.
Could try the System Update Readiness Tool.
Could go cumulative updates but that enables Customer Experience Improvement Program (CEIP) (diagnostics and telemetry)
https://support.microsoft.com/en-us/help/2978092/graphics-software-or-applications-crash-when-they-use-warp-for-software-rendering-in-windows
Microsoft
Microsoft
MSDN
System File Checker
https://msdn.microsoft.com/en-us/library/windows/desktop/aa382541%28v=vs.85%29.aspx
https://support.microsoft.com/en-us/help/947821/fix-windows-update-errors-by-using-the-dism-or-system-update-readiness-tool
https://support.microsoft.com/en-us/help/4009469/windows-7-sp1-windows-server-2008-r2-sp1-update-history
https://www.microsoft.com/products/ceip/en-US/default.mspx
Thanks for the information.
It's a moving target due to Microsoft Patch Tuesday that's once per month.
IIRC some Windows 7 and Windows 8.1 updates are a preview of the next month's updates (gives system administrators a heads up)
Windows 10 has the Preview ring that gives software creators a heads up before an update is released.
Hmmm, we only stop on required patches, not on suggested ones... The one you showed is optional..
SFC won't help unfortunately, it's an inconsistency in the hotpatch registration that triggers the false detection.
:: Morten
Thanks Morten!
I swear the "Next" button was disabled for several attempts to install. It "magically" got enabled - something you can see in my screenshot but which I failed to observe...
I suppose the online/web install would have succeeded at that point but I was already on my way with the d/l of the offline installer. And that succeeded, so all is well that ends well.
Anyway, you're often the unsung hero re Studio, so as a small remedy I'm now humming a tune in your honor :-) I'll mark you post about the update being optional as the solution for anyone being in the same situation, and that happens to locate this thread.
Thank you!
