microSD FAT32
6 posts / 0 new
Hi freaks, trying to setup a FAT32 microSD card.  I've ported the ASF example of the AT45DBXX to sd_mmc, i.e. I have initialised the microSD SPI instead of the AT45DBXX SPI.  I've have enabled and disabled the following:
#define LUN_0                DISABLE  //!< On-Chip Virtual Memory.
#define LUN_1                DISABLE   //!< AT45DBX Data Flash.
#define LUN_2                ENABLE  //!< SD/MMC Card over SPI.
#define LUN_3                DISABLE
#define LUN_4                DISABLE
#define LUN_5                DISABLE
#define LUN_6                DISABLE
#define LUN_7                DISABLE
#define LUN_USB              DISABLE  //!< Host Mass-Storage Memory.
the following simple test fails:
 if (mem_test_unit_ready(LUN_ID_SD_MMC_SPI_MEM) == CTRL_GOOD)
    // Get and display the capacity
    mem_read_capacity(LUN_ID_SD_MMC_SPI_MEM, &VarTemp);
    print(SHL_USART, "OK:\t");
    print_ulong(SHL_USART, (VarTemp + 1) >> (20 - FS_SHIFT_B_TO_SECTOR));
    print(SHL_USART, " MB\r\n");
    // Display an error message
    print(SHL_USART, "Not initialized: Check if memory is ready...\r\n");
​so this leaves me thinking that either the microSD card is too large, "8 GBytes" or I have missed something in the porting of the example.  Maybe I have to change other things to to get it to work with the micorSD.  Any help ill be really appreciated.  Thanks
Got it guys, was using the wrong SPI Peripheral.  Duh!
Hey Fianawariror,
Have you succeeded? I am trying to connect MicroSD 2GB FAT16 with UC3A3 so i can save some data in a .txt file. I have tried with ASF Examples (FSACCESS_EXAMPLE, FAT_EXAMPLE) but without success. I could use some help. :)
Greetings
I'll get back to you. I'm busy at the moment mate.
Dont bother, but thank you anyway :)
I've done it . I have used FAT_EXAMPLE from ASF, changed it a little bit and it works like a charm now.
Hi m@rko, I adopted the  AT45DBX example.  Have a look at it and please ask if you have any problems.
