XMega32C4 a good choice for LUFA?
32 posts / 0 new
I'm working on a project I call Orthrus. I've built a prototype with an ATMega32U2, and the problem is that my software AES implementation slows it down by a factor of 5. For the application, I could sort of live with a hard disk that runs at 150 kB/sec, but 30 is just too slow to be useful.
My thinking at the moment is that if I move to the XMega32C4, I could use the hardware AES module in parallel with the I/O so that the encryption penalty isn't so bad. I have some concerns, though: The XMega support in LUFA is described as experimental. Is it deficient? Has anyone done anything with it with this chip? Also, can one use ordinary AVR ISP programming with the XMega like with the ATMega (using avrdude and a usbtiny)?
I think the usual choice for USB on Xmega is actually the dreaded "ASF".
http://asf.atmel.com/docs/latest...
As you say, Dean describes his LUFA support for Xmega (and UC3) as:
Having said that an "experimental preview" from Dean could actually ended up being better than the ASF stuff!
The two programming mechanisms for Xmega are either JTAG or PDI. The latter specifically invented for Xmega just to piss off people who already had a tiny/mega ISP programmer cheeky. It's possible that the firmware of some "3rd party" programmers may have been updated to include PDI support.
Neat project.
The hardware RNG is nice, but consider that you can create good quality (for cryptographic purposes) random numbers using only the 128kHz oscillator in the AVR.  The idea is that this RC oscillator has (as all oscillators do) a bit of jitter.  By sampling the LSB of a timer running from the main clock (be it the 8 MHz RC, or a crystal, or...) in the WDT ISR, you can generate one bit of entropy for each overflow of the WDT (in interrupt-only mode).
I've done this and it works well.  The gotcha is that you can only generate 1 bit every 15 ms (minimum period for the WDT interrupt), so 64 bits takes about one second.  I use it to seed an LFSR, so I've not needed it (or tested it) for generating large quantities of random numbers.  I did let one run for a day, generating about 750 kB.  I then applied standard tests against this dataset with good results.
"Read a lot.  Write a lot."
joeymorin wrote:
Neat project.
I considered that, but I can get a conservative 10 kHz sampling rate (the actual "frequency" of the generator is in the high-ish hundreds of kHz) from the hardware, and it adds only around a dollar to the BOM. It's also excellent for marketing. :)
Seriously, though, have you run a sample from that technique through DieHarder to gauge the quality? I'd guess (obviously without having tried it) that the jitter would have some cyclicality in the short term. That said, similar DieHarder tests with my gizmo are pending (I'm missing a part on the prototype).
What's killing me right now, though, is the AES performance on an ATMega32u2 running at 16 MHz. It's pitiful. And the SPI clock being stuck at 8 MHz doesn't help either.
Groan.
Ok, what's the best option for someone developing on a mac who's never done either of them before? The hardware is a blank slate - I can set it up for either or both (assuming it doesn't take up pins I need for something else). What I do *not* want to do is do programming over USB. If you want to inject rogue firmware in, you're gonna have to crack the case open. :)
PDI (Program-Debug-Interface) works pretty well.   And uses less pins than JTAG.
ATMEL-ICE,  DRAGON, JTAGICE-2, JTAGICE-3 all work with PDI.   But of course PDI, debugWIRE and aWIRE are Atmel specific.
Xmega works pretty well but you may want to consider ARM Cortex-M3 or M4.    You will have most tools and IDE software on a Mac when you go to ARM.
You can probably run Atmel PC software on a Virtual PC but I don't know how painful it might be.
What's the PDI equivalent of AVRDude? I will check if my avr-gcc accepts an mmcu argument for xmega. If I can figure out how to get a .hex into the chip, the rest I think I can manage.
There should be a suitable dragon_pdi programmer (or equivalent).  Just type avrdude -c
Of course there is atprogram.exe from Atmel.
Well, it turns out the C4 doesn't have the AES subsystem. sad The C3 does... maybe. The datasheet says that "selected devices only" have it, but I don't see where it says which ones.
Yup.  Cryptographically sound at first glance, but not exhaustively investigated.
You may want to consider less computationally expensive alternatives like elliptic curve encryption.
EC is the wrong tool for the job. I need a symmetric algorithm for this.
[ASF-3.34.1]
The follow-on to ASF3 is ASF4 but ASF4 is not on XMEGA C (XMEGA AU has ASF4)
I'm having difficulty getting to ASF4 USB on XMEGA32A4U (USB device instance error) (likely I'm mis-operating)
There's USBasp firmware that does PDI.
Dean's LUFA AVRISP2 is popular.
Atmel START
Atmel Software Framework 4 (ASF4)
Introduction
http://atmel-studio-doc.s3-website-us-east-1.amazonaws.com/webhelp/GUID-4E095027-601A-4343-844F-2034603B4C9C-en-US-1/index.html?GUID-D988E54F-D11D-4617-8C23-60B4CACFCB68
via http://start.atmel.com/
Jim's Projects
Cheap USBASP knockoff programmer
Posted on December 18, 2014 by Jim
http://jimlaurwilliams.org/wordpress/?p=4803
Update: PDI programmer and more cable stuff
http://www.fourwalledcubicle.com/AVRISP.php
Edit : Atmel START
It's AVRDUDE other than via Atmel Studio :
  • CrossPack
  • Homebrew
  • Atmel Studio on Windows on Parallels
PDI is dedicated and present whereas JTAG is shared (upper half of port B on XMEGA A1U) and is present on some XMEGA (PDI only on XMEGA A4U)
https://www.obdev.at/products/crosspack/index.html
https://github.com/obdev/CrossPack-AVR
Homebrew — The missing package manager for macOS
https://brew.sh/
ka7ehk is a macOS operator (there are at least a few more)
http://www.avrfreaks.net/forum/avr-studio-mac-linux by ka7ehk
some of Atmel's cortex m7 offerings have got fast crypto engines as well as fast spi. These might be a better choice than the AVR offerings.
nsayer wrote:
The C3 does [AES]... maybe.
AES is in the XMEGA384C3 datasheet.
http://www.microchip.com/wwwproducts/en/atxmega384c3
Would a crypto authenticator chip connected to your preferred AVR work?
http://www.atmel.com/tools/CryptoAuthLib.aspx?tab=documents
XMEGA A3BU was added to CryptoAuthLib 2016-Jan (zip file, README.md)
http://start.atmel.com/#examples/cryp
Intent is reference for discussion :
AVR1318: Using the XMEGA built-in AES accelerator
http://ww1.microchip.com/downloads/en/AppNotes/doc8106.pdf
(page 1)
The AES uses 375 clock cycles to execute one encryption/decryption [128 bits] after the Key and State memory is loaded and the mode of operation is selected.
via
http://www.microchip.com//wwwAppNotes/AppNotes.aspx?appnote=en591666
via
http://www.microchip.com/wwwproducts/en/atxmega32a4u
I'm sort of starting to warm to the ATXMega384C3. It is on the LUFA supported chips list, and from what I can tell (I'm confirming this with @MicrochipTech now) it's the minimum unit that supports the AES subsystem. What I like is that I believe I can set up a combination of DMA and interrupt driven machinery to precalculate the entire sector's worth of AES counter mode XOR material in the background. If I start that going first, it likely can get a head start while the SD card read/write command is being sent and likely get far enough ahead of the actual I/O that I won't have to wait on the crypto at all. Doubling the SPI clock and not waiting on crypto suggests to me that this solution would yield >300 kB/sec since the current version with equivalent null crypto on the 32u2 is getting ~150 kB. Not fantastic, but I think doing better would require using the more modern access modes on the SD cards, at which point it would also be time to consider super-speed USB.
This is my first XMega design. If you guys want to take a look and tell me all the ways it's wrong, that would likely be fun: https://cdn.hackaday.io/files/20...
C:\SysGCC\avr\avr\include\avr>grep "AES_t \*" *
iox128a1.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox128a1u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox128a3.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox128a3u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox128a4u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox128b1.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox128b3.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox16a4.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox16a4u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox192a3.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox192a3u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox256a3.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox256a3b.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox256a3bu.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox256a3u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox32a4.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox32a4u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox384c3.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox64a1.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox64a1u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox64a3.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Crypto Module */
iox64a3u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox64a4u.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox64b1.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
iox64b3.h:#define AES    (*(AES_t *) 0x00C0)  /* AES Module */
I'm guessing it's a pretty fair bet the GCC headers would not be defining a location for a block of AES registers in a chip that does not have AES so I think you can take it as read that all the above have it. Clearly that includes:
Thanks - I think that's good confirmation.
If I have a misgiving, it's that the chip is outrageous overkill for what's going on (I'll be surprised if I use 1/50th of the flash)... except for the AES accelerator. I guess I can get past that given that I've used Raspberry Pi Zeros as SPI masters for 7 segment clock displays. :)
Why then are you paying for 384K of flash when:
seem to confirm that a couple of the 16K flash models have the AES unit too ?
BTW as moderator can I ask you to modify your signature? This is a non-commercial site, the only place limited advertising is permitted is the marketplace forum.
Huh. The A4U might work. I'll have to look into it.
EDIT: Amusingly, the 32A4U is a nickel less at Digikey. :)
I've ordered prototype boards for the xxA4U and have some 32A4U parts on the way. I also bought an AtmelICE and the plan is to use avrdude -c atmelice_pdi for programming. I haven't exhaustively started porting the firmware yet, but LUFA does seem to at least compile when properly set up for the A4U, and it looks like I can use the internal 32 MHz clock with USB SOF correction for the system clock and the PLL to turn that into 48 MHz for USB. Finally, it looks like I can eventually try USART0 in MSPI mode to improve the throughput. The eventual hope is to break through 500 kB/sec (the 32u2 with no crypto is doing 200 now, but that's at 8 MHz SPI instead of 16 and no SPI double-buffering). It's not going to be a speed demon, but that will at least be minimally usable, I think. Schematic: https://cdn.hackaday.io/files/20772888709248/Orthrus%20v2.0.pdf
Interesting project, I like it.
I suggest using a crystal rather than the SOF calibration system... I've found that a crystal is more reliable, especially if you have heat generation sources (SD cards) and a high CPU clock on the board. You will probably find you can run your CPU clock at 48MHz without issue too, if you really want to push for higher speed. If you can get long SPI reads working with DMA then 500kB/sec should be possible I think. Good luck!
If it is of any interest, I did some experiments generating random numbers on XMEGA with no external hardware. You can never have enough sources of entropy, and my tests performed well in DieHarder. https://github.com/kuro68k/xrng
So far the SOF calibration system seems to be working ok, albeit with a very small sample size. One thing I wonder about is that the sample code in LUFA uses the 32 MHz oscillator raised up to 48 MHz as the USB clock with the SOF correction and separately uses the 2 MHz oscillator with the PLL to make the 32 MHz CPU clock. I, instead, clock the 32 MHz oscillator at 32 MHz for the CPU clock, SOF correct it, and then use the PLL from that to get 48 MHz for the USB clock. I figured the results would be the same, but I'd be running one less oscillator and save some power. Might there be an accuracy difference there that you're speaking of?
The idea of overclocking the CPU at 48 MHz is very, very tempting. I was getting around 225 KB/sec at 32 MHz, but that was with AES counter mode, which is cryptographically weaker for this purpose, so I've switched to XEX mode. But XEX mode can't be precomputed in the background with the DMA system, so I'm now down to 135 KB/sec. I'm contemplating moving to a AT32UC3A4128S so that I can get a faster core, high speed USB, 4 bit SD I/O and AES-256. There's no question that I'll get results that are within an order of magnitude of the current state of the art for ordinary SD card readers. But that chip is going to require a whole lot of "firsts" from me - BGA, AVR32, 4 bit SD, JTAG programming... It's giving me pause to have that many new things to work through at one time.
Well, the PLL does introduce some jitter, so it is likely to be a bit worse than using the 32MHz RC oscillator at 48MHz.
I found that the DFLL SOF calibration worked fine most of the time, but some small number of machines didn't like it for long periods. As in, if you kept the device attached for 20 minutes it would suddenly stop responding. Windows makes it worse by aggressively power managing your device, which involves not sending it frames to recalibrate from very often.
I looked at AVR32 for a potential project. The chips are very nice, but don't get a lot of love from Atmel. They are rather different to the 8 bit range to use too, which takes some getting used to. To be honest, if I were going to invest the time in switching I'd consider ARM instead. Cheaper, even faster, and with a solid future. Or maybe PIC32, I have heard those are nice even if MPLAB is awful. ARM at least gives you a great deal of freedom to pick any IDE and toolchain you desire.
I wouldn't worry too much about XEX, what you are using (CBC?) is going to be more than adequate, especially if you have a good RNG for the IVs. Get the first version working with an XMEGA at 48MHz, and you will probably find that in practice it's fast enough. Have you tried sleeping while the DMA works? It shares memory access cycles with the CPU and the datasheet suggests that the CPU gets priority, so unless there is some useful work to be doing it might be quicker to sleep in idle mode.
I was using counter mode (perform ECB on 0, 1, 2... and XOR with plaintext). When you're doing WDE, there's no place to store an IV, so you can't use individual ones for every ciphertext. You can only use a nonce (you can tweak the nonce on a per-disk-block basis, but within a single disk block it's still a fixed nonce). Counter mode allowed me to precalculate the cryptostream in the background and in my testing it literally had no impact on the throughput compared to turning the crypto completely off. The downside, though, is that like all streaming modes (without varying IVs), there are known plaintext, known ciphertext  and bit-flip attacks that make it weak for this purpose.
XEX blunts those weaknesses and adds 16 byte diffusion on bit-flipping attacks, but there's no way to use DMA practically that I can find because you need the plaintext to perform the encryption, and you only get that in the pipeline between USB and the SD card.
Yes, veery cool project!
You need to do a small correction to the project web-site. The person behind LUFA is named Dean Camera.
Best of luck with your project! Keep us informed of your progress!
Oops. Will fix. Fixed.
Could consider starting with the FOSS (GPLv3, CC BY-SA) Nitrokey Storage (an UC3A3256S in BGA)
The BGA is 144 ball 0.8mm pitch; it's on a 4 layer PCB.
Nitrokey | Secure your digital life
Made in Berlin, Assembled in Berlin
Nitrokey
https://www.nitrokey.com/
https://www.nitrokey.com/news/2016/nitrokey-storage-available
https://github.com/Nitrokey/nitrokey-storage-hardware
https://github.com/Nitrokey/nitrokey-storage-firmware
If one wants to move away from MPLAB X and XC32 then PlatformIO may be considered.
Imagination Technologies lists several compilers and an IDE that may work for PIC32.
http://www.microchip.com/mplab/mplab-x-ide
http://www.microchip.com/mplab/compilers
http://docs.platformio.org/en/latest/platforms/microchippic32.html
http://docs.platformio.org/en/latest/ide.html
https://community.imgtec.com/developers/mips/tools/compilers/
I'll have to look into all the possibilities (AVR32, PIC32 and ARM) for the next version of the project, but all of those take us away from XMega, and are probably off-topic here.
