[TUT] [C] GCC and the PROGMEM Attribute
204 posts / 0 new
Pages
I made this table illustrating the complexity and lack of "one-to-one" mapping between PC and AVR memory types. I'm sure it does not cover everything, and might be wrong in details. See it as an illustration rather than an absolute truth..
Memory type       Volatile  Speed[1] PC                                     AVR
                            R   W
RAM               Yes       F   F    * Program code when executing
                                     * Data for programs while running      * Data for programs while running
Hard disk         No        S   S    * Permanent program code storage       * n/a [2]
                                       (must be loaded into RAM to be
                                        executed)
                                     * Permanent data storage
                                       (e.g. store data between executions
                                       i.e. when program is not running)
Flash             No        F   S    * n/a [4]                             * Program code permanent storage, and
        is executed from here
EEPROM            No        F   S    * n/a [5]                              * Low volume read and write data
        i.e. when AVR is not powered)
External          No        S   S    * As hard disk above                   * High(er) volume read and write data
Non-volatile        (e.g. store data between executions
Memory [3]                 			                              i.e. when AVR is not powered)
        Possibly for needing moveable/detachable
        memory, or just for high volumes
[1] R - Read, W - Write, F - Fast, S - Slow
[2] While technically possible attaching a "classical" hard disk (SATA/ESATA)
    to an AVR is complex and in most all cases a memory card is more fitting
    and definitively easier to do
[3] Memory cards, USB sticks/drives
[4] I'm avoiding a somewhat complex discussion on PC BIOS storage by simply ignoring it and
    saying n/a while it might not be true :-)
[5] It's possible (or even likely?) that BIOS Setup data is stored in EEPROM on a PC
I managed to solve my problem gracefuly!:_
const char PROGMEM ErrorArray1[] = "testa";
const char PROGMEM ErrorArray2[] = "testaaa";
const char PROGMEM ErrorArray3[] = "test";
const char PROGMEM ErrorArray4[] = "test";
const char PROGMEM ErrorArray5[] = "testdddddd";
const char PROGMEM ErrorArray6[] = "test";
const char PROGMEM ErrorArray7[] = "test";
PGM_P const ErrorArray8[][3] PROGMEM = {{ErrorArray1,ErrorArray2},{ErrorArray3,ErrorArray4},{ErrorArray5,ErrorArray6,ErrorArray7}};
AND a 3 multi array of pointers and the 4th array being char array
    PGM_P const ErrorArray8[][2][3] PROGMEM = {{{ErrorArray1,ErrorArray2},{ErrorArray3,ErrorArray4}},{{ErrorArray5,ErrorArray6,ErrorArray7}}};
Pages
