Flash writing breaking after one write + influenced by breakpoints
3 posts / 0 new
I have a program where 3 Flash pages are being written (4 if you include the userpage) in sequence, because the data doesn't fit in one page.
When I start the MCU and run it, everything seems to be written correctly to flash.
But if I want to clear and overwrite it, the program fails to do so.
There is no error showing up, no exception, nothing that would indicate a failure. The data is simply not re-written in flash (checked with atmel studio debugger).
I'm also fully aware, that with a write operation, only ones can be turned to zeroes and not the other way around. (I'm always calling the clearing command to restore the 0xff .... state.)
After a restart it works again for exacly 1 page written. The passed address is correct I verified that, I'm not violating reserved flash or something like that.
Any ideas why it's failing? What could I do?
A hint may be, that, when I put a breakpoint somewhere before the write command, it fails completely and doesn't even write once (race condition?).
This is the relevant code:
Own code:
void writeNormalFlashPage(uint32_t*data, uint16_t wordcount, uint32_t destinationAddr)
    flashc_clear_page_buffer();
    uint32_t *psrc, *pdest ;
    uint8_t timeout = 0;
    volatile uint32_t dAC = destinationAddr;
    psrc = (void*) (&(data[0]));
    pdest = (void*) destinationAddr ;
    while (wordcount--)
        *pdest++ = *psrc++ ;
    while(!flashc_erase_page(dAC/512,true) && timeout < 250)
        timeout++;
    if(timeout >= 250)
        return;
    flashc_write_page(dAC/512);        // transfer all data from page buffer to flash
    while(!flashc_is_ready());
void KMS_FLASH_saveSettingsFileToFlash(uint32_t*settingsFile, uint16_t fileLen)
    // userpage
    WriteUserPageFlash(settingsFile, 7);
    // FSlot1
    writeNormalFlashPage(&(settingsFile[7]), 72, FLASH_FilterSlot0);
    // FSlot2
    writeNormalFlashPage(settingsFile + 79, 72, FLASH_FilterSlot1);    // + 79
    // FSlot3
    writeNormalFlashPage(settingsFile + 151, 72, FLASH_FilterSlot2); // + 151
ASF:
void flashc_write_page(int page_number)
    flashc_issue_command(AVR32_FLASHC_FCMD_CMD_WP, page_number);
[insert smart signature here]
There might be a side-effect problem in your WriteUserPageFlash(,)
"After a restart it works again for exacly 1 page written." Does that "1 page" refer to the user-page ? or to whatever the FLASH_FilterSlot0 page-number is ?
flashc_erase_page(,) performs a flashc_issue_command(,) which will wait until the command has completed, therefore there should not be any need to have retries on the erase-page operation.
If flashc_erase_page(,) fails you can check why it failed with flashc_is_lock_error() and flashc_is_programming_error()
What kind of side-effect problem are you thinking of?
The flashc_erase_page is returning a bool and has the option to check if the command was successful, thats what I'm using, just to be sure.
But nevertheless, flashc_erase_page(,) never fails (I concluded that, because the timer variable is never touched).
UPDATE: I did a small test and I wrote something wrong before: The function KMS_FLASH_saveSettingsFileToFlash(,) is calling writeNormalFlashPage multiple times and each is executed successfully! But when I call KMS_FLASH_saveSettingsFileToFlash(,) a second time, it doesn't do anything, although data has changed.
Also, all methods cease to function if a breakpoint is hit anywhere prior to the Flash function calls.
Im trying to find out what diffrences are being made to the flash registers between two writes.
