Newbie: custom programming tool definition
13 posts / 0 new
Good day to all,
Im new to Atmel Studio and bough an Atmel SAM V71 Explained Ultra evaluation board and installed the Atmel Studio (version 7.0.1188) on my Windows Machine.
I installed the EDBG Virtual Com port driver and when I go to the Tools->Device Programming (select the EDBG tool)->Memories i can program and verify that the image has been successfully programmed into the board flash.
However, when I try to debug or run an application, the studio complains about the need to select a programmer. It opens a new tab and in the Tool->"Selected debugger/programmer" I select the "Custom Programming Tool" (which is the only option available). When I try to run the application again it complains that the custom programming tool has not been defined. My question is: what should I place in the "command" of the custom programming tool? Or is there a default programming tool that somehow Atmel Studio is not giving me?
I do not have an installed programmer and was hoping that Atmel Studio provided this programmer.
Thank you in advance and kind regards,
Manuel
This basically means that you have selected the wrong device in the project. The EDBG reports to Atmel Studio what device is on the board, so that Atmel Studio can filter out EDBGs that do not 'fit' with the project.
:: Morten
Thanks meolsen for the reply.
I don't know if it helps, but when I do the "Tools->Device Programming" and select the EDBG tool the Atmel Studio automatically selects the ATSAMV71Q21B device (which is correct) in the SWD interface.
I've tried to create a new project for a ATMEL Start web and when I exported the project and opened it in Atmel Studio it complained with the following error:
"Following component versions are not installed in your PC.
 - Name: Device Startup, Version: 2.1.0 (Latest installed: 2.0.0)
Do you want to create the project with the Latest installed version of the above component(s)?"
I've tried to find a place where to download the new version of the Device Startup but didn't find any. Is it an option inside the Atmel Studio?
Is this issue related to problem you said before? (note: i did not select the device in the project, it appears to be selected automatically)
Kind regards,
Manuel
Tools->device pack manager is used to update.
:: Morten
Thanks again for the reply,
I've been searching for the device pack manager option but could not find it.
I found the link that shows the option you are referring to:
http://www.atmel.com/webdoc/GUID...
but my "Tools" only has the following options:
Do you know how to make this option available?
Kind regards,
Manuel
Nevermind, I try to run with admin privileges and the option now appears.
Still have to figure out how to update but one step at a time
Tools->Select Profile->Choose Advanced
:: Morten
Were you able to the startup code version figured out?  I am having the same trouble.
Kevin
I ended up using the atprogram application to program the board. Have not used any debugger though.
Kind regards,
Manuel
Hi All,
I am working on ATSAMV71Q21B board and I finding issue in debugging the example program.
How to resolve this issue ? Why the device is detected in Programming /Debugger mode ? I am using windows 10 PC.
So which programmer or debugger do you have?
Hi JS,
I appreciate your quick response. I am using the ATSAMV71-XULT (B) eval kit which comes with a fully integrated debugger . So I connect an USB (micro)cable to Debug USB port in the Board to my PC. So the problem is why the device is not getting detected  for debugging the example code.
Solved
Had also the ATSAMV7-XULT and got the same problem  ... selected ATSAMV71Q21B instead of the other ATSAMV71Q that did not work.
Best regards
Jørgen
