Xbee Interface
8 posts / 0 new
Hi, I am new to AVR kindly anyone provide me tutorial and code on interfacing xbee with atmega32
The Xbee interface is a simple usart. Connext the Tx pin of your AVR to the RX pin of the Xbee. Connect the RX pin of the AVR to the TX pin of the Xbee. Thats pretty much it.
The xbee only runs on 3.3v so you will need to run the AVR on the same voltage or use level translators.
The Xbee modules out of the box are set up as broadcast mode so you should be able to get going right away.
Hari_22 wrote:
Hi, I am new to AVR
Just to AVR, or also to microcontrollers in general?
And programming in general?
For getting started with AVR  (or, in fact, any microcontroller) programming, see: http://www.avrfreaks.net/comment...
The best place to go for that would be to look for Arduino Projects & Tutorials
For information & support on XBee, see: https://www.digi.com/lp/xbee
Thank you.
whether at first we have to configure xbee using terminal. if i am using only two xbees i.e one as transmitter and one as receiver how to configure it.
Thank you,
I am using AVR studio 4.0 to program and gcc compiler. As I referred Its simple usart connection from above reply.
If you have purchased an Xbee kit which comes with two modules. Two Grove boards and the usb cables you would use the XCTU software to configure them
But the units themselves default in broadcast mode out of the box so there is no need to configure anything to get a link going. All you need is Vcc Gnd Tx and Rx
Hello Hari,
I can help you with this. I can provide you source ie. ElectronicWings where you can find it. Detail's with whole explanation, code, Video step by step is provided. I hope it will help you.
And if it help's you please let me know.
Well, that's nice of you - but about 6 months too late!
