taking a register bit as a source for XCL module instead of a pin
5 posts / 0 new
I am trying to implement XOR functionality through an XCL (LUT option) module. I did it by using two pins as input in ATXMEGA32E5. But is there a way to do it through a register/internal signal without using external pin?
In short,  is there a workaround that XCL will read a bit from a general register as an input (instead of an external pin) for performing XOR functionality?
maar
Per the XMEGA E family manual: Input sources: From external pins or the event system
So, if your "bit from a general register" can trigger an event, then this can be done.
Greg Muth
Portland, OR, US
Xplained Boards mostly
Yeah I figured this out. Used Strobe and data register to manually trigger and write event through CH7. But thanks for the reply.
But what do you mean by bit from a general register? can I trigger event by writing to a general purpose register address space and making it event source?
maar
I was quoting you from your original post, so, what do you mean by bit from a general register?
Greg Muth
Portland, OR, US
I was thinking of writing to a general location or general purpose register and using that as an input for XCL. But I guess it has to be done by writing in STROBE and DATA register only.
maar
