AT32UC3C0512C STARTUP GUIDE BASIC NEEDED.
13 posts / 0 new
Hi, I have AT32UC3C0512C microcontroller. i want to start with basic LED blinking and Port READ/ WRITE program.
I am totally new to UC3, 32 bit AVR microcontroller. i am looking for a help in following things.
1) Basic oscillator circuit.
2) How to LOAD program and which tool and additional circuit i need to load the code.
3) Basic code for LED blinking and PORT READ/WRITE.
4) any other additional circuit needed to operate the microcontroller.
5) is there any additional circuit needed to LOAD the code into Microcontroller.
can i use atmel studio 5 to design a code.
Thanks in advance.
Regards:
EJ
You have the chip only, not any dev kit? I prefer getting a dev kit first so I don't need to (or shouldn't need to) worry about H/W problems before getting the software to some sort of a working state.
Several examples are available in ASF. Just click New > Example Project in Atmel Studio 7, and enter UC3C in the search box to see compatible ones only. They work pretty much out-of-the-box on the UC3C-EK dev board at least.
I use Atmel ICE for flashing and debugging. It's one of the cheaper options but works just fine.
Any specific reason for choosing this chip - particularly in the light of: http://www.avrfreaks.net/comment...
Anyhow, as Handsome Jack suggested, for any microcontroller it really is the best idea to start with a proper development board or kit.
Once you have gained some basic experience with the kit, then - and only then - move on to creating your own boards.
Some beginner's getting started tips here: http://www.avrfreaks.net/comment...
Typically, chip manufacturers have a Product Page on their website where they collect together all the support materials for a particular product (or family).
The easiest way to find it is usually just to put the part number into Google.
For the AT32UC3C0512C, that gets us to:
http://www.microchip.com/wwwprod...
Where you will see:
  • Datasheet
  • Documentation - which includes a huge list of Application Notes, Quick Start Guides, etc
  • Development tools
  • etc
You should find answers to all your questions in there.
This should be your first port of call when starting with any new chip.
#ProductPage
i want to develop my own borad. so i do not want to buy any ready made dev board.
i am new to AVR32 controller it does not mean i am new to Hardware and other controller. i am working in Analog field and have developed several boards.
i worked on 8051, and AVR 8 bit microcontroller.
i am looking for a help. if anyone has done it in past kindly answer my problems.
Thanks in advance.
Regards:
EJ
Datasheet does not solve all problems, there are many Practical aspects. only person with great experience and failure can understand it.
for example in datasheet i could not found how to do In system programming without using programmer like AVR dragon  etc... Crystal oscillator basic circuit shown but the value i fouiund is maximum 16 Mhz. how to work it for 50 MHz. is it through PLL or External. ?? What are the values for decoupling and series resistor if i am using any port pins.
I thought i might get something else than datasheet based on the experience of forum people. but i failed wrong.
Regards:
EJ
Again, there is a lot more than just the datasheet on the Product Page.
There are many Application Notes - they should answer your questions.
eg,
AN_8128 - AVR186: Best practices for the PCB layout of Oscillators
Page not found
We're sorry! The page is not available. Please visit the Home page.
Regards:
EJ
Hmm ... it works for me!
Is that from clicking the link in my post above, or direct from the Product Page ?
(both work for me)
no not working. anyway can u tell me how to do ISP for UC3 or which programmer works well i have atmel studio 7 can i use AVRISP MKII programmer or AVR JTAG ICE PROGRAMMER & DEBUGGER USB.
can i attached 40 Mhz crystal externally as shown  in datasheet. in datasheet it showws 66 Mhz Clock frequency.
Regards:
EJ
AFAIK, both AVR ISP mk II (for AVR8 only) and AVR JTAG ICE (for AVR8 and AVR32) have been discontinued and replaced by Atmel ICE http://www.atmel.com/tools/atatm.... But if you can still find an AVR JTAG ICE, it works fine, too.
The product page http://www.microchip.com/wwwprod... works fine for me. There's a huge pile of documentation there.
The link Andy gave...
http://www.microchip.com//wwwApp...
works here. (Firefox).
I just tried the links again, and got "page not found" twice - but it worked on the 3rd try (Chrome).
