Port.Pin as function parameter.
3 posts / 0 new
let me describe my problem. I have following piece of code written:
typedef struct{
    uint8_t p0:1;
    uint8_t p1:1;
    uint8_t p2:1;
    uint8_t p3:1;
    uint8_t p4:1;
    uint8_t p5:1;
    uint8_t p6:1;
    uint8_t p7:1;
} IO;
#define PORT_B_DDR (*(volatile IO*)&DDRB)
#define PORT_B  (*(volatile IO*)&PORTB)
#define PORT_B_PIN (*(volatile IO*)&PINB)
#define SPI0_CAN_CS   PORT_B.p4
#define SPI0_CAN_CS_DDR  PORT_B_DDR.p4
#define SPI0_CAN_CS_PIN  PORT_B_PIN.p4
How can I pass SPI_CAN_CS as a function parameter. What type is it ?
Any help appreciated :)
Any integer type will accept it.
Taking its address is a no-no.
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
To be absolutely clear, skeeve's response implies that you can use pass-by-value semantics only.
Pass-by-reference semantics (and, therefore, the ability for the callee to modify the pin's state via the function parameter) will not work.
