Tiny1634 Timer1 issue
13 posts / 0 new
Been trying to get the timer to blink an led - simple stuff, but I am obviously doing something wrong.  I have it running as a free running timer with TOP being 0xFF.  I have COM1B1:0 set for clear on match, in the Overflow ISR the pin is set, the port pin DDR set properly, but the pin stays low.  If I set the COM bits to toggle, and remove the ISR it works just fine, Interrupts are enabled, as is the global enable.  From the datasheet I should be able to run this without the need for a compare match interrupt
The idea is to create a 'pulse' of about an eighth of a second.  Right now I am trying to get half second on/off.
ISR(TIM1_OVF_vect)
	PORTA = PORTA | 0x40;
void avr_init(void)
// Port A initialization
	// Pull-up initialization
	PUEA=(0<<PUEA7) | (0<<PUEA6) | (0<<PUEA5) | (0<<PUEA4) | (0<<PUEA3) | (0<<PUEA2) | (0<<PUEA1) | (0<<PUEA0);
	// Function: Bit7=In Bit6=In Bit5=Out Bit4=In Bit3=In Bit2=In Bit1=In Bit0=In
	DDRA=(0<<DDRA7) | (1<<DDRA6) | (0<<DDRA5) | (0<<DDRA4) | (0<<DDRA3) | (0<<DDRA2) | (0<<DDRA1) | (0<<DDRA0);
	// State: Bit7=T Bit6=T Bit5=0 Bit4=T Bit3=T Bit2=T Bit1=T Bit0=T
	PORTA=(0<<PORTA7) | (0<<PORTA6) | (0<<PORTA5) | (0<<PORTA4) | (0<<PORTA3) | (0<<PORTA2) | (0<<PORTA1) | (0<<PORTA0);
	// Timer/Counter 1 initialization
	// Clock source: System Clock
	// Clock value: 31.250 kHz
	// Mode: Normal top=0xFFFF
	// OC1A output: Disconnected
	// OC1B output: Clear on compare match
	// Noise Canceler: Off
	// Input Capture on Falling Edge
	// Timer Period: 1 s
	// Output Pulse(s):
	// OC1B Period: 1 s
	// Timer1 Overflow Interrupt: On
	// Input Capture Interrupt: Off
	// Compare A Match Interrupt: Off
	// Compare B Match Interrupt: Off
	TCCR1A=(0<<COM1A1) | (0<<COM1A0) | (1<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
	TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (1<<CS12) | (0<<CS11) | (0<<CS10);
	TCNT1H=0x00;
	TCNT1L=0x00;
	ICR1H=0x00;
	ICR1L=0x00;
	OCR1AH=0x00;
	OCR1AL=0x00;
	OCR1BH=0x80;
	OCR1BL=0x00;
	// Timer(s)/Counter(s) Interrupt(s) initialization
	TIMSK=(1<<TOIE1) | (0<<OCIE1A) | (0<<OCIE1B) | (0<<ICIE1) | (0<<OCIE0B) | (0<<TOIE0) | (0<<OCIE0A);
	avr_init();
	sei();
I am aware that I could use PWM or CTC mode, but I would prefer to use this for the application.  PLus this is just bugging the crud outta me now.
When COMxYz bits are set, then the PORT output is disabled.
The mode you have selected is (generally) to be used with one of the "Phase Correct" counter modes.
Any reason why this need to be a sticky?
No reason at all... I hit the wrong radio button in haste
Not so sure about that....From  the datasheet:
I have the DDR for PA6 set for output.
What I was trying to say is that the PORTA = PORTA | 0x40; inside the ISR will have no effect because:
If one or both of the COM1B[1:0] bit are written to one, the OC1B output overrides the
normal port functionality of the I/O pin it is connected to.
If the intent is to toggle bit 6 in PORTA in the ISR, shouldn't that be;
      PORTA ^= 0x40;
I'm not that familiar with "C", but your code turns bit on and then never off again.
Because the COM1B[1:0] bits are configured to "Clear on Compare Match", there is nothing to set the bit high, and "normal port functionality" is disabled.
Ahh, ok. That makes sense. To then how to clear the pin then when the timer overflows? It would seem odd there is no way other than resetting the AVR to clear the pin.
Edit: only way I see to clear the pin would be to change the pin to normal mode, clear it, and then change it back to being controlled by the timer.
Set the COM-bits and do a "Force Output Compare".
Stefan Ernst
Won't work. The timer has its own stored output state, so "change it back to being controlled by the timer" also means to change back to the last timer controlled output state.
Stefan Ernst
Thanks. Will try it later and report back
What do you actually want to achieve?   2.097s period with 1s on and 1s off ?
Or do you want 0.125s on and 1.875s off ?
Or 0.125s on and 0.875s off ?
The Tiny1634 should work exactly like any other AVR 16-bit Timer1.  i.e. set a PWM mode and duty cycle.
It should work even with "unusual" PWM periods.
PWM#14 is probably the easiest one to use.
If you give real-life numbers for your period,  duty-cycle and polarity,   I will try it with the CodeWizard.
Normally,  I would just calculate in the program statements.
Edit.  Just tried it in the CodeWizard.   It is painful to set ICR1 and OCR1B manually.   But at least it gives you instant feedback for period and pulse width.
Far easier to just calculate manually.
