Is there any difference between power-on, watchdog, and external resets?
24 posts / 0 new
I have a very strange problem where some code which triggers a watchdog reset and then jumps to the boot loader only works if an external reset has not happened since the last power-on reset. HWB is tied to GND.
Memory contents can be retained when the power remains ...
I know that, but for some reason the external resets keep working while my code fails.
the fact that data persists can cause trouble when you have uninitialised vatiables
can also show-up other bugs in your could which just happen to "work" by "luck" after a power cycle, but not other resets...
The MCU status register keeps a record of what resets have happened.  Maybe the bootloader checks this.
It does check MCUSR, but my code clears it during startup.
Are you sure you clear the bits?  According to the manual they are cleared by writing zero bits.  I believe that's backwards from the Xmega.
A debugger would tell you where the bootloader is going wrong.  I don't know just how to go about debugging the bootloader.
Yes, here's what I do.
MCUSR = 0;
I now have a new but very similar problem, where my application will only run after a power-on reset. It will not run if the boot loader calls it. Does anyone have any ideas?
Not enough info to go on.
Also do you have any diagnostic aids like a debugger?
and I have a baffling problem that is the opposite of that. Here is my problem that I would appreciate any clues about fixing:
I am using ATMEGA1284 and JTAG ICE MKII.  I am getting on pretty fine programming two different projects in ATMEL assembler.
The first project board talks to a PC via the AVR UART, controls relays, flashes LEDs, drives steppermotors and measures voltages and currents all very nicely and "at the same time" using an RTOS.
It works under the JTAG ICE MKII debugger, and also without the debugger, doing power-up reset all on its own fine.
The second project uses an almost identical circuit and almost identical software, and same Xtal.
The difference is, it uses the SPI port to drive things instead of bit bashing.
This project also works fine when I download code with JTAG ICE MKII and set it running.
It continues to run fine after I unplug the JTAG dongle without first removing power form the board.
But if I then remove power from the board, it will not power-up restart on its own.
So here is what I have suspected and tried:
(1) Changed the processor. All chips do the same
(2) Tried checking "Use Exrernal Reset" and also not checking it. No difference.
(3) Tried all settings of Brown Out Detector fuses. No difference
(4) Tried different settings of Xtal fuses. No difference
(5) Tried changing external reset delay (which is provided by a TI TPL9201 chip) between 0 and 8mS. No difference.
(6) Questioned whether the SPIEN fuses chould be checked or unchecked. Since I was using the SPI port to control hardware,
     I thought it should be checked. However, the SPI port works fine without this fuse being checked, as I am setting port bit usage in start-up code.
      So I am now thinking that the SPIEN fuse is only for when you want to do debugging via the SPI port instead of JTAG. Can't see any documentation to that effect.
      I read somewhere that if the SPI port clock in particular is toggled while holding RESET low, that can cause corruption. I guess that is only if SPIEN fuse is checked?
      Anyway, that is not happening.
(7) Suspect that IVSEL is not getting reset back to 0 to put the interrupt vectors back to the start instead of into the boot zone.
     So, I am trying to monitor MCUCR that contains the IVSEL and IVE bits while single stepping at start-up.
     It is not clear where I should be looking at this register: Is it address 35 or 55 in data mapped I/O?  So I give both values:
      data mapped I/O address hex35 containes 0 at start up under JTAG. Data mapped I/O address hex 55 contains  17
      Now I single step through the power-up initialization routine, setting port pin data directions etc, until I get to a piece of code that will set IRAM
      addresses $0100  to $0110 to $FF in the following loop:
                   SER R16                        ; SET R16 TO $FF
                   LDI R17,  NUMBER_OF_PROCESSES         ; = 16 DECIMAL
QLOOP1:    ST Z+,R16
                   DEC R17
                   BRNE QLOOP1
Z = (R31,R30) is  set to $0100  upon entry   and R17  to $10
I step though this to BRNE QLOOP1 and upon executing that it returns to QLOOP 1 as it should first time round,
BUT, I notice data mapped I/O register has changed to $01 simulatneously with executing BRNE
 That means IVE is now set to 1 !!  Who did that ? Some little hardware wrinkle that only works when the JTAGEN fuse is set?
Why did it pick then to do it?  (These things need to be documented please!)
Now I do 4 more steps and data mapped I/O register 35 becomes 07. That means IVE and IVSEL are now 1.
That seems to be executing the protocol that you have to set one first then set the other within 4 cycles to switch the
interrupt vectors to the boot zone.
That is as much as I know, but one of things that some expert may be able to tell me is what is the AVR sensing that made it
do that then, that it would not be sensing if I was doing power-up reset without JTAG plugged in?
Are the JTAG pins expected to be at any particular potential (via pull downs or pull ups) when JTAG is not plugged in to prevent
switching the interrupt vectors to the boot zone?
Paul Dent
PaulWDent wrote:
BUT, I notice data mapped I/O register has changed to $01 simulatneously with executing BRNE That means IVE is now set to 1 !!
You lost me.  Do you mean IVCE instead of IVE?
And "interesting" how your your loop apparently affects 0x55.  And how did you find that anyway?  The bit turned color when stepping?
PaulWDent
Forget about fiddling with the spi for the moment & all the confusion factors between SPI/Jtag...does your chip even come out of reset & the boot area and run normal code?  Set  the DDRx for a port pin & then toggle the pin it endlessly (your short program will do NOTHING else)....does at least that power up & run?  Is it twiddling at the expected freq (so you know the correct clock setting is also as expected).  If it makes it to this code & runs properly, then a lot of options must be set properly & functioning. Once you know that is working, you can investigate your spi issue & whether you can actually send data over it.
If you have a bootloader relocating interrupts to the boot section then you need to make sure your main program code changes your vectors back to the main program.
But you really should have the bootloader RESET to your main program via a watchdog reset by doing checks for the reset cause.
This will make sure all registers are cleared to a know state before you continue with the main program set-up.
+1
In fact why is the bootloader even using interrupts anyway? You make the code hugely less complicated (and hence easier to test and debug) if you stick to polling actions in the botloader. Given that it's a piece of software that probably only runs about once avery 3 to 6 months for 1..2 minutes it's not worth the effort to do a load of "fancy stuff" that would require the use of interrupts.
At the end of the day the only piece of software in the system that MUST work is the bootloader (as it's the only bit you cannot replace) so the essence of it is to keep it as simple as possible (and hence bug free).
I have lots of ideas, most of them bad.  wink
I guess what you mean is the application won't run if it has just been put into flash by the bootloader.  I've had that problem myself but I don't remember the solution.  I've also had the opposite problem where the application would run only if it was just flashed.
If the bootloader uses interrupts, it should disable the individual interrupts and the interrupt priority levels and the global interrupt.  Not doing so can obviously cause problems.
It may use different clocks than the application is using, but no problems that might cause come to mind. It also uses various devices and sets them up differently than the application does.
Your application may start running and get hung up is initialization.  Having a JTAG debugger or whatever debugger could come in handy.  Some debuggerless folks put in code that turns on a LED.  And then moving the turnon code further into the initialization until the led no longer gets turned on.
It seems to me, putting the vectors back should be done by the bootloader.
Yes, maybe, but I'd want to know if I got watchdog resets because my software or hardware was bad.  This muddies the waters.
What would be nice is to have software resets for this.  Xmegas have one.  I want two.  One for my "deluxe" application wink so I can get to the bootloader from the application without having to hold down two buttons on the board.  The other software reset would be used by the bootloader to get to the application.
So you set a flag in RAM when you do a deliberate reset, and check that - along with the Reset Cause - when the code restarts.
Thus you can distinguish a "fault" watchdog reset from a "deliberate" watchdog reset...
Wouldn't the bootloader and the application have to use the same RAM location?  How would you do that?   It might be easier to use EEPROM.
Yes.
Indeed - but bootloader and application would still have to "agree" on what location within the EEPROM to use ...
I don't use interrupts in the bootloader but if I did (and didn't use a wd reset) I might think about the best place to restore the vectors. Bootloader section does make sense but locating the vector change in the program might be a good reminder that you that you're using interrupts in the bootloader.
Theoretically, you can tell whether a watchdog reset has happened from the bootloader (which you can assume is "bug free", right?) or the application.  A couple people have posted possible solutions to this for Optiboot.
In practice, I think it ends up being a bit more complicated (and I haven't yet "accepted" any of the Optiboot proposals.)  It's similar to the "double-reset" boot procedure that a couple of SAMD boards have implemented (one reset - start the bootloader with it's normal (short) timeout.  An additional reset during that short timeout - lengthen/eliminate the timeout.)
You can still use the watchdog normally in your program since the bootloader will always jump to the program on wd reset. That's not really a problem is it? What would you have the bootloader do if it did hit a wd timeout? If the bootloader did hang (and it shouldn't since it should be rock solid code) then you could just do another bl reset manually.
Yes, the xmega sw reset is a nice feature, xmega's do have some excellent features.
I don't typically use any buttons to start a bl, I like to use a 2 second time-out at boot-up and hit an ESCAPE key via uart to enter the bl.
