Solved: Array passed to function
13 posts / 0 new
I'm trying to pass an array to a function, where the array is modified in place.  I'm using AS7.  I keep getting the compiler error "called object 'Voltages' is not a function or function pointer", with the error cursor pointing to each 'Voltage(i)'
Here's my function and its caller:
void CalAnalog(){
OCR0A = 192;
	while(UDR0 != 'x'){
		ReadVoltages(Voltages);
		printf("Ch1=%2.2f,\tCh2=%2.2f,\tCh3=%2.2f\n\n", Voltages(0), Voltages(1), Voltages(2));
	_delay_ms(1000);
float ReadVoltages(float *Voltages){
	Voltages(0) = RDiv*ReadADC(0, 16);
	Voltages(1) = RDiv*ReadADC(1, 16);
	Voltages(2) = RDiv*ReadADC(2, 16);
I declared earlier:
float Voltages[3];
float ReadVoltages(float Voltages);
Any idea what I'm doing wrong? thanks, paul
Which line does the error statement point to?
Wrong type of brackets!
Array: Voltages[0]
Function: Voltages(0)
Solution - use square brackets for array.
The error points to the printf statement and all 3 Voltages(i) =
duh! Knew it had to be something stupid! thanks much, Kartman! paul
Funnily enough, the same thing came up only the other day:
http://www.avrfreaks.net/comment...
paulofelora wrote:
I declared earlier:
but then you defined it as:
(which is the correct interface). Surely the compiler complained about this??
(that is the lack of '*' in the declaration).
Note that
is equivalent to
float ReadVoltages( float Voltages[] ){
but the latter emphasises that the parameter is intended to be array of floats - rather than a pointer to a single float.
EDIT:
Just to clarify, as following replies have pointed out, that I am not saying that an array declaration is universally equivalent to a pointer declaration.
I am just talking about the specific case of a function formal parameter.
http://c-faq.com/aryptr/aryptrpa...
awneil wrote:
is equivalent to
Someone is going to be along in a minute to remind us that this is technically not true.
(though I know what you mean!)
I think it is true in this particular context (ie, as a function parameter) ?
clawson wrote:
awneil wrote:
is equivalent to
An oldie but goodie.  Indeed, when learning, the tutor will say "an array is a pointer and a pointer is an array".  As one learns, "...except when it is not" is added.
For most vanilla work -- e.g. a character string array of char -- the axiom works out pretty well.
I didn't say that the array is equivalent to the pointer - I said that the two function signatures are equivalent.
I'll update my original post to be clear - just in case someone takes it out of context, and doesn't read the replies ...
But I [almost] did.
