uint16_t variable problem
10 posts / 0 new
Hi there guys,
would someone know why this works
uint32_t time_int = 0;
time=actual_time = 98000;
lcd_write(time_int);
also this works
time_int=actual_time = 15*19600;
but this does NOT!!!
time_int=actual_time = (((hour_temp1*60)*60)+(minute_temp1*60))+second_temp1;
this also not working
time_int=actual_time = ((hour_temp1*60)*60)+(minute_temp1*60)+second_temp1;
this output only 11822
have been about this all day...
here is the all code
uint8_t hour_temp1,minute_temp1,second_temp1=0;
	uint8_t hour_temp2,minute_temp2,second_temp2=0;
	uint32_t time1,time2,actual_time=0;
	//Here I was just trying playing arroud by trying to make separate the variables
	hour_temp1 = data.get_hour();
	minute_temp1 = data.get_minute();
	second_temp1 = data.get_second();
	uint32_t h = (data.get_hour()*60)*60;
	uint16_t m = (data.get_minute()*60);
	actual_time = h+m+data.get_second();
if (data.get_humidifier_function_in_use()){
        if (data.get_humidifier_timer_on()){
            data.get_humidifier_time_from(hour_temp,minute_temp,second_temp);
            time1 = (((hour_temp*60)*60)+(minute_temp*60))+second_temp;
            data.get_humidifier_time_to(hour_temp,minute_temp,second_temp);
            time2 = (((hour_temp*60)*60)+(minute_temp*60))+second_temp;
            actual_time = (((hour_temp*60)*60)+(minute_temp*60))+second_temp;
            if((actual_time > time1)&&(actual_time<time2)){
                if (data.get_humidifier1() < data.get_room_humidity() ){
                    data.set_humidifier_on(true);
                }else{
                    data.set_humidifier_on(false);
            }else{data.set_humidifier_on(false);}
        }else
            }else{
thank you very much
hlinskoelektrikar wrote:
also this works
Hard to believe.
With what values of hour_temp1, minute_temp1, and second_temp1?
Most likely an overflow. Keep in mind: the type of the variable on the left side of an assignment does not influence the way the evaluation is done on the right side. In this case the whole right side is calculated in int.
Stefan Ernst
Integer overflow.
'C' will do integer calculations as 'int' by default, (or wider if there is a 'wider' value in the calculation).
Change hour_temp1 minute_temp1 second_temp1 to uint32_t (or use typecasts in the formula)
Also suffix the constants with ul. Eg 60ul will coax them to be 32 bits. This may also force the compiler to do 32bit calcs rather than 16. As mike hints, it is about C's promotion rules.
Hi yes this on
just my mistake it was this way of course :-)
time_int = 15*19600;
mikech wrote:
Integer overflow.
Your solution sound ok but when I am trying this, I get problem that compiler says no  function get_heating_time_from to called with uint32 as parameters of this functions are uit8
even if I try typecast.
But hold on!!! This looks write its numbers are now arroung 70200 Iam going to test it more, will let you know....
COOOOOOL THATS IT!!!!! Thank you :-)
There are only 24*60*60 = 86400 seconds in any earth day. So what is this 15*19600 = 294000 seconds thing?
I just tested if its calculating right way and if I get right value but this value was have not do anything with time...
