CH340G IC vendor.....
22 posts / 0 new
Finishing the design phase of a small job and the USB port is the last part to put together.  I have been using some CH340G USB/TTL modules, and they work great if I load the driver manually, or wait 15 minutes for windows to find it online from goodness knows where.  I have also used the FTDI with the same results, although Windows finds the drivers a little faster.
I am having a bit of a difficult time finding a vendor for the CH340G IC that is not selling beads, dresses and other items.  While this design fro the moment is a 5 piece order, if the client likes the design enough it could/will mean more orders so I really cannot afford to screw this up.
The other issue is that the USB needs to work with both a MAC and a PC which gives the FTDI an edge as I have never tested a CH340G IC on a MAC so I have nothing to compare.
Essentially the USB needs to not require the end user to have to search for drivers and manually install if I can help it.  I also though am looking at my bottom line and while the FTDI is not terribly expensive at $2.38 each, this number can add up.
Any recommendations on a vendor?  Any experience with the CH340G and a MAC?
* Added the 'G' suffix for accuracy. Ross. *
jgmdesign wrote:
..  I also though am looking at my bottom line and while the FTDI is not terribly expensive at $2.38 each, this number can add up.
Any recommendations on a vendor?  Any experience with the CH340 and a MAC?
Why not look at the CP2102N ?  - No crystal needed.
Findchips shows that as low as $1.26 1 off ?
I think the CH340 dates from back when these parts still used a (12MHz) crystal ?
https://www.aliexpress.com/item/...
There are others also Jim. Such as...
... and
Ross...
Those prices are certainly reasonable.  Great finds.  I hadn't thought about aliexpress...I was searching alibaba and the results were more bulk quantities than I could ever use.
Who-me...
$1.26 is certainly much more reasonable than the one I was looking at, but I will have to see what it's specs are at low and high temperatures as this thing may be subjected to some extreme temps at times.
Great finds by you both, Thanks!
JIm
The data says  -40 to +85 °C, which is more extreme than the  average user can tolerate  ;)
I'd suggest the ch340 is probably not a good choice due to ongoing driver support on OSX.
FTDI it is then
I don't understand these chinese manufacturers, they don't care about western markets?
The manufacturer of the ch340 doesn't even have an english version of their website: http://www.wch.cn/
With the size of the domestic Chinese market, it is not a surprise to me. The hobbyist customers are probably more of a nuisance... even at a 1000 a day .
Likewise with Cypress.
Microchip - MCP2221 is no crystal; MCP2200 with a 12MHz resonator.
Cypress Semiconductor
USB-Serial Bridge Controller
http://www.cypress.com/products/usb-serial-bridge-controller
(Features tab)
Full-Speed USB controller with Integrated termination resistors, voltage regulator, on-chip oscillator and Flash – no external components required
Microchip Technology Inc
Microchip
USB Bridges
http://www.microchip.com/design-centers/usb/usb-hubs-and-devices/products/usb-bridges
https://learn.sparkfun.com/tutorials/sparkfun-usb-uart-breakout-cy7c65213-hookup-guide
http://www.microchip.com/wwwproducts/en/MCP2200
http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=ADM00393 (MCP2200 Breakout Module)
http://www.microchip.com/wwwproducts/en/MCP2221A
http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=ADM00559 (MCP2221 Breakout Module)
jgmdesign wrote:
FTDI it is then Jim
Use caution with the  FT_prog software if you need it... killed my keyboard TWICE, and also from my experience atmel ice tool attached to PC makes the software force close, this on windows 10 atleast.
If the USB bridge enumerates as USB HID then no drivers are needed (USB HID is a built-it part of Linux, macOS, and Windows)
If the USB bridge enumerates as USB CDC ACM then
  • Linux - no driver
  • macOS - I don't know
  • Windows 10 - no driver
  • Windows 8.1 and previous - INF and usbser.sys
Microsoft logo
Microsoft Windows USB Core Team Blog
What is new with Serial in Windows 10
by George Roussos
July 29, 2015
https://blogs.msdn.microsoft.com/usbcoreblog/2015/07/29/what-is-new-with-serial-in-windows-10/
1.   Improved Serial over USB driver support in Windows 10
In Windows 10, we added inbox support for USB CDC Abstract Control Model (ACM) compliant hardware. Usbser.sys is now installed as a compatible ID match for USB CDC compliant hardware, without requiring a 3rd party driver or inclusion via modem INFs.
Now devices that report these compatible IDs:
  • USB\Class_02&SubClass_02&Prot_01
… including popular prototyping boards like Arduinos – just work with our built-in driver.
Microchip
USB Bridges
USB to UART/SPI Bridge
  • Class 02h – USB to UART comm and I/O control
  • Class 03h – HID: I/O Control, EEPROM access
http://ww1.microchip.com/downloads/en/DeviceDoc/MCP2200_MCP2221_CDC_Mac_Readme.txt
Edit : Microchip macOS URL
From the previous sentence, I'm guessing you are looking for the module?  Or is that just the IC?
So while DigiKey and Mouser don't have any stock right now, it appears they can get them.
[found via Octopart search]
Interesting - lower highest baud, of only 460k, and no handshake lines, just TX,RX
However, it can do i2c, which could be useful, and offers gull wing packages.
Costs more than CP2102N ( which can do 3~4MBd, & comes with handshake lines )
gchapman wrote:
Cypress CY7C65211A
Better baud rates, and has UART/i2c/SPI, and CapSense, Claims 3MHz on UART, SPI, so similar to CP2102N and FTDI parts.
Much higher price than CP2102N.
There is a dual channel version, CY7C65215,  which looks cheaper than FT2232D
Less clear is if their SPI includes JTAG use (as FTDI manage).
Another player is EXAR  XR21V1410 - this one has the highest BAUD ability of any FS USB bridge I tested. You can set up to 12MBd, and it can sustain close to 9MBd rates.
This part also manages 9-bit UART modes.
Last time I checked the EXAR driver, it failed when sending a single block/file > 100k
Wow, those are low Module prices (even if they do use the ancient USB connector, likely that's virtually free in alleys in China).
I see Seeed has no stock of CH340G but they do have stocks of a $1.95 PL2303 USB to Serial (TTL)  module.
They do have stocks of a CH340T  module at $7.95, claims Supports baud rate varies from 2400bps to 115200bps.
JoniS wrote:
jgmdesign wrote:
FTDI it is then Jim
FTDI got themselves into big trouble with an aggressive attack driver, that could disable users systems without warning.
Many designers now avoid them entirely, where they can.
As you see, plenty of other choices in the USB Bridge space - many cheaper.
Who-me wrote:
[MCP2221] ... and no handshake lines, just TX,RX
UART DTS DTR would be handy to reset the MCU as DTS DTR is available via the serial driver (Linux, Windows, and likely also macOS)
In lieu of, the MCP2221 DLL can be used to toggle one GPIO (in Windows either via .NET or direct)
Who-me wrote:
[CY7C65215] Less clear is if their SPI includes JTAG use (as FTDI manage).
400KHz JTAG is in CY7C65215; instead of JTAG, CY7C65215A has RS485 and 8-pin UART.
http://www.cypress.com/part/cy7c65215-32ltxit
Edit : strikethrus
Interesting detail - I had only downloaded the '211 data, wrongly thinking the Dual would have the same features. I did see JTAG on the brochure, hence my puzzled comment...
Why only 400KHz when SPI claims 3M ? - I guess they bit-bash the JTAG to allow any number of bits ?
Also says this
"Note:  When  JTAG  is  enabled,  other  interfaces  in  the CY7C65215/CY7C65215A device cannot be used."
FTDI allow one JTAG and one UART, which is a very common FPGA Eval usage.
jgmdesign wrote:
FTDI it is then Jim
That is the decision to make. Mentioned earlier, OSX has driver hassles as does Windows. Check out this App Note for a utility you can use to change the device descriptor to something like "JMGdesign". I don't remember how I did it, but when I brought my programmer into work it was re-programmed to display my name so there would be no question as to ownership.
I will look into that for sure!
Some context for JTAG via CY7C65215 :
OpenOCD 0.10.0 release is out
January 22nd, 2017
http://openocd.org/2017/01/openocd-0-10-0-release-is-out/
JTAG Layer:
  • OpenJTAG support for Cypress CY7C65215
PIC32 has JTAG; PIC32MX is in OpenOCD.
