a warning I have not understood yet
12 posts / 0 new
Hi everybody.
int main()
    char array[2];
    array[0]='A';
    array[1]='b';
    char*p;
    p=array;
    for(int i=0;i<2;i++)
        printf("%c\n",*p);
        p++;
    return 0;
when I write a code like above for normal pc (in GCC) there is no warning. But, when I compile it in avrgcc there is a warning 'incompatible pointer type'. what is that? Any idea?
What line is it complaining about?
 p=array;
this line.
and tahn I edited p=&array[0] and there is no warning.
Is that the exact code that you are compiling?
ie, copied direct from the source file, and pasted into the forum - with no manual re-typing?
What compiler version?
Do you also get any other errors and/or warnings?
Please post the full error message - again, copy & paste.
Well apart from anything else the code is not complete as it misses the #include <stdio.h>. Anyway....
C:\SysGCC\avr\bin>type avr.c
#include <stdio.h>
int main()
    char array[2];
    array[0]='A';
    array[1]='b';
    char*p;
    p=array;
        printf("%c\n",*p);
        p++;
    return 0;
C:\SysGCC\avr\bin>avr-gcc -Wall -mmcu=atmega16 -Os avr.c -o avr.elf
C:\SysGCC\avr\bin>
Even with -Wall I cannot get a warning out of avr-gcc about this so I would like to hear more about the environment in which this is built and the command lines used etc.
Of course I *can* get it to behave similar to what the OP suggests:
C:\SysGCC\avr\bin>avr-gcc -mmcu=atmega16 -Os avr.c -o avr.elf
avr.c: In function 'main':
avr.c:10:6: warning: assignment makes integer from pointer without a cast [-Wint-conversion]
     p=array;
avr.c:14:23: error: invalid type argument of unary '*' (have 'int')
         printf("%c\n",*p);
The way I achieved that was simply to change:
    char*p;
to be
    char p;
What version is that?
I get:
mesuttopuzlu.c: In function 'main':
mesuttopuzlu.c:12:5: error: 'for' loop initial declarations are only allowed in C99 or C11 mode
mesuttopuzlu.c:12:5: note: use option -std=c99, -std=gnu99, -std=c11 or -std=gnu11 to compile your code
With
AVR-GCC.exe (AVR_8_bit_GNU_Toolchain_3.5.3_1700) 4.9.2
Copyright (C) 2014 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
But adding the -std=c99 does, indeed, compile with no warnings & no errors
If I simply change:
    char array[2];
to be
    char *array[2];
Then I get:
mesuttopuzlu.c:6:13: warning: assignment makes pointer from integer without a cast
     array[0]='A';
mesuttopuzlu.c:7:13: warning: assignment makes pointer from integer without a cast
     array[1]='b';
mesuttopuzlu.c:10:6: warning: assignment from incompatible pointer type
     p=array;
Bingo!
cheeky
5.4.0 (from FSF not Atmel)
OK, thanks - I guess that must default to a later 'C' standard, then?
Anyhow, it seems clear that the code the OP posted is not the actual code that causes the reported "problem".
<rolls eyes>
I will be corrected if I am wrong, but it might be that:
>>char array[2];
this is actually is telling the compiler/linker  to reserve a number of bytes in the ram area.
so it is not actually a location
>>p=array;
this tells that the pointer has to point to the location 'array' but that in fact is not a single location, but in your case at least 2. To what location should the pointer point then? the first or the second
with changing it to
>>p=&array[0]
you are actually telling the pointer should be the adress (&)  of location 0 in the reserved memory space, and thus is a valid assignment
at least that is the way I like to remember the pointer stuff as it makes life easy, but if you are not working with it on a daily basis hard to grasp.
I'm afraid you are wrong.
Remember that the code as shows in the OP does compile correctly without any warnings. The only reason Cliff & I were making changes was to try to reproduce the warning that the OP had hinted at; in other words, we were deliberately introducing errors.
>>char array[2];
Correct.
Not correct.
The name of an array is, effectively, a pointer to the start of the first element; ie, it gives the address of the 1st element.
>>p=array;
And, by definition, the location 'array' is the location of the first element
Incorrect.
See above: by definition, it is the location of the first element
with changing it to
>>p=&array[0]
True - but not relevant. An array name is exactly equivalent to the address of the first element.
http://c-faq.com/aryptr/index.html
Aside from the compiler warning, the statement
printf("%c\n",*p);
may print lots of garbage since the string
    char array[2];
    array[0]='A';
    array[1]='b';
is not zero terminated.
It should be:
    char array[3];
    array[0]='A';
    array[1]='b';
    array[2]='\0';
But he's using %c not %s? It will work and print the first character of the array that p is pointing to.
