avrdude 5.10 give syntax error for
7 posts / 0 new
I have compiled avrdude 5.10 because I want to use ftdi. So I went by the instruction from http://doswa.com/2010/08/24/avrdude-5-10-with-ftdi-bitbang.html
and tried to run this script:
sudo ./avrdude -v -c avrftdi -C avrdude.conf +atmega328p.conf -P /dev/ttyUSB0 -p m328p
and I get a syntax error at the line for:
type = "wiring";
# PROGRAMMER DEFINITIONS
# http://wiring.org.co/
# Basically STK500v2 protocol, with some glue to trigger the
# bootloader.
programmer
  id    = "wiring";
  desc  = "Wiring";
  type  = "wiring";
  connection_type = serial;
I've tried it without the quotes and it doesn't recognize to 'w';
The avrdude.conf file works fine for avrdude-6.1
Is there an older version of the avrdude.conf I'm supposed to use with 5.1?
- Dan
OK, so I did the same process for avrdude-6.1, copied the avrdude file to my working directory and tried the same script file:
sudo ./avrdude -v -v -v -v  -c avrftdi -C avrdude.conf +atmega328p.conf -P /dev/ttyUSB0 -p m328p $1 $2 $3
and got this error:
avrdude: Version 6.1, compiled on Mar 14 2017 at 13:20:17
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "avrdude.conf"
         User configuration file is "/home/dan/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : avrftdi
avrdude: Warning: using PID 0x6001, ignoring remaining PIDs in list
I avrftdi_open(717): Using device VID:PID 0403:6001 and SN '(null)' on interface A.
D write_flush(481): Setting pin direction (0x0000) and value (0x0000)
T write_flush(493): Set pins command: 80 00 00 82 00 00
I think it might have something to do with how my pins are set:
programmer
  id         = "avrftdi";
  desc       = "FT2232D based generic programmer";
  type       = "avrftdi";
  connection_type = usb;
  usbvid     = 0x0403;
  usbpid     = 0x6001;
  usbvendor  = "";
  usbproduct = "";
  usbdev     = "A";
  usbsn      = "";
#ISP-signals - lower ADBUS-Nibble (default)
  reset  = 3;
  sck    = 0;
  mosi   = 1;
  miso   = 2;
udevadm info --attribute-walk -n /dev/ttyUSB0 | sed -n '/FTDI/,/serial/p'
    ATTRS{manufacturer}=="FTDI"
    ATTRS{removable}=="unknown"
    ATTRS{idProduct}=="6001"
    ATTRS{bDeviceClass}=="00"
    ATTRS{product}=="FT232R USB UART"
  looking at parent device '/devices/pci0000:00/0000:00:1d.1/usb7':
    KERNELS=="usb7"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{bDeviceSubClass}=="00"
    ATTRS{bDeviceProtocol}=="00"
    ATTRS{devpath}=="0"
    ATTRS{idVendor}=="1d6b"
    ATTRS{speed}=="12"
    ATTRS{bNumInterfaces}==" 1"
    ATTRS{bConfigurationValue}=="1"
    ATTRS{bMaxPacketSize0}=="64"
    ATTRS{authorized_default}=="1"
    ATTRS{busnum}=="7"
    ATTRS{devnum}=="1"
    ATTRS{configuration}==""
    ATTRS{bMaxPower}=="0mA"
    ATTRS{authorized}=="1"
    ATTRS{bmAttributes}=="e0"
    ATTRS{bNumConfigurations}=="1"
    ATTRS{maxchild}=="2"
    ATTRS{bcdDevice}=="0313"
    ATTRS{avoid_reset_quirk}=="0"
    ATTRS{quirks}=="0x0"
    ATTRS{serial}=="0000:00:1d.1"
- Dan
My old conf files define programmer.type without quotes.
Add quotes and the conf file works with modern avrdude.
If you have an old avrdude, try it with and without quotes and see if it is happy.
as you can see from my 2nd post, that's not the problem anymore. Going to start a new thread. smiley
- Dan
DO NOT START A NEW THREAD!!!!
Moderator
whoops, sorry boss - already did.
- Dan
... and so the inevitable happened. Lesson learned hopefully. There is nothing quite as annoying as having to chase threads all over the site to try and get the context of a poster's story.
