Help, trying to get measurements form my ds18b20 sensor to show up on an lcd.
9 posts / 0 new
I have the code all written but for some reason it does not work. I have checked and rechecked my connections to the atmega640 I am using but still dont see any issue. I know signal is sent because I checked using a DMM. below is the code I got from whb8:
#define F_CPU 16000000L // run CPU at 16 MHz
#define LED 5 // Boarduino LED on PB5
#define ClearBit(x,y) x &= ~_BV(y) // equivalent to cbi(x,y)
#define SetBit(x,y) x |= _BV(y) // equivalent to sbi(x,y)
#define ReadBit(x,y) x & _BV(y) // call with PINx and bit#
// INCLUDES
#include <avr/io.h> // deal with port registers
#include <util/delay.h> // used for _delay_us function
#include <stdlib.h>
#include <stdio.h>
// TYPEDEFS
typedef uint8_t byte; // I just like byte & sbyte better
typedef int8_t sbyte;
// MISC ROUTINES
void InitAVR()
	DDRE = 0x3F; // 0011.1111; set E0-E5 as outputs
	DDRG = 0x00; // 0000.0000; set PORTG as inputs
void msDelay(int delay) // put into a routine
{ // to remove code inlining
	for (int i=0;i<delay;i++) // at cost of timing accuracy
	_delay_ms(1);
void FlashLED()
	SetBit(PORTE,LED);
	msDelay(250);
	ClearBit(PORTE,LED);
	msDelay(250);
// HD44780-LCD DRIVER ROUTINES
// Routines:
// LCD_Init initializes the LCD controller
// LCD_Cmd sends LCD controller command
// LCD_Char sends single ascii character to display
// LCD_Clear clears the LCD display & homes cursor
// LCD_Home homes the LCD cursor
// LCD_Goto puts cursor at position (x,y)
// LCD_Line puts cursor at start of line (x)
// LCD_Hex displays a hexadecimal value
// LCD_Integer displays an integer value
// LCD_String displays a string
// The LCD module requires 6 I/O pins: 2 control lines & 4 data lines.
// PortB is used for data communications with the HD44780-controlled LCD.
// The following defines specify which port pins connect to the controller:
#define LCD_RS 0 // pin for LCD R/S (eg PB0)
#define LCD_E 1 // pin for LCD enable
#define DAT4 2 // pin for d4
#define DAT5 3 // pin for d5
#define DAT6 4 // pin for d6
#define DAT7 5 // pin for d7
// The following defines are HD44780 controller commands
#define CLEARDISPLAY 0x01
#define SETCURSOR 0x80
void PulseEnableLine ()
	SetBit(PORTE,LCD_E); // take LCD enable line high
	_delay_us(40); // wait 40 microseconds
	ClearBit(PORTE,LCD_E); // take LCD enable line low
void SendNibble(byte data)
	PORTE &= 0xC3; // 1100.0011 = clear 4 data lines
	if (data & _BV(4)) SetBit(PORTB,DAT4);
	if (data & _BV(5)) SetBit(PORTB,DAT5);
	if (data & _BV(6)) SetBit(PORTB,DAT6);
	if (data & _BV(7)) SetBit(PORTB,DAT7);
	PulseEnableLine(); // clock 4 bits into controller
void SendByte (byte data)
	SendNibble(data); // send upper 4 bits
	SendNibble(data<<4); // send lower 4 bits
	ClearBit(PORTE,5); // turn off boarduino LED
void LCD_Cmd (byte cmd)
	ClearBit(PORTE,LCD_RS); // R/S line 0 = command data
	SendByte(cmd); // send it
void LCD_Char (byte ch)
	SetBit(PORTE,LCD_RS); // R/S line 1 = character data
	SendByte(ch); // send it
void LCD_Init()
	LCD_Cmd(0x33); // initialize controller
	LCD_Cmd(0x32); // set to 4-bit input mode
	LCD_Cmd(0x28); // 2 line, 5x7 matrix
	LCD_Cmd(0x0C); // turn cursor off (0x0E to enable)
	LCD_Cmd(0x06); // cursor direction = right
	LCD_Cmd(0x01); // start with clear display
	msDelay(3); // wait for LCD to initialize
void LCD_Clear() // clear the LCD display
	LCD_Cmd(CLEARDISPLAY);
	msDelay(3); // wait for LCD to process command
void LCD_Home() // home LCD cursor (without clearing)
	LCD_Cmd(SETCURSOR);
void LCD_Goto(byte x, byte y) // put LCD cursor on specified line
	byte addr = 0; // line 0 begins at addr 0x00
	switch (y)
		case 1: addr = 0x40; break; // line 1 begins at addr 0x40
		case 2: addr = 0x14; break;
		case 3: addr = 0x54; break;
	LCD_Cmd(SETCURSOR+addr+x); // update cursor with x,y position
void LCD_Line(byte row) // put cursor on specified line
	LCD_Goto(0,row);
void LCD_String(const char *text) // display string on LCD
	while (*text) // do until /0 character
	LCD_Char(*text++); // send char & update char pointer
void LCD_Hex(int data)
// displays the hex value of DATA at current LCD cursor position
	char st[8] = ""; // save enough space for result
	itoa(data,st,16); // convert to ascii hex
	//LCD_String("0x"); // add prefix "0x" if desired
	LCD_String(st); // display it on LCD
void HexDigit(byte data)
// lower 4 bits of input -> output hex digit
// helper function for other LCD hex routines
	if (data<10) data+='0';
	else data+='A'-10;
	LCD_Char(data);
void LCD_HexByte(byte data)
// displays a two-character hexadecimal value of data @ current LCD cursor
	HexDigit(data>>4);
	HexDigit(data & 0x0F);
void LCD_Integer(int data)
// displays the integer value of DATA at current LCD cursor position
	itoa(data,st,10); // convert to ascii
	LCD_String(st); // display in on LCD
void LCD_PadInteger(int data, byte size, char padChar)
// displays right-justifed integer on LCD, padding with specified character
// using this instead of sprintf will save you about 1400 bytes of codespace
	byte len = strlen(st); // string length of converted integer
	sbyte blanks = size-len; // required spaces to pad on left
	if (blanks>=0) // do we need to pad at all?
	while(blanks--) // add padding characters...
	LCD_Char(padChar);
	LCD_String(st); // then the converted integer
// "ONE-WIRE" ROUTINES
#define THERM_PORT PORTG
#define THERM_DDR DDRG
#define THERM_PIN PING
#define THERM_IO 0
#define THERM_INPUT() ClearBit(THERM_DDR,THERM_IO) // make pin an input
#define THERM_OUTPUT() SetBit(THERM_DDR,THERM_IO) // make pin an output
#define THERM_LOW() ClearBit(THERM_PORT,THERM_IO) // take (output) pin low
#define THERM_HIGH() SetBit(THERM_PORT,THERM_IO) // take (output) pin high
#define THERM_READ() ReadBit(THERM_PIN,THERM_IO) // get (input) pin value
#define THERM_CONVERTTEMP 0x44
#define THERM_READSCRATCH 0xBE
#define THERM_WRITESCRATCH 0x4E
#define THERM_COPYSCRATCH 0x48
#define THERM_READPOWER 0xB4
#define THERM_SEARCHROM 0xF0
#define THERM_READROM 0x33
#define THERM_MATCHROM 0x55
#define THERM_SKIPROM 0xCC
#define THERM_ALARMSEARCH 0xEC
// the following arrays specify the addresses of  ds18b20 devices
// to be read using Romreader function
byte rom0[] = {x,x,x,x,x,x,x,x};
byte rom1[] = {x,x,x,x,x,x,x,x};
byte therm_Reset()
	byte i;
	THERM_OUTPUT(); // set pin as output
	THERM_LOW(); // pull pin low for 480uS
	_delay_us(480);
	THERM_INPUT(); // set pin as input
	_delay_us(60); // wait for 60uS
	i = THERM_READ(); // get pin value
	_delay_us(420); // wait for rest of 480uS period
	return i;
void therm_WriteBit(byte bit)
	THERM_LOW(); // pull pin low for 1uS
	_delay_us(1);
	if (bit) THERM_INPUT(); // to write 1, float pin
	_delay_us(60);
	THERM_INPUT(); // wait 60uS & release pin
byte therm_ReadBit()
	byte bit=0;
	_delay_us(1);
	THERM_INPUT(); // release pin & wait 14 uS
	_delay_us(14);
	if (THERM_READ()) bit=1; // read pin value
	_delay_us(45); // wait rest of 60uS period
	return bit;
void therm_WriteByte(byte data)
	byte i=8;
	while(i--) // for 8 bits:
		therm_WriteBit(data&1); // send least significant bit
		data >>= 1; // shift all bits right
byte therm_ReadByte()
	byte i=8, data=0;
		data |= (therm_ReadBit()<<7); // get next bit (LSB first)
	return data;
void therm_MatchRom(byte rom[])
	therm_WriteByte(THERM_MATCHROM);
	for (byte i=0;i<8;i++)
	therm_WriteByte(rom[i]);
void therm_ReadTempRaw(byte id[], byte *t0, byte *t1)
// Returns the two temperature bytes from the scratchpad
	therm_Reset(); // skip ROM & start temp conversion
	if (id) therm_MatchRom(id);
	else therm_WriteByte(THERM_SKIPROM);
	therm_WriteByte(THERM_CONVERTTEMP);
	while (!therm_ReadBit()); // wait until conversion completed
	therm_Reset(); // read first two bytes from scratchpad
	therm_WriteByte(THERM_READSCRATCH);
	*t0 = therm_ReadByte(); // first byte
	*t1 = therm_ReadByte(); // second byte
void therm_ReadTempF(byte id[], int *whole, int *decimal)
// returns temperature in Fahrenheit as WW.D, where W=whole & D=decimal
	byte t0,t1;
	therm_ReadTempRaw(id,&t0,&t1); // get temperature values
	int t16 = (t1<<8) + t0; // result is temp*16, in celcius
	int t2 = t16/8; // get t*2, with fractional part lost
	int f10 = t16 + t2 + 320; // F=1.8C+32, so 10F = 18C+320 = 16C + 2C + 320
	*whole = f10/10; // get whole part
	*decimal = f10 % 10; // get fractional part
inline __attribute__ ((gnu_inline)) void quickDelay(int delay)
// this routine will pause 0.25uS per delay unit
// for testing only; use _us_Delay() routine for >1uS delays
	while(delay--) // uses sbiw to subtract 1 from 16bit word
	asm volatile("nop"); // nop, sbiw, brne = 4 cycles = 0.25 uS
// ROM READER PROGRAM
void RomReaderProgram()
// Read the ID of the attached Dallas 18B20 device
// Note: only ONE device should be on the bus.
	LCD_String("ID (ROM) Reader:");
		LCD_Line(1);
		// write 64-bit ROM code on first LCD line
		therm_Reset();
		therm_WriteByte(THERM_READROM);
		for (byte i=0; i<8; i++)
			byte data = therm_ReadByte();
			LCD_HexByte(data);
		msDelay(1000); // do a read every second
// DUAL TEMPERATURE PROGRAM
void DualTempProgram()
		int whole=0, decimal=0;
		LCD_Line(1);
		LCD_String("Temp1 = ");
		therm_ReadTempF(rom1,&whole,&decimal);
		LCD_Integer(whole); LCD_Char('.');
		LCD_Integer(decimal);
		LCD_Line(2);
		LCD_String("Temp2 = ");
		therm_ReadTempF(rom0,&whole,&decimal);
		msDelay(1000);
		FlashLED();
// MAIN PROGRAM
	InitAVR();
	LCD_Init();
	RomReaderProgram();
	//DualTempProgram();
sonia pan
1) Are you sure that the atmega640 is actually running at 16MHz?
    Write a program that blinks a LED once per second and time the blinks.
2) Your main() terminates which causes the firmware to restart from 0x0000, clearing the LCD ... again and again.
// MAIN PROGRAM
	InitAVR();
	LCD_Init();
	RomReaderProgram();
        while(1);  // Loop forever  <-- Add this
3) therm_Reset() returns the sensor presence bit but your program ignores it - why?
therm_reset() is used in the readTemp functions.
I added the while(1) in the main but still nothing on the LCD.
I made sure it's running at 16Mhz. I am confused here.
sonia pan
You haven't told us how it doesn't work. It might be your hardware or it might be your software.
What tests have you done to prove the hardware works?
I tested the Lcd by writing allnthe ascii characters and it did work, implying also that the microcontroller works.(to make sure, I placed and LED at the pins I initialized as output).
As for the sensor, I used a dmm to check the voltage at its pins (between GND and V+/Data pin)and I had 5V meaning signal reaches .
I dont really know if it's an assurance though.
Any other idea would be welcomed.
As for software, I checked code and may be I need other eyes, you might see a flaw I dont.
sonia pan
1) You have
    at the top of RomReaderProgram() which is called by main().
    Is the "ID (ROM) Reader:" showing on the LCD?
2) It is also used in RomReaderProgram().
    My point was that your code doesn't check the value that therm_reset() returns - the sensor presence pulse.  It should.
Where can I place therm_reset then?
Nothing shows on the lcd.
sonia pan
Err ... no for 2 reasons:
1) It never comes back from RomReaderProgram():
So there is the while(1) (and no I don't like this design either!) but also:
2) even if that function returned then a return from main() does not cause a reset (there was only one issue of compiler back around 4.3 where AVR-LibC made that mistake). What does happen if you return form main is that it does a CLI then an infinite RJMP loop. So it won't reset but if you are returning from main() because you thought it was all going to operate on ISR()s then you will be a little disappointed.
Why is there nothing showing on the LCD?
Add the line shown below to test the LCD.
        while(1); // Loop Forever  <-- Add to test LCD
		LCD_Line(1);
		therm_Reset();
			LCD_HexByte(data);
BTW, is the watchdog disabled on the atmega640?
