TC72 reading temperature
14 posts / 0 new
i have some of problems when dealing with TC72 temp sensor chip
that when i read the temp it get ne a wrong value  i only can write on tc72  control register .
i divide the project to 3 files : SPI.h , SPI.c , MAIN.c
i need your help, pls .
/////////////////////////SPI.h///////////////
*================Types=====================================*/
typedef unsigned char uint8_t ;
/*================Constants================================ */
#define MOSI 5
#define MISO 6
#define SCK 7
#define SS 4
#define MSB_FIRST 0
#define LSB_FIRST 1
/*==========Function prototypes==========================*/
void spi_init(uint8_t data_dr) ;
void spi_write(uint8_t data_s) ;
uint8_t spi_read(void) ;
***********************SPI.c*********************
#include "spi.h"
/*=============Macros=========================*/
#define SET_BIT(REG,BIT) ( (REG) |=( 1<<(BIT)) )
#define CLEAR_BIT(REG,BIT) ( (REG) &=~(1<<(BIT)) )
	DDRB |= (1<<MOSI) | (1<<SCK) | (1<<SS) ;
	CLEAR_BIT(DDRB , MISO) ;
	SPCR |= (1<<SPE) | (1<<MSTR)  ;    /* Enable SPI module , controller is master. */
	//SPCR |= (1<<SPR0) ;    /* SPI clock speed = Fosc/ 16 . */
	(data_dr == 1)? SET_BIT(SPCR , DORD) : CLEAR_BIT (SPCR , DORD) ;
	// SPCR |= 1<<DORD ; // LSB first .
	SPSR |=1<<SPI2X ;
	//CLEAR_BIT(PORTB , SS) ;
	SPDR = data_s ;
	while(!(SPSR & (1<<SPIF))) ;
	//SET_BIT(PORTB , SS) ;
	while( ! (SPSR & (1<<SPIF)) ) ;
	return SPDR ;
*******************************************main******************
#define F_CPU 8000000
#include <util/delay.h>
#include "spi.h"
#include "MMC.h"
/*MACROS*/
#define delay_ms(X) _delay_ms(X)
#define BUTTON 0
	uint8_t high_temp_byte ;
	uint8_t low_temp_byte ;
	uint8_t dummy ;
	DDRD = 0xFF ;
	spi_init(MSB_FIRST) ;
	//delay_ms(200) ;
	//read temp from TC72
	SET_BIT(PORTB , SS) ;  // make CE to TC72 as 1 .
	spi_write(0x80) ;  // to make write operation on TC72 sensor .
	dummy = spi_read() ;
	spi_write(0x11) ;  // set at control reg 0x15 to adjust it at one shot conversion .
	CLEAR_BIT(PORTB , SS) ;// make CE to TC72 as 0 .
	delay_ms(180); // delay to complete temp conversion .
	spi_write(0x02) ; // send address of temp high byte .
	spi_write(0xFF) ; // send dummy output (0x00) to start clock pulses .
	PORTD = spi_read() ;
	spi_write(0xFF) ;
	low_temp_byte = spi_read() ;
	return 0 ;
and the 'wrong' value, is, ?????????
The protocol has none of this "dummy"...
You are doing three bytes for a two-byte operation.
SPI is inherently full-duplex.  There is no need for both read and write primitives.  In fact, with those you will be unable to do true full-duplex "streaming" SPI.
You are doing three bytes for a two-byte operation. ?
As I see it, the spi_read() is only reading what is in the SPDR, it is not generating any clocks, so the dummy = spi_read() ; statements when writing the 0x80 0x11 bytes are not doing much apart from clearing the SPIF flag.
If the compiler optimises very well then there is a possibility that with a processor clock of 8MHz the TC72 is not getting a minimum of 400ns between CE going high and the start of the first SCK pulse.
If SPIF isn't set upon entry, then it never will be...
I remove dummy = spi_read();
And still have the same wrong reading that when temp = 27 i read only 141 !!!!
Is the value 141 in PORTD ?
Is the value 141 in low_temp_byte ?
Is the value 141 the result of some calculation that I have no information about ?
High temp byte ... There is no additional operations .
I am guessing that high_temp_byte now replaces PORTD in PORTD = spi_read() ; in your post #1.
decimal 141 for the high-byte of the temperature is 141 * 0.25 = 35.25 'C, which, with an ambient temperature of 27 'C leads me to suspect that the TC72 is near some heat-generating device(s).
If you suspect that the data is corrupted there is a simple check that you can do., the Microchip TC72 has 2 registers that contain constant data, control register (address 0) and manufacturer-id (address 3).
If the values that you read from those registers agrees with that is expected then the value for the temperature is probably correct.
spi_write(0x11) ;
this should be:
spi_write(0x10) ; // TC72 continiuos operation
or
spi_write(0x14) ; // Tc72 one shot operation
writing 0x11 will simply power down TC72
Mohsen
Huh?
"Read a lot.  Write a lot."
sorry my bad.
0x04 for continuous mode,
0x14 for one shot mode.
Either way bit 0 (SHDN) must be '0'. writing 0x11 will shutdown TC72
Please see table 5-1 of datasheet.
http://ww1.microchip.com/downloa...
Mohsen
I don't have the hardware to test  how exactly TC72 behaves with ox11 written to its control register. However another  issue I see  is that in your spi_write()  function, once while loop passed (which means SPIF is '1') there is no code to clear it. So next time you call spi_write this while loop can not wait til the whole 8 bit data byte is transmitted. in other words "while loop" will be passed  immediately as SPIF bit is already set due to previous  spi transfer. As a result spi_read function (called after dummy spi_writes()  will not return the correct data as it has not been  captured correctly (i.e spi bus has not clocked 8 bits yet at the time the spi_read is called).
solution:  add the following lines  immediately after while loop in spi_write:
        dummy = SPSR;  // to access status register
        dummy = SPDR; // to access data register
Reference: page 127 (14.5.2)  says:
the SPIF bit is cleared by first reading the SPI Status Register with SPIF set, then accessing the SPI Data Register (SPDR).
the while loop  in the spi_read seems to be redundant as this function always come after a dummy write so the serial transfer is completed and its flag already polled in the dummy spi_write.
Mohsen
You have misunderstood the datasheet.  Table 5-2 is the relevant table, as I posted above.
Further, there is no function to bit 2, so a value of 0x04 is equivalent to a value of 0x00, and a value of 0x14 is equivalent to a value of 0x10.
Note:
(One-Shot Command is ignored if SHDN = ‘0’)
One-Shot mode is selected by writing a ‘1’ into bit 4 of
the Control register. The One-Shot mode performs a
single temperature measurement and returns to the
power-saving Shutdown mode. After completion of the
temperature conversion, the One-Shot bit (OS) is reset
to ‘0’ (i.e. “OFF”). The user must set the One-Shot bit
to ‘1’ to initiate another temperature conversion.
Also:
... is incorrect.
	SPDR = data_s ;
Note how and SPSR is read by the while(), and exits only when SPIF is set, and since every spi_write() is followed by an spi_read():
	return SPDR ;
... where the the while() falls through immediately, and SPDR is accessed, that is all that is necessary to clear SPIF:
I'll grant that the spi_write() and spi_read() constructions are awkward, but they function.  A 'better' approach would be an spi_transfer() which writes a byte >>and<< returns a byte, since that is the natural action of SPI anyway.
Why have you resurrected a one-year-old thread?
