GPRS sim800
20 posts / 0 new
Hello.
I use sim800 to send data to webpage but update (data transfer) takes too long, is there faster ways to send data, or faster hardware
instead of sim800, Below is used (pseudo)code and command execution times.
wait_for_sim_ready();
// set connection
send_at("AT+SAPBR=3,1,\"CONTYPE\",\"GPRS\"\r\n"));
wait_for_response();
send_at("AT+SAPBR=3,1,\"APN\",\"internetd\"\r\n"));
send_at("AT+SAPBR=1,1\r\n"));
	read_data_from_sensor();
	send_at("AT+HTTPINIT\r\n"));
	send_at("AT+HTTPPARA=\"URL\",\"www.webpage.com/receive_data.php?data_to_send=<data_from_sensor>\"\r\n")); // data about 160 bytes long
	wait_for_response();		// about 2 sec
	send_at("AT+HTTPACTION=1\r\n"));
	wait_for_response();		// about 5 sec
	send_at("AT+HTTPTERM\r\n"));
	wait_for_response();		// about 1 sec
Ana
ana57 wrote:
takes too long
That's a pretty meaningless statement!
So how long does it take?
How long do you want it to take?
Have you done the sums to see if your expectation/requirement is reasonable?
Have you done comparative measurements with other equipment?
Rather that just dump a load of source code, explain what methods you're using to transfer the data - and what performance you expect that to give.
Fater than what, exactly?
Well I read:
etc.
But as someone who simply is a user of GPRS (because Vodafone cannot seem to rustle up 3G or 4G in my back garden!) surely this kind of performance is "normal". Trying to read avrfreaks.net using a mobile in my shed is as painful an experience as documented here. The real solution is to trade up to a higher speed data network from GPRS!
It looks like the OP is opening & closing a connection for each 160-byte transmission - which is going to be grossly inefficient.
Especially using HTTP!
Why not batch them up ... ?
I tried to send 6 samples at one message, it took about 12 sec instead of 5, so can anyone suggest faster hardware.
More to the point what radio coverage are you in range of? Does the GSM only offer GPRS or are higher data transports (EDGE, 4G etc) available to you?
So what, exactly, did you try?
What does your "one message" look like?
Again, what, exactly, took 12s ?
That doesn't sound at all unreasonable for GPRS setting up a channel, doing some HTTP, and closing the channel.
instead of 5
Where does 5 come from?
ana57 wrote:
... send data to webpage but update (data transfer) takes too long, is there faster ways to send data, ...
The handshaking of TCP has some latency plus HTTP itself.
Alternatives :
  • websockets
  • Google protocol buffers on TCP
  • SMS gateway (evaluate pricing)
  • UDP (some thought for dropped packets)
websocket.org - Powered by Kaazing
https://www.websocket.org/about.html
Low Latency
HTML5 Rocks
Introducing WebSockets: Bringing Sockets to the Web
by Malte Ubl and Eiji Kitamura
October 20th, 2010
https://www.html5rocks.com/en/tutorials/websockets/basics/
An alternative for the cellular modem is to move it from a MCU to an MPU with the MCU attached to the MPU via USB, UART, etc :
GitHub - chilipeppr/serial-port-json-server
https://github.com/chilipeppr/serial-port-json-server
Serial Port JSON Server is a websocket server for your serial devices. It compiles to a binary for Windows, Mac, Linux, Raspberry Pi, or BeagleBone Black that lets you communicate with your serial port from a web application. This enables web apps to be written that can communicate with your local serial device such as an Arduino, CNC controller, or any device that communicates over the serial port.
http://www.avrfreaks.net/forum/low-cost-wifi#comment-1324686 (Google protobuf)
Definition from Techopedia
What are GPRS Tunneling Protocols (GTP)?
https://www.techopedia.com/definition/24978/gprs-tunneling-protocols-gtp
Version 0 can be used with TCP and UDP, while version 1 can be used with UDP only.
Indeed - especially so over GPRS!
surprise
That's why I say that sending such small amounts of data at a time is bound to be slow!
I very much doubt that would help - it is unlikely to be the local processor or comms speed that's the bottleneck.
Take the AVR out of the loop and just use a mobile phone. Try surfing on GPRS, EDGE, UMTS, HSPA, LTE and any other 2G, 3G, 4G links you can think of. You will find GPRS is always an abysmal experience.
Simcom have other modules above GPRS for faster data links...
http://www.simcom.eu/index.php?m...
Web socket looks promising, any idea how to send/receive messages (sim800), if I understood right it is not only TCP/IP socket to port 80.
Relative to a SIM800, I do not know.
Maybe libwebsockets or noPoll
https://en.wikipedia.org/wiki/Comparison_of_WebSocket_implementations
though it's not apparent where to hook into a cellular modem.
Python packages are not listed at WebSocket implementations :
homepage
Python Package Index
websockets 3.2
https://pypi.python.org/pypi/websockets
An implementation of the WebSocket Protocol (RFC 6455)
websockets is a library for developing WebSocket servers and clients in Python. It implements RFC 6455 with a focus on correctness and simplicity.
More RFC 6455 on Python :
https://pypi.python.org/pypi/asyncws/0.1
https://pypi.python.org/pypi/wspy/0.9.1
https://pypi.python.org/pypi/wswrapper/0.0.0
Edit : Python
That, obviously is a question for the SIM800 documentation - and/or SIMCOM support.
The SIM800 documentation (and/or SIMCOM support) will tell you if the unit has any specific support for websockets.
If there is no specific support, then you'll just have to treat it as "raw" TCP/IP
You will, of course, also require Websocket support on the server ...
https://en.wikipedia.org/wiki/We...
An obvious place to start would be: http://www.lmgtfy.com?q=arduino+...
Pycom is adding LTE-M to their line-up of ESP32 MicroPython modules :
Pycom
Meet GPy - our latest board
Dec 24, 2016
https://www.pycom.io/meet-the-gpy/
... a nano SIM card reader ...
... LTE Cat M1 ...
... LTE Cat M2 ...
Pycom
Pycom’s view of LTE-M around the World
Nov 29, 2016
https://www.pycom.io/pycom-and-canonical-to-enable-lpwan-communications-via-snaps/
"This [LTE-M] allows battery lifetime as long as 10 years or more for a wide range of use cases, ..." - GSMA
"... LTE-M networks will co-exist with 2G, 3G, and 4G mobile networks ..." - GSMA
4 LTE categories by data speed least to most : Cat NB1, Cat M1, Cat1, Cat4
Here’s what we think we know about LTE-M roll out.
Vodafone, Europe, Q1 2017 first are Ireland, Netherlands, Spain
EE/Orange, Central Europe, close 2017
Deutsche Telecom, Central Europe
http://www.gsma.com/aboutus/
gchapman wrote:
LTE-M
But LTE-M is not about high-speed; the speed is comparable to GPRS.
As noted earlier, I suspect that the OP's "problem" is not with speed as such, but with the latencies of the network - and a poorly optimised strategy for handling it.
Pycom LTE-M breadboard and OEM modules are a new (near) arrival at Mouser :
http://www.mouser.com/new/pycom/pycom-boards-shields-oem/
Also new are the 1km (est) Wi-Fi and multi-km LoRa modules.
gchapman wrote:
 LoRa modules.
and LoRa is slower than a slow thing on a slow day!
That's the price you pay for long range at low power.
There is no such thing as a free lunch.
EDIT
remembering that the specific request of the OP is:
Seems to come back to:  Good/Cheap/Fast  pick any two, can't have all three.
Cheap/Good <not> fast!
Good/Fast <not> cheap!
Cheap/Fast <not> Good!!!
Except here the tradeoff is between power consumption, speed, and range.
