.bss in SDRAM issue with heap_3.c
3 posts / 0 new
Hi all,
I'm using Atmel Studio 7 (lwip, FreeRTOS 7) and i'm unsuccessfully trying to allocate .bss into SDRAM, but i am succesfully doing it for the Heap. My actual issue is that heaps_3.c (void *pvPortMalloc( size_t xWantedSize )) is unable to allocate memory (always return 0x0000) when .bss is in SDRAM, by switching back .bss to INTRAM this is fixed.
After reading a lot of documentation, is obvious for me (correct me if i'm wrong) that .bss was initialized when SDRAM was not, so i need to initialize SDRAM before that happens. The problem is, I cant find crt0.S anywhere in the project (in program files/toolchain there is a crt0.S, is unclear for me if that's called magically). In my folder ASF I only have trampoline_uc3.S:
https://www.screencast.com/t/vDQ...
then, i don't know from where _init_startup(void) (is in port.c, a file in freeRTOS) is beign called, and is the earliest function i can see before reaching to main() but i guess is too late by that time. My questions could be resumed in:
  • Where can I initialize SDRAM before .bss in this project (based in example LWIP with DHCP /freetos from ATMEL Studio 7)?
  • heaps_3.c (void *pvPortMalloc( size_t xWantedSize )) is unable to allocate memory when .bss is in SDRAM, by switching back .bss to INTRAM this is fixed,
  • where i can find WHO calls int _init_startup(void) for this code? init_startup() is in port.c a file from freeRTOS 7 excecuted before main
when it fails i modify the original linker from:
__bss_start = .;
  .bss            :
    *(.dynbss)
    *(.bss .bss.* .gnu.linkonce.b.*)
    *(COMMON)
    /* Align here to ensure that the .bss section occupies space up to
       _end.  Align after .bss to ensure correct alignment even if the
       .bss section disappears because there are no input sections.  */
    . = ALIGN(8);
  } >INTRAM AT>INTRAM:INTRAM
to
 .bss            :
    *(.dynbss)
    *(COMMON)
    . = ALIGN(8);
  } >SDRAM AT>SDRAM :SDRAM
And now heap_3.c fails always when creating the first tasks
Any help or comment is greatly appreciated, thanks a lot
(added the linker, changed the extension only)
I know nothing about UC3 so I don't know if it's done in the same way as AVR8 but I'm sort of assuming AVR8 may have been used as a starting point. If that's the case it may be worth reading about this stuff in the AVR8 manual and see if their are parallels for AVR32...
One thing you will learn there is that AVR8 has come code sections defined in the linker script before the main .text section so it's roughly:
.vectors
.init0
.init1
.init2
.init8
.init9
.text
The even numbered .init sections are already used by the C runtime so things like stack setting happen in .init0 and the BSS and .data setup don't happen until .init4. So if you want to pre-empt the BSS/.data setup with your own code that "gets in early" you put it in an odd numbered init section (usually init3) with something like:
__attribute__((naked, section(".init3"))) void early(void) {
    // do stuff like setting up ext-mem interfaces
Maybe, just maybe AVR32/UC3 has been done in some similar kind of way? (if the .x file mentions lots of .initN then the chances are that is "yes" ;-)
Hi Mr. Clawson,
(somehow i have problems logging in with my accound)
Thank you for your answer, seems AVR32 is not exactly the same but the functionality you described is exactly what i needed.
In any example code that uses freeRTOS for Atmel studio 7.0 seems:
  •  the linker calls Trampoline on boot:    -Wl,--relax -T../src/ASF/avr32/utils/linker_scripts/at32uc3a/0512/gcc/link_uc3a0512.lds -Wl,-e,_trampoline
  • and this calls a pre-compiled file in the toolchain crt0.o, specifically an assembler function called _stext
  • What i did is add -nostartfiles (prevents the use of crt0.o) and added a new assambler file startup_uc3.s in order to replace the precompiled function _stext from crt0.s
  • Now trampoline calls _stext that is contained in my startup_uc3 which initializes stack,data, bss. (example startup_uc3.s file used)
To clarify how is this done, this is adding a new function in the linker like .mycustomsection, update linker flags to add( -Wl,-e,_start) then in the startup_uc3.s put .section  .mycustomsection, "ax", @progbits (this last one i didn't test it thoroughly)
Linker changes
SECTIONS
  /* If this heap size is selected, all the INTRAM space from the end of the
     data area to the beginning of the stack will be allocated for the heap. */
  __max_heap_size__ = -1;
  /* Use a default heap size if heap size was not defined. */
  __heap_size__ = DEFINED(__heap_size__) ? __heap_size__ : LENGTH(SDRAM)-0x00400000;
  /* Use a default stack size if stack size was not defined. */
  __stack_size__ = DEFINED(__stack_size__) ? __stack_size__ : 4K;
  /* Read-only sections, merged into text segment: */
  PROVIDE (__executable_start = 0x80000000); . = 0x80000000;
  .interp         : { *(.interp) } >FLASH AT>FLASH :FLASH
  .mycustomsection         : { *(.mycustomsection) } >FLASH AT>FLASH :FLASH
  .reset		  :	{ KEEP(*(.reset)) } >FLASH AT>FLASH :FLASH
  .hash           : { *(.hash) } >FLASH AT>FLASH :FLASH
  .dynsym         : { *(.dynsym) } >FLASH AT>FLASH :FLASH
C file:
#include <avr32/io.h>
//! \verbatim
  // This must be linked @ 0x80000000 if it is to be run upon reset.
  .global _start
  .global _early
  .type _start, @function
  .type _early, @function
_start:
  // Jump to the C runtime startup routine.
So in _start you could put a call to any c function like sdram_init() with a call:
.global _sdram_init
_start:
lda.w   sp, _estack
call _sdram_init
Linker flag on toolchain:
-Wl,--relax -T../src/ASF/avr32/utils/linker_scripts/at32uc3a/0512/gcc/link_uc3a0512.lds -Wl,-e,_start -nostartfiles
So in my case i just recycled the trampoline function which does something like this. This seems very simple, but i had a lot of troubles finding out, thanks a lot for your help i hope this helps someone else. If i misunderstood any of this, please let me know i just used what it worked for me.
Thanks a lot
