avrdude cannot open and read hex file
23 posts / 0 new
In Atmel Studio 7 I managed to setup avrdude to program an Arduino Nano 3 this way:
-C "C:\avrdude\avrdude.conf" -v -v -v -patmega328p -carduino -Pcom8 -b57600 -Uflash:w:"$(ProjectDir)Debug\$(TargetName).hex":i
It all works to the point where it should open and read the .hex file, however it cannot find the hex file (even though the said hex file exists):
avrdude.exe: erasing chip
avrdude.exe: reading input file "C:\Users\IEUser\Documents\Atmel Studio\7.0\GccApplication2\GccApplication2\Debug\GccApplication2.hex"
avrdude.exe: can't open input file C:\Users\IEUser\Documents\Atmel Studio\7.0\GccApplication2\GccApplication2\Debug\GccApplication2.hex: No such file or directory
avrdude.exe: read from file 'C:\Users\IEUser\Documents\Atmel Studio\7.0\GccApplication2\GccApplication2\Debug\GccApplication2.hex' failed
Interestingly when I hard-coded the name of the hex file, everything worked fine. What am I missing?
Maybe you need a \ after (ProjectDir).
I always run avrdude from a batch file in the project folder.  The path is relative.
Depending where the batch file is it would be something like GccApplication2/Debug/GccApplication2.hex.
Hi Steve!
Thank you for your help, you certainly gave me something to start with.
Strangely the path to the hex file is correct. It says it cannot open the file but the path to it is fine.
The following command works fine in command line:
avrdude -v -v -v -patmega328p -carduino -Pcom8 -b57600 -Uflash:w:GccApplication2.hex:i
I concluded that the fault is at Atmel Studio and the way the path is defined. avrdude, the serial port and the programmer all work fine. This still doesn't work in Atmel Studio:
-C "C:\avrdude\avrdude.conf" -v -v -v -patmega328p -carduino -Pcom8 -b57600 -Uflash:w:$(TargetDir)Debug\$(TargetName).hex:i
It's very frustrating. IS there an option in Atmel Studio to set paths?
SOLVED!
The right command:
-C "C:\avrdude\avrdude.conf" -v -v -v -patmega328p -carduino -Pcom8 -b57600 -U flash:w:"$(TargetDir)$(TargetName).hex":i -v -v
So it seems that indeed, the path was wong. Thank you steve17, your tip was correct!!!
Is there any a way to edit the topic title and add 'SOLVED'?
Just click the "Mark as Solution" on one of the posts in the thread.
BTW for the future - to debug this kind of thing set the external command to invoke a batch file and then just have that print out the parameters passed to it and this way you can easily see what the meta variables represent.
I got a simular problem.
I'm trying to create a midi controller from my Arduino Uno using an AVR ISP2.
Everytime I try to reassign my usb port with terminal I get the same error:
/Users/Lennard/Downloads/hiduino-master/LUFA-140928/Projects/arduino_midi: is a directory
Lennards-MacBook-Pro:~ Lennard$ avrdude -p at90usb162 -P usb -c avrispmkii -U flash:w:arduino_midi.hex -v -F
Pressing enter:
avrdude: Version 6.0.1, compiled on Dec 16 2013 at 17:26:24
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf"
         User configuration file is "/Users/Lennard/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : avrispmkii
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200212995
         AVR Part                      : AT90USB162
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC6
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no        512    4    128  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     16384  128    128  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel AVR ISP mkII
         Programmer Model: AVRISP mkII
         Hardware Version: 1
         Firmware Version Master : 1.23
         Vtarget         : 5.1 V
         SCK period      : 8.00 us
avrdude: Device signature = 0x1e9489
avrdude: Expected signature for AT90USB162 is 1E 94 82
avrdude: safemode: lfuse reads as EF
avrdude: safemode: hfuse reads as D9
avrdude: safemode: efuse reads as F4
avrdude: erasing chip
avrdude: reading input file "arduino_midi.hex"
avrdude: error opening arduino_midi.hex: No such file or directory
avrdude: input file arduino_midi.hex auto detected as invalid format
avrdude: can't open input file arduino_midi.hex: No such file or directory
avrdude: read from file 'arduino_midi.hex' failed
avrdude: safemode: Fuses OK (H:F4, E:D9, L:EF)
avrdude done.  Thank you.
How can I get rid of this error and start setting up my midi controller?
But that is simply saying that arduino_midi.hex does not exist in the directory where you are running avrdude (the prompt appears to suggest this is just "~", your home directory). Either cd to the directory where the .hex file really is or specify it on the avrdude command line.
It also seems a bit strange that you are saying it is an at90usb162 in the command line but avrdude is seeing a different signature? I cannot help notice that:
~/windows/avr8-gnu-toolchain-linux_x86_64/avr/include/avr$ grep SIGNA iom16u2.h
#define SIGNATURE_0 0x1E
#define SIGNATURE_1 0x94
#define SIGNATURE_2 0x89
so the chip is actually a mega16U2 not a at90usb162.
Thanks for your response Clawson!
Since I'm new to this I got a lot of questions.
You're saying that the file does not exist in the directory where I'm running avrdude.
I've checked the folder I was searching in and I did find it, does this mean the code is wrong?
If yes, what should I write?
I also tried to change the at90usb162 part into mega16U2, then I got this message:
Last login: Mon Jan  9 09:48:46 on console
lennards-mbp:~ Lennard$ /Users/Lennard/Downloads/hiduino-master/LUFA-140928/Projects/arduino_midi
-bash: /Users/Lennard/Downloads/hiduino-master/LUFA-140928/Projects/arduino_midi: is a directory
lennards-mbp:~ Lennard$ avrdude -p mega16U2 -P usb -c avrispmkii -U flash:w:arduino_midi.hex -v -F
avrdude: AVR Part "mega16U2" not found.
Valid parts are:
  uc3a0512 = AT32UC3A0512       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13747]
  c128     = AT90CAN128         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:3136]
  c32      = AT90CAN32          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:3520]
  c64      = AT90CAN64          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:3328]
  pwm2     = AT90PWM2           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:8371]
  pwm2b    = AT90PWM2B          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:8564]
  pwm3     = AT90PWM3           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:8554]
  pwm316   = AT90PWM316         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:8591]
  pwm3b    = AT90PWM3B          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:8578]
  1200     = AT90S1200          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:1597]
  2313     = AT90S2313          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:1826]
  2333     = AT90S2333          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:1939]
  2343     = AT90S2343          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:2067]
  4414     = AT90S4414          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:1713]
  4433     = AT90S4433          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:2191]
  4434     = AT90S4434          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:2315]
  8515     = AT90S8515          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:2398]
  8535     = AT90S8535          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:2512]
  usb1286  = AT90USB1286        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:11081]
  usb1287  = AT90USB1287        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:11271]
  usb162   = AT90USB162         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:11284]
  usb646   = AT90USB646         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:10878]
  usb647   = AT90USB647         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:11068]
  usb82    = AT90USB82          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:11470]
  m103     = ATmega103          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:2633]
  m128     = ATmega128          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:2956]
  m1280    = ATmega1280         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9380]
  m1281    = ATmega1281         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9570]
  m1284p   = ATmega1284P        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:4332]
  m1284rfr2 = ATmega1284RFR2     [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9935]
  m128rfa1 = ATmega128RFA1      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9790]
  m128rfr2 = ATmega128RFR2      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9859]
  m16      = ATmega16           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:3713]
  m161     = ATmega161          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5664]
  m162     = ATmega162          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:4524]
  m163     = ATmega163          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:4722]
  m164p    = ATmega164P         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:3892]
  m168     = ATmega168          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7410]
  m168p    = ATmega168P         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7599]
  m169     = ATmega169          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:4880]
  m16u2    = ATmega16U2         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:11845]
  m2560    = ATmega2560         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9583]
  m2561    = ATmega2561         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9777]
  m2564rfr2 = ATmega2564RFR2     [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9925]
  m256rfr2 = ATmega256RFR2      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9844]
  m32      = ATmega32           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5487]
  m324p    = ATmega324P         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:3916]
  m324pa   = ATmega324PA        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:4108]
  m325     = ATmega325          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12213]
  m3250    = ATmega3250         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12594]
  m328     = ATmega328          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7800]
  m328p    = ATmega328P         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7985]
  m329     = ATmega329          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5062]
  m3290    = ATmega3290         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5261]
  m3290p   = ATmega3290P        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5275]
  m329p    = ATmega329P         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5247]
  m32u2    = ATmega32U2         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:11658]
  m32u4    = ATmega32U4         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:10688]
  m406     = ATMEGA406          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:14085]
  m48      = ATmega48           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7010]
  m48p     = ATmega48P          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7197]
  m64      = ATmega64           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:2773]
  m640     = ATmega640          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9190]
  m644     = ATmega644          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:4124]
  m644p    = ATmega644P         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:4315]
  m644rfr2 = ATmega644RFR2      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9945]
  m645     = ATmega645          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12404]
  m6450    = ATmega6450         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12606]
  m649     = ATmega649          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5288]
  m6490    = ATmega6490         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5474]
  m64rfr2  = ATmega64RFR2       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9872]
  m8       = ATmega8            [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5804]
  m8515    = ATmega8515         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:5965]
  m8535    = ATmega8535         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:6123]
  m88      = ATmega88           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7210]
  m88p     = ATmega88P          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7397]
  m8u2     = ATmega8U2          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12032]
  t10      = ATtiny10           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:14040]
  t11      = ATtiny11           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:1092]
  t12      = ATtiny12           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:1156]
  t13      = ATtiny13           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:1289]
  t15      = ATtiny15           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:1464]
  t1634    = ATtiny1634         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13773]
  t20      = ATtiny20           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:14050]
  t2313    = ATtiny2313         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7998]
  t24      = ATtiny24           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9956]
  t25      = ATtiny25           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:8644]
  t26      = ATtiny26           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:6281]
  t261     = ATtiny261          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:6438]
  t4       = ATtiny4            [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13996]
  t40      = ATtiny40           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:14067]
  t4313    = ATtiny4313         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:8187]
  t43u     = ATtiny43u          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:10509]
  t44      = ATtiny44           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:10140]
  t45      = ATtiny45           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:8826]
  t461     = ATtiny461          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:6629]
  t5       = ATtiny5            [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:14013]
  t84      = ATtiny84           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:10324]
  t85      = ATtiny85           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:9007]
  t861     = ATtiny861          [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:6820]
  t88      = ATtiny88           [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:7612]
  t9       = ATtiny9            [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:14023]
  x128a1   = ATxmega128A1       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13078]
  x128a1d  = ATxmega128A1revD   [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13094]
  x128a1u  = ATxmega128A1U      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13104]
  x128a3   = ATxmega128A3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13114]
  x128a3u  = ATxmega128A3U      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13124]
  x128a4   = ATxmega128A4       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13134]
  x128a4u  = ATxmega128A4U      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13192]
  x128b1   = ATxmega128B1       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13244]
  x128b3   = ATxmega128B3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13302]
  x128c3   = ATxmega128C3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13006]
  x128d3   = ATxmega128D3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13058]
  x128d4   = ATxmega128D4       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13068]
  x16a4    = ATxmega16A4        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12744]
  x16a4u   = ATxmega16A4U       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12672]
  x16c4    = ATxmega16C4        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12724]
  x16d4    = ATxmega16D4        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12734]
  x16e5    = ATxmega16E5        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13642]
  x192a1   = ATxmega192A1       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13374]
  x192a3   = ATxmega192A3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13390]
  x192a3u  = ATxmega192A3U      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13400]
  x192c3   = ATxmega192C3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13312]
  x192d3   = ATxmega192D3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13364]
  x256a1   = ATxmega256A1       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13472]
  x256a3   = ATxmega256A3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13488]
  x256a3b  = ATxmega256A3B      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13508]
  x256a3bu = ATxmega256A3BU     [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13518]
  x256a3u  = ATxmega256A3U      [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13498]
  x256c3   = ATxmega256C3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13410]
  x256d3   = ATxmega256D3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13462]
  x32a4    = ATxmega32A4        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12832]
  x32a4u   = ATxmega32A4U       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12760]
  x32c4    = ATxmega32C4        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12812]
  x32d4    = ATxmega32D4        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12822]
  x32e5    = ATxmega32E5        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13694]
  x384c3   = ATxmega384C3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13528]
  x384d3   = ATxmega384D3       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13580]
  x64a1    = ATxmega64A1        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12930]
  x64a1u   = ATxmega64A1U       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12946]
  x64a3    = ATxmega64A3        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12956]
  x64a3u   = ATxmega64A3U       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12966]
  x64a4    = ATxmega64A4        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12976]
  x64a4u   = ATxmega64A4U       [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12848]
  x64b1    = ATxmega64B1        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12986]
  x64b3    = ATxmega64B3        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12996]
  x64c3    = ATxmega64C3        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12900]
  x64d3    = ATxmega64D3        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12910]
  x64d4    = ATxmega64D4        [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:12920]
  x8e5     = ATxmega8E5         [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13590]
  ucr2     = deprecated, use 'uc3a0512' [/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf:13763]
What's going wrong.
It can't be that hard right to make my Arduino work as a midi controller so I can trigger my relay board on/off?
Also, if I format the usb of the arduino I can't make the in and outputs for my jumpers work right? How can I fix this?
Everything I'm trying to do is related to this article, starting from step 8:
http://www.instructables.com/id/...
Hopefully u can help me
So:
-p mega16U2
is wrong.
Try:
-p m16u2
But also what are you trying to do with:
Did you mean to use:
lennards-mbp:~ Lennard$ cd /Users/Lennard/Downloads/hiduino-master/LUFA-140928/Projects/arduino_midi
The "cd" command means "change directory". As you are not changing directory correctly "/Users/Lennard/Downloads/hiduino-master/LUFA-140928/Projects/arduino_midi" is not the current directory when you come to run the avrdude command - which is why the .hex file is not being found.
I tried to copy everything u said in the right way.
Somehow the cd part doesn't seem to work I think
Here's the code:
Last login: Mon Jan  9 12:31:23 on ttys000
lennards-mbp:arduino_midi Lennard$ avrdude -p m16u2 -P usb -c avrispmkii -U flash:w:arduino_midi.hex -v -F
         Using Port                    : usb
         AVR Part                      : ATmega16U2
         PAGEL                         : PD7
         BS2                           : PC6
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 1
         Vtarget         : 5.1 V
Just show the output of the pwd and ls commands after you cd to that directory.
Hello I'm also trying to flash the Arduino Uno Atmega328p board. However, I get the following message.
avrdude.exe: Version 6.3, compiled on Jan 17 2017 at 12:00:53
             Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
             Using Port                    : COM4
             Using Programmer              : arduino
             Overriding Baud Rate          : 115200
             AVR Part                      : ATmega328P
             PAGEL                         : PD7
             BS2                           : PC2
             RESET disposition             : dedicated
             RETRY pulse                   : SCK
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
               eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
               lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
             Programmer Type : Arduino
             Description     : Arduino
             Hardware Version: 3
             Firmware Version: 4.4
             Vtarget         : 0.3 V
             Varef           : 0.3 V
             Oscillator      : 28.800 kHz
             SCK period      : 3.3 us
avrdude.exe: AVR device initialized and ready to accept instructions
avrdude.exe: Device signature = 0x1e950f (probably m328p)
avrdude.exe: safemode: hfuse reads as 0
avrdude.exe: safemode: efuse reads as 0
avrdude.exe: reading input file "c:\users\cem\Documents\Atmel Studio\7.0\GccApplication2\GccApplication2\Debug\GccApplication2.hex"
avrdude.exe: can't open input file c:\users\cem\Documents\Atmel Studio\7.0\GccApplication2\GccApplication2\Debug\GccApplication2.hex: No such file or directory
avrdude.exe: read from file 'c:\users\cem\Documents\Atmel Studio\7.0\GccApplication2\GccApplication2\Debug\GccApplication2.hex' failed
avrdude.exe: safemode: Fuses OK (E:00, H:00, L:00)
avrdude.exe done.  Thank you.
However, when I check the Directory, I don't see the .hex file. What can be the reason that I don't have the .hex file? How could I flash my arduino board? I appreciate your answers. Thank you.
The most obvious reason would be that you didn't build it. Or you tried to build it but the build finished with errors.
Go up a few directories and "dir GccApplication2.hex /s" which should locate where it has actually been built (assuming it has)
I searched the whole Directory of my Computer. However, there is no GccApplication2.hex ​file. I use Atmel Studio 7 and under Tools-> External Tools -> Commands: C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avrdude.exe and Arguments: -C"C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf" -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:"$(TargetDir)$(TargetName).hex":i ​​ Do you think that it has something with Arguments' path to do?
Then show us the complete output of your build. After a Rebuild, switch to the Output tab, mark everything there, copy that and paste in a post here.
Also go to the project Properties, select Build at the left and do a screen-shot that shows everything to the right in that pane.
The following lines are my Output tab:
             System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf"
             Using Port                    : COM4
             PAGEL                         : PD7
             BS2                           : PC2
             RETRY pulse                   : SCK
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
             Hardware Version: 3
             Vtarget         : 0.3 V
             Varef           : 0.3 V
             SCK period      : 3.3 us
avrdude.exe: reading input file ".hex"
avrdude.exe: can't open input file .hex: No such file or directory
avrdude.exe: read from file '.hex' failed
When I go to under View to Properties Window (as this is the only property tab that i can find in Atmel Studio 7) , there is no build.
That is not the build. That is an attempt at programming the flash.
Before attempting to program flash you must "build" (compile, and link, and more..) the application. The result of doing a (successful) build is that the .hex file is created from your source files. If you've never done a build of the project there will be no .hex file.
This differs from how you do things in Arduino IDE. In that IDE you normally just select Sketch menu and in there Upload. The Arduino IDE will start a build first, and if it fails will not proceed with the flash programming.
Using AVRDUDE from Atmel Studio, as an "external tool", Studio will unfortunately not start a build before running the AVRDUDE "external tool" [1] [2]. You must start the build.
Unless you have set the project up in some special way you do that by any of the following manouvres:
  • Pull down the Build menu and select Build Solution (will build all projects in your open solution).
  • Press F7 (same effect as above).
  • Right click on the solution in Solution Explorer and select Build Solution (same effect as above).
Or any of these:
  • Pull down the Build menu and select Build project-name (will build only the project that is set up as the start project).
  • Right click on the project in the Solution Explorer, and select Build (will build only the project you right-clicked).
There are also menu alternatives for Rebuild. The difference is that a Build only does so much of a build that is actually needed. I.e. if no source files or project settings have changed since the last build it will do nothing. The Rebuild, on the other hand forces a rebuild of everything in the project.
Footnotes:
[1] If the project  is set up to use one of Atmels "official" programming tools (AVR ISP mkII, AVR JTAGICE mkII, AVR JTAGICE3, Atmel-ICE, AVR Dragon...) then Studio will start a build if you select the menu  alternative for programming the flash.
[2] I say "unfortunately" because it seems to me that it would be easy to have a checkbox in the "External Tool" setup saying "Build solution before running tool".
Thank you very much. My mistake was that I was trying to Flash under a file not under a Project. When I moved the Code under a Project, I saw the Build button and I did what you wrote. So now the LED is blinking. Thank you very much again.
