Split from: AT32UC3C0512C BOOTLOADER / APPLICATION SELECT
3 posts / 0 new
Can someone please hep me with flashing the program in AT32UC3C0512. I tried flashing the code using Atmel ice with awire and jtag both. Both times while flashing code it gives me error Failed to write  ox80000000h something like this. I am very new to avr 32 bit MCU.
* Please don't hijack someone else's thread. Moderator *
Describe your hardware, is this MCU on a pcb of known good layout or is it on a proto-board?
Are ALL power and ground pins connected with bypass caps near by?
What is the power source?
The problem here might not be a power supply one.
UC3 chips come with a factory programmed bootloader, and this bootloader region is protected by BOOT PROTECT fuse. To fix this problem just go to device programming window in Atmel Studio and perform a chip erase.
