stuck in AVR32 usb HOST mass storage bootloader program SCRIPTING PLZ HELP..
2 posts / 0 new
I am working on EVK1100 Board . I am startup guy .so I don't have much knowledge in USB host mass storage bootloader.
for this I used the reference example is given by Atmel  application note with a software package avr32758.zip. I am not able to program bootloader scripting using JTAG programmer.
my doubt is how to program DOS script file using a JTAG programmer?
 in  given application note: This script programs the DFU bootloader, the MSC, bootloader and the user application
jtagprogram-uc3a-dfu_bl-ms_bl-user_appli.cmd file:
jtagprogram-uc3b-dfu_bl-ms_bl-user_appli.cmd file:
I tried  to execute this cmd  ex: I connect my evk1100 board to Atmel JTAG debugger .after that i open the command window and type the dos script command.
but error is  command is not recognized  as an internal or external command .so what I have to  do?
I copy  this folder contains the srec_cat.exe tool in my c system path. i did the same thing with srec_cat.exe tool. but no response
I send some screenshot of error pleased referred  attach below
pleased help...
thanks
If you are using avr32 studio, you can use the avr32program.exe
If you have Atmel Studio IDE, the script will be different.
Refer to the following FAQ :- It has examples for both - http://atmel.force.com/support/a...
