delay AVR32
6 posts / 0 new
How to use delay_ms(); function with 32bit microcontrollers? Is there any difference or is it the same like with 8bit controllers. For example a simple code for LED Blink every second but with UC3C-EK?
There is no such thing for AVR32. But really programmers don't use delay_ms() anyway (why would you pay for expensive silicon to have it sat idle for most of the time?). If you want to schedule activities in your code use a timer.
If you REALLY need a delay try something like:
void my_delay(uint32_t n) {
    volatile uint32_t m;
    for (m = 0; m < (n * 100000); m++);
You will need to call this a few times in a loop and time it with a stop watch. Adjust 100000 until the delay here is some "useful" amount like 1 millisecond, 10 milliseconds, 100 milliseconds or whatever.
Basically i need to read and send data from temperature sensor every 1h, so i am not sure if i can do that without delay_s and while()
Thank you for the answer
But if it's once an hour surely you put the CPU to sleep and arrange for an infrequent alarm to wake it?
Thats a very good idea Sir!
There is also a delay API in ASF which makes use of the cycle counter.
http://asf.atmel.com/docs/3.33.0...
But as sugested by clawson, I would not have my MCU sitting idle, it either has to go to sleep or do someting else. I would suggest that you create a state machine along with a timer to monitor tasks.
