AT32UC3C and ADT7301
4 posts / 0 new
Greetings,
has anyone experiance with AT32UC3C0512 and Temperature Sensor ADT7301 and putting them together? My task is to connect those two and send temperature value over 32UC3C1512C TX pin (PB17). I am not very good at this and have a basic knowlege. There is a code in ADT7301 data sheet and its said that any microchip microcontroller can use that program by simply exchanging the include file for the device that is being used and I have no idea how to do it.
m@arko
So, i have done following:
I have connected Temp. sensor ADT7301 with AT32UC3C-EK via Two Wire Interface like this:
SCL --> WZ_SCL (J44.2)
DOUT --> WZ_SDA (J44.1)
VCC --> VCC3 3,3V (J25.10)
GND --> GND (J25.9)
Pins DIN and CS are N.C.
From Atmel Studio 7 i have used Example Project TWIN Master Example-UC3C-EK(Using the TWIM module, perform read and write operations from/to a virtual memory space pre-allocated in internal RAM in a slave TWI device. To be used with two boards with the corresponding TWIS module example. [TWIM Master Example - UC3C-EK - AT32UC3C0512C])
When I programm the device on PC terminal i get this result:
Master Example
Master Started
TARGET SLAVE FIND:      PASS
Writing data to TARGET
WRITE TEST:     PASS
Reading data from TARGET
READ TEST:      FAILED
Check Read:     FAIL
Can anyone give me some kind of direction/advice or tell am I even close?
So why the two usernames?
I cannot reset  password for my first account.
This server is experiencing technical problems. Please try again in a few moments. Thanks for your continued patience, and we're sorry for any inconvenience this may cause.
Error 503 Service Unavailable
Service Unavailable
XID: 1618296547
so i have logged with Google account.
Any suggestion for my actual problem? :D
