increment button
29 posts / 0 new
Hi everybody
I would like to know how to create an increment once you press a button. It has to be kind of like this:
Every time you press the button, the value should increase by +1 on the display. So if I press the button 5 times that should give the value 5 on the display.
I tried to set as follows, but am stuck on increment.
void ChoiceOfSMS(void)
unsigned char tmp;
tmp = keyscan();
unsigned char a = 1;
while(tmp ='1')                                            // Button 1
  a++;
lcd_goto(1,1);
data_to_display(a);
First question: do you know how to detect a "pushed" button? I see no evidence of it in your code. keyscan(), what ever that is, is overkill. How many "buttons" do you have?
Second question: what mcu are you using and are you using some sort of pre-made board? If pre-made, which one?
THat cannot be your entire program.  THere needs to be some form of AVR_setup to configure input(s), and output(s)  Some includes and a f_CPU define.
BUT, lets say thats all done properly.  YOur code will never work properly for several reasons.
1) you never clear 'tmp' so after you press your button that first time, 'a' will increment until it overflows then start over repetitively.
2) no debounce is taking place so your display will appear to 'skip' numbers.  For now the debounce is the least of your concerns.  Post the parts of your program that includes your AVR_SETUP and includes and defines.
JIm
A further note: that pseudo-code is written a bit like you would when an operating system is available. There is NO operating system, here.
Jim (jgm) is absolutely right. You have to figure out how everything is going to be initialized and that includes a bunch of #include statements and probably a bunch of #define statements.
Then, get rid of that keyscan idea and work at the level of detecting individual buttons. I assume that you do NOT have a regular keyboard but one or more simple buttons. You need to learn how to detect those buttons. Later that will involve debouncing, but you are a long ways from that point, now.
And please do NOT post such questions on the Studio forum. This is only for Studio related bugs, I'll move the thread to general programming.
Etie,
I do not know what your display code looks like, nor do I know what AVR you are using, but to possibly prevent this thread form turning into a mess take look at this:
I wrote this, and checked it on a Mega2560 running at 8Mhz, but will work on pretty much any AVR:
 * GccApplication1.c
 * Created: 10/22/2016 12:12:12 AM
 *  Author: jgmDESIGNS-Laptop
THIS PROJECT RUNS ON A MEGA2560 MCU.
THE CLOCK FUSE IS SET TO THE INTERNAL 8 MHz OSC
THE CLKDIV8 FUSE is BE DISABLED
#define F_CPU 8000000UL
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
#include <util/delay.h>
void avr_setup(void)
	DDRA = 0xFF;	//all outputs
	DDRB = 0x00;	//PORTB input
	PORTB = 0xFF;	//pullups all on
	avr_setup();
	uint8_t a = 0x00;
	PORTA = a;     //make sure PORTA is clear
		if((PINB & 0x01) == 0)		//check to see if button on PORTB,0 pushed - active low
			_delay_ms(20);		//wait for button to stabilise/lazy debounce
			a++;	//increment a variable by one
			PORTA = a;		//output a to porta
					while((PINB & 0x01) == 0)		//wait here until PORTB,0 button is released
					}//end of while
			_delay_ms(20);		//lazy debounce
		}//end of if
	}//end of while(1)
}//end of main
It simply sits in a loop testing for the button connected to PortB,0 pin.  Once it sees the pin pulled LOW the code waits 20 milliseconds for the button to stabilise(google DEBOUNCE),
then increments the 'a' variable by 1, and sends this to PORTA.  Then the code sits in a WHILE() loop waiting for the button to be released.
Once it is released the code waits 20 milliseconds for the button to stabilise(google DEBOUNCE), and the loop repeats.
In your scenario you would do this:
#define F_CPU 8000000UL      //<-- Change this to your AVRs clock
#include <stdio.h>
#include <stdint.h>
#include <stdlib.h>
	avr_setup();
	uint8_t a = 0x00;
			lcd_goto(1,1);
			data_to_display(a);
					}//end of while
		}//end of if
	}//end of while(1)
}//end of main
Untested.
Hope this helps.
EDIT: spelling
Hello everyone,
I'm sorry for inaccurate information on the code. And so the purpose of the exercise to do.
In fact I use ARV STK500, ATmelStudio 7 ATmega16 and a 3x4 keypad.
I have on hand a keypad code is active, but I have pragrammer each button.
That is why I have started the '1' key. For the "1" button should have to display each message record and its index. And stokage capacity is limited á 10 messages. However after appuer 10 times, the Lcd is playing "A" instead of 10 á the position lcd_goto (1.1) and the message lcd_goto á the position (2,0).
For example: when I support once the "1" button, the LCD displays 1 á the position (1,1) and the message á the position (2,0).
the routine ChoiceSMS  is only for the button "1".
The position to display the message is already fixed.
Thank you so much for your response.
My English is so poor.
Make sure you disable the JTAG interface as it resides on PORTC.
Instead of using 'if' statements for key presses, you might want to implement a switch instead.
Wouldn't it be far better to use the JTAG - so that you can actually see what's going on inside the chip ?!
Agreed, but his code has the keypad attached to PORTC, that's why I mentioned disabling JTAG. Of course the OP can always change the code to use another port, unless this is a PCBoard.
JTAG is long off
I still try as below but no raction button "1".
unsigned char ChoiceSMS(void)
    uint8_t tmp = 0x01;
        while(keyscan()== '1')        //check to see if button "1" is pressed
            tmp++;    //increment tmp variable by one
             if (tmp =0x0A)
                 tmp = 0;
             LCD_goto(1,1);
             switch(tmp)
                 case 1:
                 if (tmp =1)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("first message");
                 break;
                 case 2:
                 if (tmp =2)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("2nd message");
                 break;
                 case 3:
                 if (tmp =3)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("3 message");
                 break;
                 case 4:
                 if (tmp =4)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("4 message");
                 break;
                 case 5:
                 if (tmp =5)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                 break;
                 case 6:
                 if (tmp =6)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("5 message");
                 break;
                 case 7:
                 if (tmp =7)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("6 message");
                 break;
                 case 8:
                 if (tmp =8)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("7 message");
                 break;
                 case 9:
                 if (tmp =9)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("8 message");
                 break;
                 case 10:
                 if (tmp ='A')
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("9 message");
                 break;
                 default: return;
        }//end while
Etie wrote:
switch(tmp) {
case 1:
if (tmp =1)
1)  As you are already in "case 1:", you >>know<< that the value of tmp is 1 -- otherwise the code would not be executed.
2)  (tmp = 1) is incorrect -- if you want to make the comparison, then it is (tmp == 1) for comparison, and not the assignment operator.
3)
Etie wrote:
if (tmp ='A')
Assuming you meant to use the comparison operator == and you know tmp is 10, how do you expect a comparison against 'A' 0x41 to work?
4)  ...and before the switch(), you limit the value of tmp to no more than 9
I'd still like to see keyscan.
Check Post#7, his source code is there
JIm
 formally i apologize for this serious error of comparison. I have already corrected.
I'd made the mistake of the kopie I posted before.
here's the code I wanted poster.
I am sorry for the inconvenience that I have cuase.
I am only a beginner in programming.
Routine the button "1" to choice the message between 1 to A.
        uint8_t tmp = 0x01;          // Index Message (to be increment)
        while(keyscan()== '1')         //check to see if button "1" activ is
             if (tmp ==0x0A)
                 tmp = 0;
             switch(tmp)
                 case 1:
                 if (tmp == 0x01)
                     LCD_Print("1st message");
                     LCD_goto(1,1);
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                 break;
                 case 2:
                 if (tmp == 0x02)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                 break;
                 case 3:
                 if (tmp ==0x03)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("3rd message");
                 break;
                 case 4:
                 if (tmp ==0x04)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("4th message");
                 break;
                 case 5:
                 if (tmp ==0x05)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("5th message");
                 break;
                 case 6:
                 if (tmp ==0x06)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("6th message");
                 break;
                 case 7:
                 if (tmp ==0x07)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("7th message");
                 break;
                 case 8:
                 if (tmp ==0x08)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("8th message");
                 break;
                 case 9:
                 if (tmp ==0x09)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("9th message");
                 break;
                 case 10:
                 if (tmp ==0x0A)
                     data_to_dis(tmp);
                     LCD_goto(2,0);
                     LCD_Print("10th message");
                 break;
                 default: return;
Please use CODE <> tags button in toolbar - JGM
Hi everyone
The code works now, but there is still a problem.
After 10 times press on the button. the next support is the 11th to return at 1 but it is still remains af 10.
However the 12th press on the come to 1.
can you tell me what's wrong?
        uint8_t tmp = 0x00;          // Index Message (to be increment)
    do
            _delay_ms(50);             //wait for button to stabilise/lazy debounce
             if (tmp ==0x10)
                 tmp = 0;
             switch(tmp)
                 case 1:
                 if (tmp == 0x01)
                     LCD_goto(1,1);
                     data_to_dis(tmp + 0x30);
                     LCD_goto(2,0);
                 break;
                 case 2:
                 if (tmp == 0x02)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 3:
                 if (tmp ==0x03)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 4:
                 if (tmp ==0x04)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 5:
                 if (tmp ==0x05)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 6:
                 if (tmp ==0x06)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 7:
                 if (tmp ==0x07)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 8:
                 if (tmp ==0x08)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 9:
                 if (tmp ==0x09)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 10:
                 if (tmp ==0x0A)
                      LCD_goto(1,1);
                      data_to_dis(0x41);
                     LCD_goto(2,0);
                 break;
                 default: return;    // In the case of an incorrect value
            _delay_ms(50);        //lazy debounce
    }while(1);
    return 0;
You ignored the point Lee made? Each case: then tests if tmp==N but you already know it is equal because you wouldn't be in case N: otherwise.
 case 1:
                 if (tmp == 0x01)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 2:
                 if (tmp == 0x02)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
Instead:
                 case 1:
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 2:
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
Untested.
THere is no need for the IF statement as the CASE does this for you.
There are 2 main mistakes in your code (ok 3 if the "if" in the case count, either if or case ).
1:
             if (tmp ==0x10)
I guess you mean 10 and not 16! (10 hex).
2:
                 tmp = 0;
But you have no case for the value 0 !
1:
             if (tmp ==0x10)
2:
                 tmp = 0;
1 - agreed.  Although symptoms for current code would be to reset at 16th press not 12th.
2 - there is a default case to handle this
David
But OP don't want to get there!
Hello
Having changed the id 0x10 á 0x0A.
if (tmp ==0x0A)
                 tmp = 0;
case 10 is not dispayed.
No because the switch never see the value 10 because you have just changed it to 0!!!
You need to find out what you really want, and please remove all those "if"'s in the switch, (if you don't understand why, then study some C )
Etie,
CASE is essentially the same thing as IF when you use a SWITCH.
You are doing the same job twice the way you have things.
If you change it to 0x0B you will see all 10 cases.
David
As you don't seem to be getting the point:
             switch(tmp)
                 case 1:
                 if (tmp == 0x01)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 2:
                 if (tmp == 0x02)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
                 case 3:
                 if (tmp ==0x03)
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                 break;
        etc.
The bits in bold are completely pointless and should be removed:
             switch(tmp)
                 case 1:
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                    break;
                 case 2:
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                    break;
                 case 3:
                     LCD_goto(1,1);
                     LCD_goto(2,0);
                    break;
        etc.
The point is that a switch()/case: construct is almost exactly the same as if you had used:
            if (tmp == 1) {
                     LCD_goto(1,1);
                     LCD_goto(2,0);
            } else
            if (tmp == 2) {
                     LCD_goto(1,1);
                     LCD_goto(2,0);
            } else
            if (tmp == 3) {
                     LCD_goto(1,1);
                     LCD_goto(2,0);
        etc.
So you don't need both the switch/case stuff AND the "if (tmp==) ..." sutff too.
