3x4 keypad and Lcd Display
13 posts / 0 new
first of all this is my first post and i want to say a big "HELLO" to everyone...
well i think u can help me in my problem:
i need to programmize in C code an ATmega16 trough AVR STK500...i am using
>>the ATmelstudio7.0 compiler
>> LCD-display 4x16 character with first address =[0x80, 0xC0, 0x90, 0xD0]
>> Keypad look like this:
// "C6"   "C5"   "C4"
// COL6 COL5 COL4
//   1       2      3    ROW 1 "C3"
//   4       5      6    ROW 2 "C2"
//   7       8      9    ROW 3 "C1"
//   *       0      #   ROW 4 "C0"
I have tow problems
First
Then proceed with the programming. It must
First a memory area 4x16 in the RAM of the processor is described
and this memory area will be copied to the display.They will only work in this RAM space after eachIt is simply copied into the display, the display is only one.
Second
I need to used the 3x4 Keypad for future programming.
I found a suitable example keypad but something is missing because the code does not work.
Can someone tell me what is wrong in the keypad and hand part?
Below you will see the code.
-----------------------------------------  lcd.h --------------------------------------------
#define  F_CPU 4000000UL
#include <util/delay.h>
#include <stdlib.h>
#include <stdio.h>
#include <stdbool.h>
#include <string.h>
#ifndef LCD_H_
#define LCD_H_
#define LCD_Scrib                 PORTA
#define DataDir_LCD_Scrib    DDRA
#define LCD_Control              PORTB
#define DataDir_LCD_Control DDRB
#define LCD_RS           0
#define LCD_Enable     1
#define LCD_AkkuB2    2
#define LCD_AkkuB3    3
#define D_Sub                    DDRD
#define Sub_Control            PORTD
#define NOP() asm volatile("nop"::);
#define KEY_PIN           PINC
#define KEY_PORT        PORTC
#define KEY_DDR         DDRC
void instr_to_dis(unsigned char command);            //function:  Send a command
void date_to_dis(unsigned char character);            //function:  Send a character
void LCD_Print(char *string);
void LCD_init(void);
void LCD_goto(unsigned char x, unsigned char y);
void LCD_Akku(void);
void Aschluss_D_Sub(void);
void tasten(void);
uint8_t keyscan(void);
uint8_t key_debounce( void );
#endif /* LCD_H_ */
----------------------------------- ldc.c -----------------------------------
 * lcd.c
 * Created: 27.09.2016 14:07:05
 *  Author: Ngangoum
#include <stdlib.h>
#include <stdio.h>
#include "lcd.h"
const char Line_Address []={0x80,0xC0,0x90,0xD0};    // 4x16 lcd_Display
Aschluss_D_Sub()
    D_Sub = 0xFF;                    // PÓRTD as output
// void Tasten()
//     //Data_Tasten = 0x70;                //0b01110000 PCx(x=0,1,2 and 3 as input)
void LCD_Akku()
    DataDir_LCD_Control &= ~((1<< LCD_AkkuB2) | (1<< LCD_AkkuB3));    // B2 and B3 of input setting
    LCD_Control = 0x0C;                                                // 0b00001100
void LCD_init()
    DataDir_LCD_Scrib = 0xFF;                            //PortA is output (DDR=0xFF)
    DataDir_LCD_Control |= 1<<LCD_RS | 1<<LCD_Enable;    // E and RS of output an PORTB setting
    _delay_ms(100);
    LCD_Control = 0xFC;        // ob11111100 (rs & e of low )
    instr_to_dis(0x01);        //Clear Screen 0x01 = 0b00000001
    _delay_ms(2);
    instr_to_dis(0x38);        //Set Function 0b00001110 (8 bits interface, 2 line display and 5x7  dots Matrix)
    _delay_us(50);
    instr_to_dis(0x0C);        //Display on/off 0b00001111 (Display 0n, cursor 0n and Blinking 0n)
    _delay_us(50);
    instr_to_dis(0x80);        //Set DDRAM Address 0b10000000
    _delay_us(50);
    LCD_Scrib = command;
    LCD_Control &= ~(1<<LCD_RS);        // RS turn of 0 (instruction)
    LCD_Control |= (1<<LCD_Enable);        // E turn of  1
    NOP();
    NOP();
    LCD_Control &= ~(1<<LCD_Enable);    // E turn of  0
    _delay_us(100);
void data_to_dis(unsigned char character)
    LCD_Scrib = character;
    LCD_Control |= (1<<LCD_RS);            // RS turn of 1 (data)
    NOP();
    NOP();
    _delay_us(100);
/* Diese Funktion bewegt der Cursor (Zeile y ,Spalte x) an dem LCD Module*/
void LCD_goto(unsigned char y, unsigned char x)
    instr_to_dis(Line_Address[y-1] + x-1);
    _delay_ms(10);
    unsigned char i;
    while(string[i]!=0)
        data_to_dis(string[i]);                    // Send a character in string format
        i++;
//Berechnet Adresse für die Zeile und schreibt sie ins DD-Ram
unsigned char Memory(unsigned char row, unsigned char column)
        DataDir_LCD_Scrib = 0x80 ;                //PortA7 is output (DDR=0b10000000)
        instr_to_dis(0x80);                     // MSB = 1 set of DD-RAM
        row = Line_Address[row];
        row += column;
        instr_to_dis(row);
-------------------------------------tasten.c ---------------------------------------------------
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <stdlib.h>
#include "lcd.h"
// "C6"   "C5"   "C4"                            C6-->PINC6 ..
// COL6 COL5 COL4
//   1       2      3    ROW 1 "C3"            C3--> PINC3
//   4       5      6    ROW 2 "C2"              .
//   7       8      9    ROW 3 "C1"              .
//   *       0      #    ROW 4 "C0"             .
    uint8_t col = 0, row = 0;
    KEY_PORT |= 0x7F;                                // all pullups on (0b01111111)
    KEY_DDR = (KEY_DDR & 0x80) | 0x0F;    // pin 0..3 = input (0x70 =0b01110000)
    KEY_PORT &= 0x8F;                               // pin 0..3 = input low (0x8F =0b10001111)
    NOP();                                                  // wait until inputs sampled
    NOP();
    if( ~KEY_PIN & 1<<0 )                           // if pin 0 = low
    col = 4;
    if( ~KEY_PIN & 1<<1 )
    col = 3;
    if( ~KEY_PIN & 1<<2 )
    col = 2;
    if( ~KEY_PIN & 1<<3 )
    col = 1;
    row = col;
    if( col ){                                                   // if column found, check row
        KEY_DDR = (KEY_DDR & 0x80) | 0x70;  // pin 4..6 = output
        KEY_PORT &= 0xF0;                             // pin 4..6 = output low
        if( ~KEY_PIN & 1<<4 )
        row = 5;
        if( ~KEY_PIN & 1<<5 )
        row = 9;
        if( ~KEY_PIN & 1<<6 )
        row = 13;
    }                                                     // 0 = no key
    return row - col;                               // 1..12 = key
uint8_t key_debounce( void )                // should be called every 5 .. 50ms
    static uint8_t oldkey, debounce;
    uint8_t key = keyscan();
    if( oldkey != key ){
        oldkey = key;
        debounce = 4;
    if( debounce && --debounce == 0 )
    return key;
    return 0;
------------------------------------------   main ------------------------------------------
 * Pr5.c
 * Created: 08.09.2016 19:25:44
 * Author : Ngangoum
#include <avr/pgmspace.h>            //supports storing strings & arrays in flash
#include <avr/interrupt.h>            //supports interrupts
#include <stdlib.h>
#include "lcd.h"
    LCD_init();
//     LCD_Print("Eternel!");
//     LCD_goto(3,1);
    Memory(4,16);
    instr_to_dis(0x01);                        // Clear screen
    data_to_dis(key_debounce());        // Echo the key pressed to LCD
That's not much of a fault report. What did you expect to happen? What actually happened? Is the fault in the LCD output stuff or the keyboard input stuff? (and if you don't know you aren't developing in a modular way!)
In passing I would just point out that by default PC4..PC7 of a mega16 are not immediately usable as the chip comes with JTAG switched on and it uses those 4 pins. So what have you done about switching it off? I don't see any JTD writes in the code so I assume you have deactivated the JTAGEN fuse?
PS "Hallo" to you too!
Hey
thanks for your support
i haven´t  deactivated the  JTAGEN.
Currently I do not get anything on the display (no reaction after I had pressed on the keyboard buttons)
I want to use the Keyboard Buttons at the futury
for example:
Button 1 must allow me to display some message .
Button # must allow me to choose a value from a list.
device configuration
Well until you add lines to your program to write JTD twice or you change the state of that JTAGEN fuse you cannot use the top 4 bits of PORTC
Hey
Can you help me with an example, because I am still neophyte in C and micontroller.
I have shot the JTAG.
And then how do I go about to operate the touch keyboard.
    Memory(4,16);
Lcd needs ascii code.
E.g. you send number 8 to Lcd, but you have to send 0x38  (ascii(8) = 0x38)
For numbers 0-9 try
    Memory(4,16);
    data_to_dis(key_debounce() + 0x30);        // Echo the key pressed to LCD
That is true.
However I would like the reaction after you have pressed the button on the keyboard.
The keyboard does not react. That's my problem.
What should I do to make the functional keyboard.
for example:
I would like to display "N" position (4.1) if I press the button 1.
    NOP();
    col = 4;
    if( ~KEY_PIN & 1<<1 )          // is that right?
    col = 3;
    LCD_goto(4,1);
    LCD_Print("N");
    col = 2;
    col = 1;
    row = col;
        row = 5;
        row = 9;
        row = 13;
    }                                        // 0 = no key
        oldkey = key;
        debounce = 4;
    return key;
    return 0;
Can anyone help me with a 3x4 keyboard code that works and where I could use any of these button to display something.
Is this what you need?
/* KEYPAD
	COL1 ->	PA6
	COL2 ->	PA5
	COL3 ->	PA4
	ROW1 ->	PA3
	ROW2 -> PA2
	ROW3 ->	PA1
	ROW4 -> PA0
#define KEYPAD A	//KEYPAD IS ATTACHED ON PORTA (change as needed)
//Don't Touch the lines below
#define KEYPAD_PORT PORT(KEYPAD)
#define KEYPAD_DDR 	DDR(KEYPAD)
#define KEYPAD_PIN 	PIN(KEYPAD)
Function return the keycode of keypressed
on the Keypad. Keys are numbered as follows
[00] [01] [02]
[03] [04] [05]
[06] [07] [08]
[09] [10] [11]
Arguments:
	None
Return:
	Any number between 0-11 depending on
	keypressed.
	255 (hex 0xFF) if NO keypressed.
Precondition:
	None. Can be called without any setup.
uint8_t GetKeyPressed()
	uint8_t r,c;
	KEYPAD_PORT|= 0X0F;
	for(c=0;c<3;c++)
		KEYPAD_DDR&=~(0X7F);
		KEYPAD_DDR|=(0X40>>c);
		for(r=0;r<4;r++)
			if(!(KEYPAD_PIN & (0X08>>r)))
				return (r*3+c);
	return 0XFF;//Indicate No keypressed
//call from main like this
		key=GetKeyPressed();	//Get the keycode of pressed key
		LCDWriteIntXY(0,0,key,3);	//Print it at location 0,0 on LCD.
Edit: untested!
Thank you.
the code is fairly incomplete but I will fight to detect the problem.
I think this works. Hope it helps
