Atmel Sam D20 xplained Pro kits hung EDBG
8 posts / 0 new
Please help to withdraw from the state (Bootloader mode (idle) The power LED and the status LED blinks simultaneously). Atmel Studio 7 doesn't see Atmel Sam D20.
http://www.atmel.com/webdoc/atme...
The firmware is in the <studio install dir>\tools\edbg\edbg_fw.zip
:: Morten
К сожалению, я не совсем понимаю последовательность действий. atfw.exe за короткое время, работает и закрывается. Моя проблема началась с обновления samd20 платам xplained Pro наборы, и в 3 версии. Компания Atmel Студия аварийно завершился. Samd20 платам xplained Pro наборы и остался в состоянии "загрузчика режим (режим ожидания) светодиодный индикатор питания и индикатор состояния мигает в то же время"
Unfortunately I don't quite understand the sequence of actions. atfw.exe for a short time, runs and closes. My problem began with the update samd20 xplained Pro kits, and to 3 version. Atmel Studio emergency has terminated. Samd20 xplained Pro kits and was left in a state of "bootloader mode (standby) power led indicator and the status indicator flashes at the same time"
You need to run atfw from a command prompt. The syntax is 'atfw -t edbg -a ..\tools\edbg\edbg_fw.zip' (if you are running from the atbackend folder, if not you need to correct the path to the firmware archive).
:: Morten
Opened like You said from the command line atfw.exe. Received (please, specify tool type: edbgbootmode ATML1873061800008161). If I understand correctly ATML1873061800008161 you want to insert in the text box (Connect by serial number). Further Device Programming > Tool > ATML1873061800008161 > Apply. Interface settings > Set The result ...OK ...OK ...OK.
Target Voltage shows Read voltage 0.0 is outside selected device's operating range: 1,6 V to 3,6 V.
In the end, still in the mode Samd20 xplained Pro kits and the kits remained in "bootloader mode (standby) power led indicator and the status indicator flashes at the same time"
Perhaps this problem has no solution. Or need an external programmer?
Yes, you should type, as I said above 'atfw -t edbg -a ..\tools\edbg\edbg_fw.zip' to do a new firmware upgrade.
No, not at all... What on earth are you talking about? :)
Perhaps this problem has no solutionOr need an external programmer?
The solution is simple, perform a firmware upgrade.
See http://atmel.force.com/support/a... the support answer.
:: Morten
Thanks for the help! The firmware updated. Only had all the necessary files to collect in one folder.
