[CODE] [ASM] Long delay generation interrupt driven
5 posts / 0 new
Hi Freaks...
I used this code to generate long delay, i.e. 1 hour at 11,0592 MHz XTAL, using Timer0 interrupt.
This routine assign the AVR to toggle the LED when reach timeout.
include "m8535def.inc"
.def smtr = r16
.def menuju1dtk = r17
.def cacahdtk = r18
.def cacahmnt = r19
.cseg
.org 0
rjmp main
.org 0x009
rjmp melimpah
;------------------------ISR-------------------------------
melimpah:
		inc menuju1dtk
		cpi menuju1dtk, 43
		in smtr, SREG
		sbrc smtr, 1
		rcall sdh1dtk
		reti
sdh1dtk:
		clr menuju1dtk
		inc cacahdtk
		cpi cacahdtk, 60
		in smtr, SREG
		sbrc smtr, 1
		rcall sdh1mnt
		ret
sdh1mnt:
		clr cacahdtk
		inc cacahmnt
		cpi cacahmnt, 60
		in smtr, SREG
		sbrc smtr, 1
		rcall timeout
		ret
timeout:
		clr cacahdtk                     ;the delay reach timeout
		clr cacahmnt                    ; you can assign other
		in smtr, PORTD
		com smtr
		out PORTD, smtr
		ret
main:
		ldi smtr, high(RAMEND)
		out SPH, smtr
		ldi smtr, low(RAMEND)
		out SPL, smtr
;aktifkan timer
		clr menuju1dtk
		clr cacahdtk
		clr cacahmnt
		ldi smtr, 0b00000101
		out TCCR0, smtr
		ldi smtr, 1
		out TIMSK, smtr
		;ldi smtr, 250
		;out TCNT0, smtr
		sei
		ser smtr
		out DDRD, smtr
		ldi smtr, 0xF0
		out PORTD, smtr
loop:
		rjmp loop       ;this is your main routine
;----------------------------------------end of code-----------------------------------
The important values are :
43 in cpi menuju1dtk, 43 -> obtained by calculate 1 second / tme needed to overflow of Timer0
60 in cpi cacahdtk, 60 -> to obtain 1 minute delay (60 seconds)
60 in cpi cacahmnt, 60 -> to obtain 1 hour delay (60 seconds)
The delay can be longer if you change the above values with the higher number. :)
Just one question,
Can you hightlight the text of the code and then hit the code button. For me, anyway, it makes the code much easer to read due to the additional formating.
Thanks.
Thanks Carl,
What did you mean?
I don't understand
Already did it for you this morning :).
What Carl means is when you post code, use the "Code" tags so that the forum software formats your code so that it remains readable (see your original post to see how the code tag formats your code differently. You should encase your code in [ code ] and [ /code ] tags (no spaces).
- Dean :twisted:
Oh I see
Thans Dean. The Code Tags, .... yes I see it.
Maybe next time when I post something, I'll remember it.
