SAM 70E support in SAM-BA
7 posts / 0 new
Hi everyone !
SAM-BA tool is listed on SAM70E tools page, but the tools itself does not list this family as being supported.
How about this family support ?
That is really great...
Well, after finding all the information scattered all over the documentation, I wrote my own tool in Java that does device flashing.
It's not complete yet, but at least I can upload program to the device and run it there. So if anyone needs it, please contact me.
Hey,
I'm having the same problem. Really trying to figure out if I can program a SAM E70 device using SAM-BA.
Do you have any updates on this?
I'll message you to get the Java code you used to program the device.
Thanks!
http://www.atmel.com/Images/Atme...
Refer the above link. It helps you to customise the SAM-BA Tool..
I wonder if there is a tool to erase the flash once the control transferred to Flash.
Hello everybody,
I'm facing the same issues regarding this tool (sam-ba) with this kit (same70).
It is suposed to work but I can't go beyond  this point using the 3.14 version:
C:\Users\1033\Desktop\sam-ba_3.1.4>sam-ba -x flash-usb.qml
Opening serial port 'COM4'
Error: Could not switch monitor on port 'COM4' to binary mode
Connection closed.
I have erased the flash and I'm using the TARGET_USB (connected to the COM4) port in my computer but can't get past this point.
Am I missing something? Some important step? All I did was erasing the Flash memory (used the Atmel Studio tool to do it), restarted the development kit and tried to run the sam-ba via command line (in windows).
I tried to connect to the UART0 pins (PA9 and PA10) to programm the Flash(serial programming instead of USB), but no luck. My External clock is 12Mhz so USB should work.
I also tried to use the sam-ba version 2.16 and select the "at91same70-xplained" option but I'm getting  the error:
Invalid chip ID - Can´t connect at91same70-xplained
Can somebody help me with this? Anyone got similar problems?
Best regards
make sure the tcl file contains the correct chip ID
looks like the communication is ok but it fails on the chip identification step
The FOSS (GPL2) Micro SAM-BA has SAM E70 :
https://github.com/atmelcorp/micro-sam-ba
Micro SAM-BA
This simple tool can be used to program the internal flash of the following microcontrollers:
  • Atmel SAME70/S70/V70/V71
Communication with SAM-BA bootloader is only supported through USB.
