SCK and SPI question ?
30 posts / 0 new
Guys,
Is the right SCK clock on my SPI bus ?
I tried to see in Logic analyzer, some of them can't be read properly....
Am I sending the right SCK clock or wrong one ? Why isn't SCK constantly sent per byte ?? I can see only 4 edges per byte ?
How to fix it ?
Please have a look on the picture :
The code :
void VS1003B_SPI_Low(void)
	SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1)|(1<<SPR0);
	SPSR = (0<<SPI2X);
//ÒÔFCK/4ËÙ¶ÈÔËÐÐ	//full speed
void VS1003B_SPI_High(void)
	SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR1)|(0<<SPR0);
    SPSR = (1<<SPI2X); //fosc/2
unsigned char VS1003B_WriteByte(unsigned char CH)
	SPDR = CH;
	while(!(SPSR & _BV(SPIF)));
	return SPDR;
//´ÓVS1003¶ÁÒ»×Ö½Ú		//read one byte from vs1003
unsigned char VS1003B_ReadByte()
    SPDR = 0xff;
 	return SPDR;
I need something like this :
Any clues ?
How fast is sck and how fast are you sampling it? If the answer is 8MHz and 12MHz, then that is the answer - the logic analyser is not showing what is really happening. Up the sample rate and/or decrease the sck rate.
so my sampling speed must be 8Mhz ? since my sck speed is 8 Mhz ? thanks
Your sampling rate will have to be at least 2 times, probably more like 4 times, the SCK frequency.
SpiderKenny
@spiderelectron
www.spider-e.com
if I use 16MHz sampling, it stops in the middle and asks me for reducing the sampling frequency...why is that ??
So for sending 8 bits data, I need 8 edges SCK, am I right ?
I put SPI analyzer on, but I can't see byte value, why is that ?
Please have a look :
Why is that? I'd guess at the settings for the spi analyser.
Which setting should I change ? thanks
You have selected xcs as the enable. It seems to stay high in your picture, thus the software is not expecting any data. Maybe you want xdcs?
Saleae Logic Analysers work very well. They do rely on sending lots of traffic on USB. If your PC is slow or just busy with other tasks, you need to reduce the sampling frequency. Or make sure that your PC is not doing other things.
In practice, it is easier to debug SPI at 4MHz. Once you are happy with 4MHz, go with 8MHz and 24MHz sample frequency.
Not much of a problem with AVR. ARM or Xmega can go faster than the Saleae can manage.
You're right, suppose to be XDCS, how can I see the array is sent properly on SPI....because so many bytes on SPI now...
I want to check :
const unsigned char HelloMP3[] __attribute__ ((progmem))= {
	0xFF,0xF2,0x40,0xC0,0x19,0xB7,0x00,0x14,0x02,0xE6,0x5C, /* ..@.......\ */
	0x01,0x92,0x68,0x01,0xF1,0x5E,0x03,0x08,0xF0,0x24,0x80, /* ..h..^...$. */
	0x05,0x9E,0x20,0xC6,0xFC,0x12,0x32,0x5C,0xBF,0xF9,0xB9, /* .. ...2\... */
thanks
The salae logic can grab as much data that can fit on your hard disk. So you can check each byte if you want to. Personally, i'd be checking only a few and verifying your code sends at the right time.
The trick with Saleae is to use a spare GPIO pin and wiggle it just before the sequence you want to observe.
Either use the wiggle to Start or simply click either side of the wiggle channel to find the next wiggle.
Or learn to recognise the patterns at low resolution. Then zoom in to find your sequence of interest.
The software will decode the SPI for you. You should see the FF, F2, 40, ... clearly displayed.
I tried to do sine test....it's sending byte properly but I can not hear 1kHz beep on and off....anything missing here ?
The delay between ON and OFF, I saw it, 10 uS
Code :
 /** VS10xx Sine Test Function - Good getting started example */
    void VsSineTest(){
        unsigned int i;
	    /* Reset MP3 chip */
	   /* Pull xRESET low -> hardware reset */
	    VS1003B_XRESET_L();
		_delay_ms(100);            /* 100 ms delay */
	    /* Send dummy SPI byte to initialize SPI bus of Atmel microcontroller */
	    VS1003B_WriteByte(0xFF);
	    /* Un-reset MP3 chip */
	    VS1003B_XCS_H();
		/* Pull xCS high    */
	    /* Pull xDCS high   */
	    VS1003B_XDCS_H();
		 /* Pull xRESET high */
	    VS1003B_XRESET_H();
        PORTD = 0xFF;
	    /* VS10xx Application Notes, chapter 4.8 ---------------------------------*/
	    /* As an example, let's write value 0x0820 to register 00 byte by byte    */
	    //VS1003B_XCS_L();
		 /* Pull XCS low, now SPI writes go to SCI port     */
	    //VS1003B_WriteCMD(SCI_MODE,0x0820);
		//VS1003B_WriteCMD(SCI_VOL,0x0000); //max volume
		 /* Send SPI Byte, then wait for byte to be sent.   */
	     /* 0x02 was WRITE command, 0x00 is register number */
	     /* This byte goes to MSB                           */
	     /* ..and this is LSB. (0x20=Allow Test Mode)       */
	    VS1003B_Delay();
		 /* Wait until Atmel MCU signals SPI write complete */
	    VS1003B_XCS_H();
		/* Pull XCS high, now SPI writes don't go to SCI port. */
       	while ((bit_is_clear(VS1003B_PIN,VS1003B_DREQ))) {
	       	// Do nothing while waiting for DREQ
			   _delay_ms(100);
	    /* pull XDCS low, now SPI writes go to SDI port    */
		VS1003B_XDCS_L();
		/* Send a Sine Test Header to Data port*/
		VS1003B_WriteByte(0x53);
		VS1003B_WriteByte(0xef);
		VS1003B_WriteByte(0x6e);
		VS1003B_WriteByte(0x44);
		VS1003B_WriteByte(0x00);
		      /* - This is a special VLSI Solution test header - */
	          /* - that starts a sine sound. It's good for     - */
	          /* - testing your code and the chip. */
		VS1003B_Delay(10);
	    // _delay_ms(150);           /* 1500 ms delay */
	    VS1003B_XDCS_H();
	    //_delay_ms(500);           /* 500 ms delay */
       VS1003B_Delay(10);
	   PORTD = 0x00;
	    /* Stop the sine test sound */
		 VS1003B_XDCS_L();
		VS1003B_WriteByte(0x45);
		VS1003B_WriteByte(0x78);
		VS1003B_WriteByte(0x69);
		VS1003B_WriteByte(0x74);
		VS1003B_Delay(100);
        VS1003B_XDCS_H();
Your delay is suspect. Do you really to expect to hear something 10us wide?
That's what I've been wondering....
How much delay do I need ? Where should I put it ?
Sorry, you've already used up your three questions on very obvious things. Time for you to do some work methinks.
I've put 500 ms delay on between...but still I can't hear beep, I can see the delay on logic analyzer but...not in my earphone...??
May be my earphone is not sensitive enough ?
What?????
Total votes: 4
The problem might be something that lies between the earphones.
Is it possible that my earphone doesn't response properly ? I'll see the output at scope then....
Sounds familiar: http://8052.com/forumchat/read/1...
wink
I can hear "teng" ....."teng"....."teng" with this code :
while (p <= &HelloMP3[sizeof(HelloMP3)-1])
			//loop_until_bit_is_set(VS1003B_PIN,VS1003B_DREQ);
			if(bit_is_set(VS1003B_PIN,VS1003B_DREQ))  //send data  honoring DREQ
				//waitspi();
				for (i=0; i<32; i++)
					VS1003B_WriteByte(pgm_read_byte(p++));
				    _delay_us(1);
				}//end for
		      }//end if
		}//end while
Is it possible if my SPI transfer is too fast ? I'm using f osc /2 = 8MHz....?
again, you ask questions you can easily answer yourself.
is the spi transfer too fast?  refer to the vs1003 data sheet. or simply try it slower.
did you get the sine wave test working? if not, it's worthless going any further.
It could be related with clock related multiplier, I changed the multiplier and it produces a different tone...
The external clock multiplier SCI register SCI_CLOCKF, which has changed slightly since
VS1003 and VS1033, is presented in the table below.
I don't understand which multiplier is suit with my application, my external crystal is 12.228 MHz
I set the value :
#define CLOCK_REG       0x0800
Any ideas ?
At a guess, I'd say 0x6800. You might want to see what the Arduino (or other example code) does.  The test frequency is supposed to be 1kHz, so that can be used to verify. The spi speed has to be slow until you set the clock multiplier.
Yes I used fosc / 128 for setting up CLOCKF....
I changed to 0x6800....still the same ...produced "ting" "ting" "tuck" "tuck"....when I see at logic analyzer...it's sending the correct byte....it means it decodes wrongly because of the wrong speed, I reckon....
How do you reckon ?
it works now with VS1003, but strangely, it doesn't work with VS1053....anything I miss here ?
That is surely a question to pose in a VLSI support forum. I think you'd be lucky to find anyone here who has experience of both 1003 and 1053.
Yes. Why you didn't say which chips you were using in your original post and you finally get around to it after 14 posts. You can type "VS1053 tutorial" into google and find plenty of help there.
