One Wire Data Sender Chip
7 posts / 0 new
Hello guys
I am working on  a PROJECT which I have to identify Some different (metallic) nuts.
I thought using hall sensors might be the best choice ,but I found it usable!
I heard there is Some kind of chips which are tiny and can connect to micro by one wire protocol and they just send an ID like a RFID tag.
  Does anybody USED that or knows about it?
Ehsan
EDIT: Moved to General Electronics. Moderator.
You can DO EVERYTHING!
Just believe yourself !!!
Are you thinking of the Maxim (formerly Dallas Semiconductor) 1-WireTM devices?
http://www.maximintegrated.com/e...
Specifically, the DS2401 "Silicon Serial Number" - http://www.maximintegrated.com/e...
Other 1-WireTM identification parts: http://para.maximintegrated.com/...
Note that these are essentially the same as what's inside the iButton devices: http://www.maximintegrated.com/e...
https://en.wikipedia.org/wiki/1-...
You do need two wires though!
Well, you need something to provide the "ground" reference - may not necessarily need to be a separate wire; but you will need some sort of connection.
eg, chassis.
And some "1-Wire" devices can use three wires!
surprise
Thank you
Can I use one wire with a IR LED ??????
I  mean transmit it by IR led????
Not with just an IR LED.
These devices need to work as slaves to a "host" - so you'd have a microcontroller "host" reading the ID chip, and then transmitting what it read over the IR link ...
Edit:
If you're going to use a microcontroller anyhow, choose one with a built-in unique ID - then you don't need an external ID chip!
smiley
http://www.avrfreaks.net/forum/h...
Why not just use RFID? You can get tags with stickers. Or barcodes?
