converting adc results to decimal display
5 posts / 0 new
I need to convert the result from my atmega328 ADC to a format where I can display it on a seven segment display. I am using a 5V reference for the ADC (which is 10 bit) so 1 bit = 5/1028=4.89mV . I have to multiply the result form the ADC by this number to get the actual voltage in, but I want the result to be as accurate as possible - I don't want to round up to 5.
What are some ways I can do this? Do i have to use fixed / floating point maths?
value_mv = (read_value *5 *(uint32_t) 1000)/1024;
Every multiplications are done first, without loss of precision; read_value has 10 bits; 1000 is ten bits, too; product -23 bits - fits into 32 bits;
BTW : what is the accuracy of your supply/reference "5v"
5.0V/1024=4.8828mV
Multiply ADC result by 4883UL and display the high order decimal digits.
Anyone remember International Theophysical Year?
Someone, please answer "Yes."
Note that when you have fixed values like this, I always look for the simplifications.  5000/1024 is the same as 625/128.  625*1023 just fits into uint16_t.
[In a trivial test program, the inclusion of 32-bit operations doesn't matter much for cycles and space.  FP could be used.  But in a "full" e.g. Tiny or Mega48 app it can make a sizable difference.]
There is an age-old debate about the /1023 and /1024, and whether the ADC result should ever be 5.00V for a 5.00V signal and a 5.00V reference.  A 0-5V control signal from the outside world rarely reaches each extreme.  For a "voltmeter" app I usually call below 10 counts or so 0V, and 1000 counts over that (and above) 5V, so 5mV/count.  In practice that works quite well.
If arithmetic simplification as I did above isn't as clear cut, I have a VisualBASIC (and C#) program that tries all possible usable ratios.  In nearly all cases, one can find a ratio of small numbers that is good to many decimal places and obviates the need for wider arithmetic.  Let me try an example:  Let's say in this case we want 5000/1023 which has no obvious simplification...to stay within 16 bits with 1023 ADC counts:
4.887585533 8.5533E-005 ==> 391 / 80
4.887585533 5.4916E-005 ==> 435 / 89
Thanks Theush : I did not dare to simplify (makes things unpleasant to read... and typo-prone ) but using unsigned integers instead of unsigned longs / uint32_t  avoids a multiplication and makes division 4 times faster -and shifts (1024 is a power of 2 ) 2 times faster- ....
