optimization problem
10 posts / 0 new
Compiling code for an ATMega328 with AVRStudio4, using avrgcc tools.
I tried to turn on the pullup on PD4 (pin 6). It wouldn't turn on,
unless I also set the pullup on PD1.
Here is the C code, and the generated assembly from the .lss file:
(Data direction register already set).
PORTD |= 0x00010000;
 EC6:  8b b1  in r24, 0x0b
 EC8:  8b b9  out 0x0b, r24
(this code doesn't set the PD4 pullup)
PORTD |= 0x00010010;
 EC6:  5c 9a  SBI 0x0b, 4
(this code does set the PD4 pullup)
Turning the optimization level from -Os to O0 makes the thing work, but greatly increases code size.
How could either of the above be correct compilations?
Thanks for any thoughts,
Jack
Please post your complete program by clicking on the <> in the taskbar of the editor and pasting your code in the window that pops up.
The internal pullups are usually set once only.  To use the pin as an output you write to the DDR register to set the PORT pin direction to output.  Then you can write the value to PORT pin to see it go high or low.
Any reason why you are using the very old AVR Studio 4 and not the most recent Atmel Studio 6.2sp2?
"Make XMEGA Great Again!"  - Greg Muth
Did you really want 0x? Maybe 0b?
Good eye, I totally missed that!
What he has in the first instance is PORTD |= 0x00;  and in the second is PORTD |= 0x10;
+1
Since PORTD expects an 8-bit quantity, the rest is truncated.  So this:
... becomes this:
PORTD |= 0x00;
... which is synonymous with this:
PORTD |= 0b00000000;
Whereas this:
... becomes this:
PORTD |= 0x10;
... which is synonymous with:
PORTD |= 0b00010000;
"Read a lot.  Write a lot."
We can always count on Joey for being more precise.wink
I'm not using the pin as an output, but as an input, depending on the internal pullup resistor.
I'm setting them at this point in the program because some initialization code, for the LCD or for
the low-speed USB port, doesn't leave stuff in the state I need to use pins not otherwise needed
as switch inputs.
I can work around this now; I just wondered how the compiler could come up with the assembly above.
(I'm using AVRStudio 4 because on my older machine running XP3, it takes a long time to start up,
and I don't want to spend the time getting familiar with a new environment.)
Wholly mackerel! Of course, you're right; a bone-headed mistake.
Thanks!
Jack
...it's reliable and it works... wink
I'm using AVR Studio 4 because it's reliable
-and it works,
-and because it doesn't take two+ minutes to load on a PC that has a multi-gigahertz CPU  and fast hard drive,
-and because it doesn't load millions of bytes worth of program code to support every possible type of CPU in Atmel's company library,
-and because I have already learned how to use it productively (instead of spending hours learning Studio 6 which does the same thing as Studio 4 but has a completely different user interface).
