"Build a serial controlled lcd" - question
7 posts / 0 new
Hi Eric,
I have had a look at your project http://8515.avrfreaks.net/index....
[ I found this to be a better link: http://www.avrfreaks.net/index.p... ]
You have not connected anything to pin 3 of the LCD display. This is "usually" connected to a potentiometer for adjusting the display's contrast.
Comment?
Cheers,
Ross
This looks like microcarls serial backpack with some added features
Maybe ... in any event the OP has disappeared after reading my PM. Maybe he doesn't answer questions.
Hmmm..
I wasa not saying he ripped the idea off. Carl used the same part for the same thing except he did not support i2c or spi.
Just noticed that there is something for sale in the Trading forum that runs along these lines.
If I remember correctly, I used all of PB7:PB0 to control the LCD and LED backlight. I had a level converter between the PCB RxD connector pin and RxD on the ATtiny 2313.
Even if my design was lifted, mass produced and sold for profit, I placed i the thing in the public domain when means I no longer have any control over what happens - my one and only gift to the world, I suppose...
I'm actually thinking about a re-do of the MyLCD project, adding Tx & Rx interrupts and Tx & Rx buffers of up to 256 bytes per side and an improved LCD driver.  Of course, then, I won't be using an ATTiny2313.  More likely, I'll be using an ATMega328P.
I'm still not too keen on adding TWI or other connection interfaces as, I mostly use RS232 and TTL interfaces.
