[C] Simple SPI "library"
3 posts / 0 new
  After a while spent trying to find out about the SPI capability of AVRs, I decided the best way to learn was to create my own library (an approach I have found works very well for beginners). I found an excellent example at https://sites.google.com/site/qe... and quickly turned it into a header file for easy reuse, adding a little more functionality for my own purposes. Since I am new to coding in raw C (I have escaped from the clutches of the Arduino IDE!), I thought it would be a good idea to see what the community here thinks of it, and if they have any advice to improve it. I also don't have the means to test it at the moment (that I am aware of), so I would appreciate it if anyone could try it out, following a successful build in ATMEL Studio 6. SPI.h is as follows:
 * SPI.c
 * Created: 20/12/2014 14:40:18
 *  Author: Benedict
#ifndef SPI
#define SPI
#ifndef csPORT
# warning "Define csPORT (default PORTB)"
#define csPort PORTB
#endif
#ifndef cs1
# warning "Define cs1 if needed"
#define cs1 0
#endif
#ifndef cs2
# warning "Define cs2 if needed"
#define cs2 0
#endif
#ifndef cs3
# warning "Define cs3 if needed"
#define cs3 0
#endif
char dataIn;
void spiInitMaster(void){
	DDRB |= (1<<2)|(1<<3)|(1<<5);    // SCK, MOSI and SS as outputs
	DDRB &= ~(1<<4);                 // MISO as input
	csPort |= (1<<cs1) | (1<<cs2) | (1<<cs3);//Set slaves high
	SPCR |= (1<<MSTR);               // Set as Master
	SPCR |= (1<<SPR0)|(1<<SPR1);     // divided clock by 128
	SPCR |= (1<<SPE);                // Enable SPI
void spiInitSlave(void){
	DDRB &= ~((1<<2)|(1<<3)|(1<<5));   // SCK, MOSI and SS as inputs
	DDRB |= (1<<4);                    // MISO as output
	SPCR &= ~(1<<MSTR);                // Set as slave
	SPCR |= (1<<SPR0)|(1<<SPR1);       // divide clock by 128
	SPCR |= (1<<SPE);
int spiReceive(void){//Call in while(1)
	while(!(SPSR & (1<<SPIF)));    // wait until all data is received
	dataIn = SPDR;
	return dataIn;
void spiTransmit(char dataOut, int slavePin){//Call in while(1)
	csPort &= ~ 1<<slavePin;
	SPDR = dataOut;                 // send the data
#endif
Thank you to anyone who takes the time to read this!
First its a fine beginning but not a complete library of code.
There is no selection of clock speed,
only one out of four possible spi modes,
the read/write functions are incomplete, ie. a slave read, but no slave write, visa versa, a master write, but no master read.
Only polling mode, no interrupt operation.
I would say keep working on it and post your results in the mega forum, as this does not seem to be a tutorial.
Ask questions if you get stuck.
Quite honestly,   SPI initialisation is only PORTB, DDRB, SPCR, SPSR.    i.e. four simple assignments.
The SPI invocation is a single uint8_t spi_xfer(uint8_t c) function.  i.e. another three lines.
The pin usage varies with AVR model .  So it is difficult to make anything universal.
Just stick to simple code with a comment (when necessary)
