[SOLVED] ATMEL AVR ATMEGA32 AND MCP23017 I2C I/O EXPANDER
13 posts / 0 new
Hi all,
   Good day.  interfaced MCP23017 I2C I/O port expander with Atmega32. and my reference link is  http://www.ermicro.com/blog/?p=1050. its working fine with MCP23S17 SPI I/O enpander. but its not ok with i2c expander. I am not getting the continuous output. If i pressed the button, i want to write and then read (led's on). But i am getting one time read only.
At this time output is:
in main
       write
            w_data=0x28
                       write
                            w_data=0x0
                                      write
                                           w_data=0xff
                                                      write
                                                           w_data=0xff
        write
        w_dat
a=0x0
     in loop
            read         inp: 0xff
                                  in loop
                                         read
if i pressed button, then it was stopped with write loop it self.
in main
                                                    write
                                                         w_data=0x28
        write
        w_data=
0x0
   write
        w_data=0xff
                   write
                        w_data=0xff
                                   write
                                        w_data=0x0
                                                  in loop
                                                         read    inp: 0xfb
        togbut
:0x1
    write
If i removed the ground connection to the mcp23017, then i am getting continuous loop message.
 write_I2C_SLAVE_WRITE failed..
                                       read
                                           read_I2C_SLAVE_WRITE failed..
        pat_coun
t_1: 0x1
        count: 0
                in loop
                       read
                           read_I2C_SLAVE_WRITE failed..         inp: 0x1
        write
        wr
                            read
                                                             pat_count_1: 0x3
        cou
nt: 1
     in loop
            read
                                                         write
                                                              write_I2C_SLAVE_WR
ITE failed..
            read
                                             pat_count_1: 0x4
                                                             count: 2
        in loop
        read
                                         write
        read
                             pat_count_1: 0x8
                                             count: 3
                                                     in loop
                                                            read
        read_I2C_SLAVE_W
                         write
                                                            read
        read_I2C_SLAVE_W
RITE failed..
             pat_count_1: 0x10
                              count: 4
                                      in loop
                                             read
inp: 0x1
        write
                                           read
        pat_
count_1: 0x20
             count: 5
                     in loop
                            read
        write
        wr
                            read
                                                             pat_count_1: 0x40
        co
unt: 6
      in loop
             read
                                                         write
                                                              write_I2C_SLAVE_WR
ITE failed..
            read
                                             pat_count_1: 0x80
                                                              count: 7
        in loop
        rea
d
                                         write
        read
                             pat_count_1: 0x0
                                             count: 8
                                                     in loop
                                                            read
        read_I2C_SLAVE_W
                         write
                                                            read
        read_I2C_SLAVE_W
RITE failed..
             pat_count_1: 0xff
                              count: 9
                                      in loop
                                             read
inp: 0x1
        write
                                           read
        pat_
count_1: 0x0
            count: 10
                     in loop
                            read
        write
        wr
                            read
                                                             pat_count_1: 0xff
        co
unt: 11
       in loop
              read
                                                         write
                                                              write_I2C_SLAVE_WR
ITE failed..
            read
I am not getting where the problem is, whether in code or in hardware.
 * MCP23017_I2C_IO_EXPANDER.c
 * Created: 11/11/2014 10:40:57 AM
 *  Author: Dev5
#define F_CPU 8000000UL
#include <avr/pgmspace.h>
#include <util/delay.h>
#include <stdio.h>
#include "UART_routines.h"
#include "i2c_routines.h"
//ATMEGA32_I2C_PORT
//#define I2C_PORT PORTC
//#define I2C_DDR  DDRC
//MCP23017_SLAVE_ADDRESS_I2C_INTERFACE
#define I2C_SLAVE_WRITE 0x40
#define I2C_SLAVE_READ  0x41
// MCP23017 Registers Definition for BANK=0 (default)
#define IODIRA 0x00
#define IODIRB 0x01
#define IOCONA 0x0A
#define GPPUA  0x0C
#define GPPUB  0x0D
#define GPIOA  0x12
#define GPIOB  0x13
//TWI initialize
// bit rate:18 (freq: 100Khz)
void twi_init(void)
	TWCR= 0X00;  //disable twi
	TWBR= 0x12;  //set bit rate
	TWSR= 0x03;  //set prescale
	TWCR= 0x44;  //enable twi
}   //end of twi_init()
void init_devices(void)
	uart0_init();
	twi_init();
}   //end of init_devices()
unsigned char i2c_read(unsigned char addr)
	//char temp_r[20];
	unsigned char errorStatus;
	unsigned char rd_data;
	transmitString("\nread");
	errorStatus = i2c_start();
	if(errorStatus == 1)
		transmitString("\nread_i2c start failed..");
		i2c_stop();
		return(1);
	errorStatus = i2c_sendAddress(I2C_SLAVE_WRITE);
		transmitString("\nread_I2C_SLAVE_WRITE failed..");
		i2c_stop();
		return(1);
	errorStatus = i2c_sendData(addr);
	//sprintf(temp_r,"\nr_addr=0x%x",addr);
	//transmitString(temp_r);
		transmitString("\nread_address failed..");
		i2c_stop();
		return(1);
	errorStatus = i2c_repeatStart();
		transmitString("\nrepeat start failed..");
		i2c_stop();
		return(1);
	errorStatus = i2c_sendAddress(I2C_SLAVE_READ);
		transmitString("\nread_I2C_SLAVE_READ failed..");
		i2c_stop();
		return(1);
	rd_data = i2c_receiveData_ACK();
	//sprintf(temp_r,"\nrd_data=0x%x",rd_data);
	//transmitString(rd_data);
	i2c_stop();
	//_delay_ms(1000);
	return rd_data;
}   //end of i2c_read()
unsigned char i2c_write(unsigned char addr, unsigned char data)
	char temp_w[20];
	transmitString("\nwrite");
		transmitString("\nwrite_i2c start failed..");
		i2c_stop();
		return(1);
		transmitString("\nwrite_I2C_SLAVE_WRITE failed..");
		i2c_stop();
		return(1);
	//sprintf(temp_w,"\nw_addr=0x%x",addr);
	//transmitString(temp_w);
		transmitString("\nwrite addr failed..");
		i2c_stop();
		return(1);
	errorStatus = i2c_sendData(data);
	sprintf(temp_w,"\nw_data=0x%x",data);
		transmitString("\nwrite data failed..");
		i2c_stop();
		return(1);
	i2c_stop();
	//transmitString("\nwrite_end");
	return (0);
}   //end of i2c_write()
	unsigned char togbutton,inp;
	unsigned int cnt;
	char temp[20];
	char pattern[12] = {0b00000001,0b00000011,0b00000100,0b00001000,0b00010000,0b00100000,
						0b01000000,0b10000000,0b00000000,0b11111111,0b00000000,0b11111111};
	init_devices();
	_delay_ms(1000);
	transmitString("\nin main");
	//I2C_DDR = (1<<PC0)|(1<<PC1);
	PORTC = 0x00;
	DDRC = 0xFF;
	// Initial the MCP23017 I2C I/O Expander
	i2c_write(IOCONA,0x28);   // I/O Control Register: BANK=0, SEQOP=1, HAEN=1 (Enable Addressing)
	_delay_ms(500);
	i2c_write(IODIRA,0x00);   // GPIOA As Output
	_delay_ms(500);
	i2c_write(IODIRB,0xFF);   // GPIOB As Input
	_delay_ms(500);
	i2c_write(GPPUB,0xFF);    // Enable Pull-up Resistor on GPIOB
	_delay_ms(500);
	i2c_write(GPIOA,0x00);    // Reset Output on GPIOA
	_delay_ms(500);
	togbutton=0;              // Toggle Button
	cnt=0;
	_delay_ms(100);
        //TODO:: Please write your application code
		transmitString("\nin loop");
		inp = i2c_read(GPIOB);		               // Read from GPIOB
		sprintf(temp,"\t inp: 0x%x",inp);
		transmitString(temp);
		_delay_ms(500);
		if (inp == 0xFB)         //(inp != 0xFF)               // Button(GPIOB2) is pressed
			_delay_ms(1);
			togbutton^=0x01;
			sprintf(temp,"\ntogbut:0x%x",togbutton);
			//if (togbutton == 0x00)
				//i2c_write(GPIOA,0x00);            // Write to MCP23017 GPIOA
				//cnt=0;
		}      // end of if (inp == 0xFB)
		if (togbutton > 0x00)
			//_delay_ms(200);
			i2c_write(GPIOA,pattern[cnt]);   // Write to MCP23017 GPIOA
			_delay_ms(500);
			i2c_read(GPIOA);
			sprintf(temp,"\npat_count_1: 0x%x",pattern[cnt]);
			sprintf(temp,"\ncount: %d",cnt);
			_delay_ms(500);
			cnt++;
			if (cnt >= 12) cnt=0;
		}      // end of if (togbutton > 0x00)
		_delay_ms(2000);
	return 0;
Thanks & Regards,
Sasi
GO GREEN
Why do you put series resistors in series with the I2C lines?????
The 4k7 resistors, if connected as shown in the schematic, are not connected as pull-ups. Without them, the I2C will not work properly.
sorry js. that is pull up resistor. by mistake i drawn in series.
Thanks & Regards,
Sasi
GO GREEN
sorry brain. that is pull-up resistor.  by mistake i drawn in series.
Thanks & Regards,
Sasi
GO GREEN
Do you think that communications between the chip and the micro is OK then? Do you have a debugger to see where the code is getting stuck?
Are the output pins getting programmed as outputs? Easy to check, if the pins are low and you put a 1K resistor to VCC on one of the pins then the LED should stay off and the pin should stay at zero or close. Otherwise the chip is not being initialised correctly.
yes output pins(GPIOA) programmed as outputs. then as per your point i connected 1K resistor between VCC and LED(+).
In output side (GPIOA-0x00(as per datasheet)) while power up, led is on and while started to write to register led off.
In input side (GPIOB-0xFF(as per datasheet)) while power up, led is on until power-down it is in on state only.
So what the problem is? code or circuit? i am not getting which one is fault.
Thanks & Regards,
Sasi
GO GREEN
I always advise people to use respected I2C libraries.
Then all we need do is look at a few lines of main()
It is generally fairly obvious where you have called a library function with the wrong arguments.
This is because you should always NAK the last read.      Your enormous functions do not do this properly.
I have not used either of those M*crochip expanders.     If you can use the SPI version,    then the I2C version should be very similar.
e.g.   write a value to a specific register.
e.g.   read a value from a specific register.
Both of those 'helper' functions are easy to implement with Fleury, Procyon, Codevision,   Arduino, ...
Edit.   Please can you correct your schematic.     i.e.  put the pull-up resistors in the right place.
yes david. i will do it now.
Thanks & Regards,
Sasi
GO GREEN
yes david now it is working fine. the problem is because of NAK the last read.
the change is
unsigned int totalChar = 1;
for(i=0;i<totalChar;i++)
        //      transmitString("in loop");
        if(i == (totalChar-1))       //no Acknowledge after receiving the last byte
        rd_data = i2c_receiveData_NACK();
 *  Author: Dev5
#include <stdio.h>
//ATMEGA32_I2C_PORT
#define IODIRA 0x00
#define IODIRB 0x01
#define IOCONA 0x0A
#define GPPUA  0x0C
#define GPPUB  0x0D
#define GPIOA  0x12
#define GPIOB  0x13
//TWI initialize
void twi_init(void)
	uart0_init();
	twi_init();
	char temp_r[20];
	unsigned int totalChar = 1, i=0;
		i2c_stop();
		return(1);
		i2c_stop();
		return(1);
		i2c_stop();
		return(1);
		i2c_stop();
		return(1);
		i2c_stop();
		return(1);
	//rd_data = i2c_receiveData_ACK();
	i2c_stop();
	//_delay_ms(1000);
	return rd_data;
	char temp_w[20];
		i2c_stop();
		return(1);
		i2c_stop();
		return(1);
		i2c_stop();
		return(1);
		i2c_stop();
		return(1);
	i2c_stop();
	return (0);
	unsigned int cnt;
	char temp[20];
	char pat_cnt;
	char pattern[12] = {0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,0x00,0xFF,0x00,0xFF};
	/*char pattern[12] = {0b00000001,0b00000011,0b00000100,0b00001000,0b00010000,0b00100000,
						0b01000000,0b10000000,0b00000000,0b11111111,0b00000000,0b11111111};*/
	init_devices();
	_delay_ms(1000);
	PORTC = 0x00;
	DDRC = 0xFF;
	_delay_ms(500);
	_delay_ms(500);
	_delay_ms(500);
	_delay_ms(500);
	_delay_ms(500);
	i2c_write(GPIOB,0xFF);    //  Reset GPIOB As Input
	_delay_ms(500);
	cnt=0;
	_delay_ms(100);
	/*inp = i2c_read(GPIOB);		               // Read from GPIOB
	_delay_ms(500);
		_delay_ms(1);
		togbutton^=0x01;
		//cnt=0;
	}      // end of if (inp == 0xFB)*/
		_delay_ms(500);
			_delay_ms(1);
			togbutton^=0x01;
				cnt=0;
			_delay_ms(500);
			pat_cnt = i2c_read(GPIOA);
			sprintf(temp,"\npat_count_1: 0x%x",pat_cnt);
			_delay_ms(500);
			cnt++;
		_delay_ms(2000);
	return 0;
Thanks & Regards,
Sasi
GO GREEN
thanks to david, js, brain and all.  Thanks alot :) . Thank you somuch.  happy coding and debugging. :)
Thanks & Regards,
Sasi
GO GREEN
I am pleased that you have it 'working'.
I still reckon that you should replace your TWI functions with proper library calls.
Bear in mind that you will be writing similar apps for other I2C chips in the future.
So it is worth choosing sensible names for your helper functions.    e.g. MCP23017_read() and MCP23017_write()
Good Day. Thanks david. Yes exactly correct what you told. Now i changed. Thanks david smiley
Thanks & Regards,
Sasi
GO GREEN
