PORTA interrupt on ATXMEGA64A3U
3 posts / 0 new
I would like to see the function interrupt moving INT routine break by PORTA's pin low active by JTAGICE3 debug mode.
But,I can't.
#include <util/delay.h>
#include <avr/portpins.h>
#include <avr/interrupt.h>
#define F_CPU 8000000UL
volatile int test_state=0;
void hw_setup(void)
	PORTB.DIRSET=0xFF;
	PORTD.DIRSET=0x3F;
	PORTA.DIRSET=0x00;
	PORTC.DIRSET=0x01;
	PORTE.DIRSET=0x00;
	PORTA.INT0MASK=0x40;
ISR(PORTA_INT0_vect)
	test_state++;
	hw_setup();
	sei();
INT0IF of PORTA.INTFLAGS is set when I make PA6 LOW after starting.
But,the break at ISR(PORTA_INT0_vect, does  not work.
Whould you tell me about I should add or repair anything code?
Thanks.
kenji maehara
You have to set the interrupt priority (which Atmel calls interrupt level).
It probably doesn't make any difference what priority (level) you choose.  At least it doesn't in my code so far.
hi steve17
Thank you so much.
kenji maehara
