Multiple inputs and multiple outputs servo problem
8 posts / 0 new
Hi all,
         I have an issue in my avr code. Basically , I have two different IR sensors that give an input when ever the emitter is blocked. I am using that input to run two different servomotors. i.e - IR sensor 1-> servomotor 1 and IR sensor 2 -> servomotor 2.
        My issue in code is I can only run the same servomotor after completing the sensing and output of the other pair. I wanted both to be independent in such a way that say, when I block the IR module 1 ,  servomotor 1 has to run. But now it waits for the 2nd pair to complete and then starts as cycle.
Please suggest me what kind of modification I have to make in code.
PS: I am a biologist by profession. Have to make this for a research purpose .
My code is down here...
#ifndef F_CPU
#define F_CPU 1000000UL
#endif
#include <util/delay.h>
  DDRA&=~_BV(3);//set port A pin 3 as input (Infra red sensor as input)
  PORTA|=_BV(3);//Enable pull up
  DDRA= _BV(2);// set Port A pin 2 as input( Another Infra red sensor as input)
  PORTA|= _BV(2);// Enable pull up
  TCCR1A|=(1<<COM1A1)|(1<<COM1B1)|(1<<WGM11);             //NON Inverted PWM
  TCCR1B|=(1<<WGM13)|(1<<WGM12)|(0<<CS11)|(1<<CS10);    //PRESCALER=1 MODE 14(FAST PWM)
  ICR1=19999;    //fPWM=50Hz (Period = 20ms Standard).
  for(;;)  // infinite loop
     if (bit_is_clear(PINA, 3))// if infra red is not sensed
          PORTD&=~_BV(4);
      //PORTD&=~_BV(4);//Servomotor output is 0;
         loop_until_bit_is_set(PINA, 3);//
             DDRD|=(1<<PD4);  //connected to first servomotor
            OCR1B=400;    //45 degree rotation
          _delay_ms(150);
         OCR1B=1050;      // 90 degree rotaiton
           _delay_ms(150);
         OCR1B=1950;    //135 degree rotation
               _delay_ms(150);
                     OCR1B=2400;   //180 degree rotaiton
            _delay_ms(150);
           _delay_ms(500);
     if (bit_is_clear(PINA, 2))// if second infra red sensor is not detected
          PORTD&=~_BV(4);
             DDRD|=(1<<PD5);  // connected to second servomotor
            OCR1A=400;    //45 degree
          _delay_ms(150);
         OCR1A=1050;      // 90 degree rotaiton
           _delay_ms(150);
         OCR1A=1950;    //135 degree rotation
               _delay_ms(150);
                     OCR1A=2400;   //180 degree rotaiton
            _delay_ms(150);
           _delay_ms(500);
......Thanks in advance
Cheers
Indran
indran
Your fundamental problem is the waiting.
You have discovered the reason embedded programs usually do not
wait for a task to complete before starting another independent task.
for(;;;) {
    // stuff depending on current time and motor1 state
    // stuff depending on current time and motor2 state
Note that the motor states include the times at which they arrived in those states.
If you have another timer available, a 10 ms "heartbeat" should not be too hard to arrange.
The time will only need to be eight bits, so you will not need to deal with atomicity issues.
I think you have other problems as well.
At least one derives from getting magic numbers wrong.
A magic number is an apparently arbitrary number that is used more than once.
The 150's seem to be consistent, but I think that you might have gotten a pin number wrong.
Also, DDRA4 is sometimes cleared and set again in short order.
In cases where PINA3 changes at just the right time, DDRA4 will stay cleared.
International Theophysical Year seems to have been forgotten..
Anyone remember the song Jukebox Band?
Welcome to the Forum.
I don't read C, so just a comment or on possible approaches to the problem.
If you turn on and off the servo based on the IR sensor only, and the durations are not timed, then one might consider this type of approach to running two "simultaneous" processes:
Use interrupts to make this task "easy".
Pseudo Code:
Headers
Ports and Pins setup
Init variables
Setup a timer in CTC mode to generate an interrupt every 10 mSec, (100 times a second).
Init Servo startup locations
Turn on interrupts
Do
               'Process Servo #1
               If  sensor #1 is on
                              Turn on Servo 1
                              turn off Servo 1
               end if
               'Process Servo #2
               If  sensor #2 is on
                              Turn on Servo 2
                              turn off Servo 2
               end if
               'Process anything else
               (Read a push button switch, flash an LED, etc)
               (Display IR status and servo status on LCD...)
Loop
Subroutine or Function, (whatever)            Turn On Servo 1
Function              Turn Off Servo 1
Function              Turn On Servo 2
Function              Turn Off Servo 2
Interrupt Routine:
Read IR sensor #1 and set a flag/bit/byte/variable On/Off for its state
Read IR sensor #2 and set a flag/bit/byte/variable On/Off for its state
return
In this case the status of the IR sensors is being continuously, (well, actually once every 10 mSec), updated.
In your Main Loop you take action based upon the status of the IR Sensors, but you don't actually even have to read them in the Main Loop, it is done in the background.
The decision to turn on and off the servos is based upon the status of the servo, and only takes a few instructions, (uSec's), so the Main Loop will actually process very quickly.
In this case the apparent servo update rate will depend upon the ISR rate, (10 mSec in this example).  The IR status can't change faster than that, (unless you change the ISR rate).
The Main loop is pretty simple.
The key actions are done in the subroutines.
I see some timed delays for a given servo degrees rotation in your code.
If you want the IR sensor to trigger a servo turn for a given time period, to get a given rotation, then in the Interrupt routine if the IR sensor changes state, instead of setting a simple flag, initialize a countdown timer in mSec for the delay desired.
In the Main Loop, if the countdown timer is > 0 turn the Servo on.
(You can re-turn it on each pass through the loop, it doesn't matter!)
Decrement the counter by 10 mSec.
If the countdown timer = 0 then turn off the servo.  (And turn it off each pass, again it doesn't matter if you keep turning it off)
Note, also, that timing a servo's activity sometimes works fine, sometimes it doesn't.  (For cheap, open loop servos, without internal absolute position sensing)
The actual position might vary, based upon the load against the servo, the servo's operating voltage, (does the servo's voltage drop when both servos are running simultaneously), and the operating temperature, (the stickiness of the lubrication on the servos gears as a function of ambient temperature), etc.)
For true precision positioning, one generally wants exact position feedback on the servo's position.  This could be an optical encoder disk, a mechanical micro switch, a rotational or linear potentiometer, etc.
For some applications a simple timed rotation might be fine, or there might be feedback for a sensor further down the process, (Servo opens or closes X amount of mSec, operating a valve, while the control loop is controlled by a flow meter distal to the valve, etc.)
Good luck with your project!
In the first place, take stock of your HW resolution.  Servo pulses happen every 20ms, so you'll never get e.g. a 150ms delay between movements.  It will be 140 or 160.
Given that, and given that the 20ms servo period is already ticking off, why not use it for your timing?
Here is a shell, no doubt with an inadvertent bug or two.  The point is, (possibly) check the sensor and (possibly) update the servos every servo tick, based on some state variables and some counters.
u8 servo1_cnt = 0;
u8 servo2_cnt = 0;
u8 servo1_state = 0;
u8 servo2_state = 0;
for (;;) // forever
    if (new_servo_period) // look at timer PWM overflow flag
        clear_overflow_flag  // by writing a 1 to it
        if (sensor1 && (servo1_state == 0))
            servo1_cnt = 8  // 160ms
            servo1_state = 1
            OCR1A = FIRST_POSITION
        else if ((servo1_state == 1) && (--servo1_cnt == 0))
            servo1_state = 2
            servo1_cnt = 8
            OCR1A = SECOND_POSITION
        ....and so on for servo1, then same for servo2....
Thank you so much for the detailed explanation .
indran
 Thank you so much for the detailed explanation  and the shell code you provided. I am trying to make changes in my codes using your information.
Cheers,
Indran
indran
  Thank you for pointing out the 150 ms issue. and also thank you so much shell code. I am trying to make changes in my code and see the impact.  Since  I am a biologist by profession, taking some time than others in debugging the stuff.
thanks a lot..
Cheers
Indran
indran
Thank you for pointing out my problems in the code. I am trying to modify my code and see the changes accordingly.
Thank you for the wonderful help and support.
Indran
indran
