LWM problem in the payload
6 posts / 0 new
Hi All
I'am using LWmesh but I fond a problem during a transmission message from Coordinator to END Device.
I've tried all message type from UNICAST , MULTICAST up to BROADCAST.
I've tried to send a message with 50 bytes of data. The data is the incremental number from 0 to 50.
ON the coordinator side I send the message with  NWK_DataReq(&appNwkDataReq) where appNwkDataReq is as follow:
00 00 00 00 00 21 00 01 01 03 0f 0f 31 06 36 58 12 00 00 21 00 01 32 00 01 02 03 04
05 06 07 08 09 0a 0b 0c 0d 0e 0f 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f 20
21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31
If you look the bold part is the data from 0 up to 49.
In the receiver side i received the following frame:
21 00 01 32 00 01 02 03 04 05 f8 d3 08 09 0a 0b 0c 0d 0e 0f 10 11 12 13 14 15 16 17
18 19 1a 1b 1c 1d 1e 1f 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f 30 31
If you look the underlined bold numbers something appens during transmission!!!
It's seems to be an incremental number like an ID number of the packet but I can't understand who change these two bytes.
I tried to disable security and other features but however this number appears !!!!
Someone have had the same problem ?
Closed
Closed
Sorry I forgot... I'm using the ATMega256RFR2  module.
Other informations:
I used the Wireshark sniffer and disabled Security.
In the air the frame is correct so Coordinador send the right data do Nodes.
Something appens in the Nodes ...
Find problem in the source code.
Forgot
msg->lqi = ind->lqi;
msg->rssi = ind->rssi;
Forgot my post !!!
None of what you have written makes any sense to me. You will have to be more specific and show some code if you want any help.
Sorry Alex
The problem was in the appDataInd function.
I left the old example code
AppMessage_t *msg = (AppMessage_t *)ind->data;
This code overwrite the data frame exactly in the location previous  explained.
Unfortunately this is a simple bug but yesterday I lost lots of time and for  this reason I wrote this request.
This morning, with 'fresh brain' , I re-checked code and used the sniffer to check the 'air'.
After exclusion of all possible problem I debugged step by step and found the problem.
I don't know if is possible to close otherwise I did that.
Sorry
Giacomo
