Help Needed with Peter Fleury I2C library
8 posts / 0 new
First off, thank you for taking you time to read this.
Now, I'm new to AVR studio 6.2 and I'm trying to get Peter Fleury i2c library to work.
I started out very simply:
1) A new project (c++)
2) copied the .h and .S to the same directory as the .cpp
3) used the Solution Explorer to add both the i2cmaster.h and i2cmaster.S (I need the asm version)
4) modified the i2cmaster.S to map the pines that I am going to use.
5) modified the delay rutine to fit a 1.8432 cristal.
6) copied the example program in the i2cmaster.h
7) changed the #include <i2cmaster.h> to #include "i2cmaster.h"
8) build the project.
Then, I get a boatload of errors:
Error    11    ld returned 1 exit status    collect2.exe
Error    1    undefined reference to `i2c_init()
And so on for all the routines.
I've searched the forum for two days now and read all the posts, but all I  can figure out is that I'm missing a step to map the .h to the .S
Can someone please point out my mistake?
Thank you again
If you are writing a C++ project,   you need to tell it that the Fleury code is C.
Otherwise the linker can't find the mangled symbols.
Thank you for you quick answer!
And ehhhh, how do I do that?
By the way, I forgot to mention that I get the same errors when I build the solution even if I don't include the .S file.
Now, I can compile the i2cmaster.S asm file just fine on it's own, but I still can't figure out how to "connect" the i2cmaster.h to the i2cmaster.S
Total votes: 3
Have you actually added i2cmaster.S to the source files in Atmel Studios Solution Explorer?
There are a lot of things we might need to know. One easy way to give us lots of info, without us asking repeatedly for tidbits, is to show the complete build output. Do a clean, then a build, switch to the Output tab/pane, mark everything, copy it and paste it into a reply here.
 In this particular case:
extern "C"
For further information about 'extern "C"', search this site and Google it. If you get nowhere, ask again here.
Thank you Johan,
You post solved my problem.
Have a great day and again, thank you for you time and knowledge (and no to mention patience)
Urant
Total votes: 2
Just for future readers that might have similar problems, what solved it (the "extern "C"" or the adding of the file to the project, or both)?
Also, I believe you can maybe  mark my post as a solution. This will rub my ego excellently, and possibly give me point in the future if this site becomes technically enabled to be a meritocracy. (I've never seen the solution marking mechanism myself - perhaps it is only visible to the user posing the original question...)
It was the "extern "C" ". I had included the file to the project from the start, and only removed it to see if it changed anything.
Again, thank you
Urant
