What is the problem with my compiler v5 and v6 showing the error below!
5 posts / 0 new
------ Build started: Project: Testingv6, Configuration: Debug AVR ------
Build started.
Project "Testingv6.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "D:\Program Files\Atmel\Atmel Studio 6.2\Vs\Compiler.targets" from project "D:\Documents and Settings\Hameed\My Documents\Atmel Studio\6.2\Testingv6\Testingv6\Testingv6.cproj" (target "Build" depends on it):
    Task "RunCompilerTask"
        Shell Utils Path D:\Program Files\Atmel\Atmel Studio 6.2\shellUtils
        D:\Program Files\Atmel\Atmel Studio 6.2\shellUtils\make.exe all
        Building file: .././Testingv6.c
        Invoking: AVR/GNU C Compiler : 4.8.1
        make: *** Access is denied.
        .  Stop.
        make: *** Waiting for unfinished jobs....
Likely, something has set the folders to read-only. Perhaps your antivirus program. I had trouble with AVG free setting the debug folder read-only.
274,207,281-1 The largest known Mersenne Prime
Oh yes: And throw version 5 out of your computer. Version 5 was a bad dream.
    Good day, and thanks for prompt response.
I have being using Atmel studio 4 with WiinAVR and its worrking, However, v6 is very slow, and from what you explained, I am using KAS Antivirus and I have checked the setting and none of AS v6 FOLDER WERE BLOCK.
Meanwhile, should I reinstall the software or I should reinstall my visual studio 2008 or upgrate it?
Thank you for your support.
Its all about my Antivirus, when I pause the protection before I lunch Atmel studio; it all work fine.
Thanks Torby for your advice.
