C++ Virtual Function Causing Exception
6 posts / 0 new
I am getting an exception when calling pure virtual functions.
Using - Atmel Studio 6 (Version: 6.2.1153 - )
1. Created a new C++ project,
2. Used the Board Wizard (EVK1100) to add ASF
3. Checked Linker/General -nostartfiles so it would compile
4. Removed Optimisation (-O0)
Header: "AtmelTest.h"
class interface
	public:
	virtual void virtual_function() = 0;
class base : virtual public interface
	public:
	unsigned char function();
class derived : virtual public interface, public base
	public:
	void virtual_function();
Source: "AtmelTest.cpp"
extern "C"
	#include
#include "AtmelTest.h"
derived object;
	board_init();
	object.function();
void derived::virtual_function()
unsigned char base::function()
	object.virtual_function(); // No Exception
	virtual_function(); // Exception
	return 0;
When calling this->virtual_function I get a Bus Error Data Fetch Exception
Can someone please help, Not sure what I am doing wrong
Solved it, was a bad idea to check -nostartfiles
Deleted the ASF startup_uc3.S instead, not sure what this will affect but seems to be working so far.
Not sure about the AVR32's, but for the 8-bitters using avr-gcc this would mean that no constructors will be run for statically allocated objects. Possibly some similar situation might be present re vtables, and since you're using virtual functions that would spell disaster.
P.S. Don't forget to make any destructors virtual! :wink:
Actually I think you might be right, I have had an issue that had me questioning constructors.
Can't remember if it was static or global, I assume global variables will be the same.
Yip you are right about the vtable out of interest I checked it in debug, they are filled in now pretty sure they were 0 previously.
That startup file must have debug code in it because now that I have deleted it breakpoints don't break when -nostartfiles is checked, using JTAGICE mkII.
Header: "AtmelTest.h" Code:
class interface
public:
public:
public:
[/code:1]
[code:1]
extern "C"
#include
derived object;
board_init();
object.function();
return 0;
This is a test.  I am quote a post with code but I have not modified the quoted content.  This test is being conducted after we removed access to the plain text editor and, thusly, the use of BBcodes.
Code:
class interface
public:
public:
public:
[/code:1]
[code:1]
extern "C"
#include
derived object;
board_init();
object.function();
return 0;
I am quoting the first post again and will go back and edit the post after submitting it.
The quoted content is fine if the new site saves the content in its native format.  Going back and editing the post (which I'm doing now) shows that the quoted content appears fine in the editor.
Please Read: Code of Conduct
Documentation: Atmel Community User Guide (work-in-progress)
Site Updates: Changelog
