ATmega328 Watchdog
15 posts / 0 new
Hey guys&gals,
I have recently started playing around with an Arduino Pro Mini board, and I intend to upload code remotely via bluetooth. I have a bluetooth module and everything works fine, but I still have to manually press the reset button in order to start the upload. This is obviously annoying, so I want to trigger the reset via software using the watchdog.
However, once the watchdog is triggered, it seems that the chip enters an endless reset loop. I understand that this usually happens because the watchdog is still active after the reset, and I tried to enter the code to disable it. This is the minimal example I tried to run, it should turn on the LED and then reset after 2 seconds:
 * WatchdogResetTest.cpp
 * Created: 26.11.2013 12:34:54
 *  Author: Christoph
#include
#include
#include
/*Disable the watchdog to prevent infinite reset loop */
void wdt_init(void) __attribute__((naked)) __attribute__((section(".init3")));
void wdt_init(void)
    MCUSR = 0;
    wdt_disable();
    return;
    _delay_ms(2000);
    PORTB ^= (1 << 5);
    _delay_ms(2000);
    wdt_enable(WDTO_15MS);
However, after the first reset it apparently enters an infinite reset loop. I also tried moving it to .init1, but both options don't seem to work. Does anyone have an idea where my problem might lie?
Thanks in advance, Christoph
How are you determining that?
If you have another LED available I'd consider doing something with it to know when you are in that wdt_init code.
Also I don't see you setting DDRB do how is your existing PORTB.5 code working anyway?
Unfortunately that's the only LED. However, it gets turned on nicely the first time the program runs.
I assume that it's a reset loop because the LED always flashes briefly after a reset, and it's blinking very rapidly after the first time the watchdog resets the chip, and only a power cycle stops this behaviour.
There are some unlisted dependencies that I don't have to explicitly include in the file (I'm using Atmel Studio), that's why PORTB is working fine.
I also just tried sending a small message to my terminal via USART at the beginning of main, but it only gets sent the first time the program runs.
To see if there is something bad with wdt_disable() I would try
void wdt_init(void)
   asm volatile("cli");
   asm volatile("wdr");               //watchdog reset
   MCUSR &= (1<<WDRF);
   WDTCSR |= (1<<WDCE) | (1<<WDE);
   WDTCSR = 0;
   asm volatile("sei");
Or
void wdt_init(void)
    MCUSR = 0;
    wdt_enable(WDTO_4S);
Unchanged behaviour for both suggestions :/
Might the following be the problem? The Arduino Pro Mini is from Sparkfun and already has a bootloader installed, I'm using a USB to Serial converter to program it. Is it possible that the watchdog kicks in before the bootloader has finished and my code never gets executed?
I can't burn the bootloader as I don't have the equipment yet unfortunately, so I can't verify this hypothesis, but does it sound reasonable? :)
Extremely possible. I bet the bootloader waits to see some trigger and I bet it waits longer than 15ms.
Also check the source of the bootloader - it's often the case that a bootloader already uses WDT for its own purposes (to reset before entering the app) so that could further complicate things.
Bah, I should have stayed with TI, stupid Arduino :P
Thanks for the hints, I'll check it out. I just noticed that I got another Arduino Pro Mini here that can act as an ISP to burn the bootloader, will report back if it works or not.
Yup you can load the ISP sketch into any Arduino and use it as an ISP programmer for a standalone chip or another Arduino.
Ah, now I remember I had the same problem and I had to disable watchdog in my AVR109 bootloader code.
It's been well over a year since I touched a pro mini, but I had similar issues with the bootloader not playing nice with the watchdog.
The source for the Pro Mini's bootloader includes this:
#ifdef WATCHDOG_MODS
	ch = MCUSR;
	MCUSR = 0;
	WDTCSR |= _BV(WDCE) | _BV(WDE);
	WDTCSR = 0;
	// Check if the WDT was used to reset, in which case we dont bootload and skip straight to the code. woot.
	if (! (ch &  _BV(EXTRF))) // if its a not an external reset...
		app_start();  // skip bootloader
#else
	asm volatile("nop\n\t");
#endif
... but examination of the pre-built .hex files for the pro mini line (of which there are 4) suggests that only one of them was built with -DWATCHDOG_MODS:
Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega168
The remaining three lack any reference to MCUSR or WDTCSR:
Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328
Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega168
Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
To the OP: which Pro Mini do you have? You could use avrdude to read flash and then wash it through avr-objdump to confirm that the bootloader's handling (or not) of MCUSR/WDTCSR.
JJ
"Read a lot.  Write a lot."
oh wow, that explains why the precompiled bootloader didn't change anything, stupid that see your answer only now :/ I tried various bootloaders this afternoon, but none worked (they either didn't solve the problem or didn't start the program at all). Unfortunately it seems to be rather hard to recompile the bootloaders on Windows, and I don't have a Linux right here.
I have an Arduino Pro Mini 328, 3.3V/8MHz
Could you maybe compile the correct file for me and put it online? And if you could also compile a version in which the bootloader is not skipped after a watchdog reset, I would be very grateful :)
Attached.
And if you could also compile a version in which the bootloader is not skipped after a watchdog reset...
Also attached. I wrapped the relevant code with an #if/#endif:
#ifndef ALWAYS_BOOTLOAD
#endif
JJ
Thousand thanks, it worked like a charm, you're awesome! :) Now onwards to the next problem :P
I just wanted to say thanks for this.  I have just successfully burnt one of your modified boot loaders onto an ATMega328 to running at 8MHz on the internal clock so that I can use the watchdog timer.  You have saved me a lot of heartache.
