Summary of Recent Activity for All AVR Freaks Forums
(select a forum to create a new topic)
Pages
Topic / Topic starter Forum Replies Views Last Post Topic Forum
New comments Terminal for printing outputs?   In-System Debuggers and Programmers 68
902
Commented by frog_jr on Wed. Oct 18, 2017 - 03:02 PM
Terminal for printing outputs?  Commented by frog_jr on Wed. Oct 18, 2017 - 03:02 PM In-System Debuggers and Programmers
New comments Simplest toolchain / programmer setup for *smallest* development board? megaAVR and tinyAVR 34
299
Commented by theusch on Wed. Oct 18, 2017 - 02:55 PM
Simplest toolchain / programmer setup for *smallest* development board? Commented by theusch on Wed. Oct 18, 2017 - 02:55 PM megaAVR and tinyAVR
New comments signal generator (sawtooth,sine,triangle,square) 1hz to 100khz with AVR megaAVR and tinyAVR 41
754
Commented by avrcandies on Wed. Oct 18, 2017 - 02:17 PM
signal generator (sawtooth,sine,triangle,square) 1hz to 100khz with AVR Commented by avrcandies on Wed. Oct 18, 2017 - 02:17 PM megaAVR and tinyAVR
New comments Bootloader updating megaAVR and tinyAVR 10
218
Commented by clawson on Wed. Oct 18, 2017 - 02:13 PM
Bootloader updating Commented by clawson on Wed. Oct 18, 2017 - 02:13 PM megaAVR and tinyAVR
Hot topic, new comments Remote timer variable   megaAVR and tinyAVR 29
240
Commented by clawson on Wed. Oct 18, 2017 - 02:09 PM
Remote timer variable  Commented by clawson on Wed. Oct 18, 2017 - 02:09 PM megaAVR and tinyAVR
New comments Serial communication with atmega32 and the Arduino 2560 Arduino 29
393
Commented by azizollah on Wed. Oct 18, 2017 - 01:51 PM
Serial communication with atmega32 and the Arduino 2560 Commented by azizollah on Wed. Oct 18, 2017 - 01:51 PM Arduino
New comments [TUT] [C] Using the EEPROM memory in AVR-GCC   Tutorials 352
493,612
Commented by ki0bk on Wed. Oct 18, 2017 - 01:42 PM
[TUT] [C] Using the EEPROM memory in AVR-GCC  Commented by ki0bk on Wed. Oct 18, 2017 - 01:42 PM Tutorials
New comments PC to AVR message handling megaAVR and tinyAVR 7
43
Commented by Brian Fairchild on Wed. Oct 18, 2017 - 01:37 PM
PC to AVR message handling Commented by Brian Fairchild on Wed. Oct 18, 2017 - 01:37 PM megaAVR and tinyAVR
New comments ATMEL Start Website Broken? Can we get a local version? Atmel Software Framework (ASF) and Atmel Start (ASFv4), all architectures 3
136
Commented by ScottMN on Wed. Oct 18, 2017 - 01:30 PM
ATMEL Start Website Broken? Can we get a local version? Commented by ScottMN on Wed. Oct 18, 2017 - 01:30 PM Atmel Software Framework (ASF) and Atmel Start (ASFv4), all architectures
New comments usart synchronous on ATMEGA 2560 megaAVR and tinyAVR 5
88
Commented by theusch on Wed. Oct 18, 2017 - 12:59 PM
usart synchronous on ATMEGA 2560 Commented by theusch on Wed. Oct 18, 2017 - 12:59 PM megaAVR and tinyAVR
New comments I2C on Atmel Start Atmel Software Framework (ASF) and Atmel Start (ASFv4), all architectures 3
69
Commented by ScottMN on Wed. Oct 18, 2017 - 12:53 PM
I2C on Atmel Start Commented by ScottMN on Wed. Oct 18, 2017 - 12:53 PM Atmel Software Framework (ASF) and Atmel Start (ASFv4), all architectures
New comments XMEGA DMA UART strange AVR XMEGA 2
57
Commented by frog_jr on Wed. Oct 18, 2017 - 12:43 PM
XMEGA DMA UART strange Commented by frog_jr on Wed. Oct 18, 2017 - 12:43 PM AVR XMEGA
New comments Display filtered data megaAVR and tinyAVR 5
47
Commented by dbrion0606 on Wed. Oct 18, 2017 - 12:32 PM
Display filtered data Commented by dbrion0606 on Wed. Oct 18, 2017 - 12:32 PM megaAVR and tinyAVR
New comments Xmega256a3bu USB CDC issue AVR XMEGA 0
10 Xmega256a3bu USB CDC issue AVR XMEGA
New comments Job offer (CoAP protocol integration) Marketplace 1
33
Commented by clawson on Wed. Oct 18, 2017 - 09:01 AM
Job offer (CoAP protocol integration) Commented by clawson on Wed. Oct 18, 2017 - 09:01 AM Marketplace
New comments AVR (ATmega328P) - Reading input from PORTB to display hex digits on 7-Seg display   megaAVR and tinyAVR 43
783
Commented by clawson on Wed. Oct 18, 2017 - 08:57 AM
AVR (ATmega328P) - Reading input from PORTB to display hex digits on 7-Seg display  Commented by clawson on Wed. Oct 18, 2017 - 08:57 AM megaAVR and tinyAVR
New comments No access to application notes from Atmel website megaAVR and tinyAVR 9
126
Commented by clawson on Wed. Oct 18, 2017 - 08:30 AM
No access to application notes from Atmel website Commented by clawson on Wed. Oct 18, 2017 - 08:30 AM megaAVR and tinyAVR
New comments 4 bytes less RAM when using my own pointer to FILE instead of stderr Compilers and General Programming 3
104
Commented by clawson on Wed. Oct 18, 2017 - 08:21 AM
4 bytes less RAM when using my own pointer to FILE instead of stderr Commented by clawson on Wed. Oct 18, 2017 - 08:21 AM Compilers and General Programming
New comments Error programing Lock bits atmega32 megaAVR and tinyAVR 0
19 Error programing Lock bits atmega32 megaAVR and tinyAVR
New comments Storing a Value to EEPROM When Power is Shut Off to a ATtiny841 megaAVR and tinyAVR 3
85
Commented by MicroGyro on Wed. Oct 18, 2017 - 06:47 AM
Storing a Value to EEPROM When Power is Shut Off to a ATtiny841 Commented by MicroGyro on Wed. Oct 18, 2017 - 06:47 AM megaAVR and tinyAVR
New comments UC3 with RPi 3 for data logging   AVR UC3 33
1,166
Commented by mikech on Wed. Oct 18, 2017 - 04:00 AM
UC3 with RPi 3 for data logging  Commented by mikech on Wed. Oct 18, 2017 - 04:00 AM AVR UC3
New comments avrdude with AVRISP-mkII on macOS 10.12 ? In-System Debuggers and Programmers 5
233
Commented by gchapman on Wed. Oct 18, 2017 - 03:08 AM
avrdude with AVRISP-mkII on macOS 10.12 ? Commented by gchapman on Wed. Oct 18, 2017 - 03:08 AM In-System Debuggers and Programmers
New comments Embedded linux modules General Electronics 48
4,483
Commented by gchapman on Tue. Oct 17, 2017 - 10:03 PM
Embedded linux modules Commented by gchapman on Tue. Oct 17, 2017 - 10:03 PM General Electronics
New comments petitfs + Data Size Viewer = surprising results? megaAVR and tinyAVR 8
120
Commented by clawson on Tue. Oct 17, 2017 - 08:46 PM
petitfs + Data Size Viewer = surprising results? Commented by clawson on Tue. Oct 17, 2017 - 08:46 PM megaAVR and tinyAVR
New comments Replacing the XMEGA on an Xplained XMEGA A1? AVR XMEGA 7
352
Commented by gchapman on Tue. Oct 17, 2017 - 05:47 PM
Replacing the XMEGA on an Xplained XMEGA A1? Commented by gchapman on Tue. Oct 17, 2017 - 05:47 PM AVR XMEGA
Pages
Legend
New or Updated Discussion
Discussion
Locked Discussion
New or Updated Hot Discussion
Hot Discussion
Sticky Discussion or Announcement
New or Updated Sticky Discussion
